5 lugger bs thread
Discussion in '5 Lug' started by Joels98taco, Dec 9, 2011.
  1. Sep 24, 2013 at 7:27 AM
    #641
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    The manual transmission drain plug is magnetic but the rear differential drain plug is not. I would buy and extra magnetic plug for the rear differential to collect bits of metal.
  2. Sep 25, 2013 at 2:14 PM
    #642
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Oh whew, I was having visions of stripped/ rounded drain plugs and immobilized tacos.
  3. Sep 28, 2013 at 10:41 PM
    #643
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    Got some work done on my truck. New break pads, callipers and disks. Found out my I snapped the nut and shock pivot piece so my front shock was just kinda chillin not doing anything..
    New coils but I ordered stock replacements the old worn out coils that were on the truck were not stock and so now my truck rides lower, tires rub on the fenders on every little bump and the ride is too soft. Don't know what I need to order now but I want the height and stiffness of the ride back.
  4. Sep 28, 2013 at 11:40 PM
    #644
    TheRedTac0
    TheRedTac0 Just a Taco guy, both food & truck
    Christopher
    Las Vegas
    2006 5-lug Regular Cab Impulse Red
    BHLM, Black Housing Altezza Taillights, 3-piece billet grille, Fatbob's 2.75" Lift with AAL, 15x8 Ion Alloy Wheels wrapped in 31x10.5 Falken's
    Has anyone done fog light installation on their 2nd gen 5-lug?
    I know our models don't come with fogs but I just scored a killer deal and I need to know how to install them, what will I need?
  5. Sep 28, 2013 at 11:46 PM
    #645
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    thats exactly what konsta did, but on his front wheels. He put 2 over ride buttons in the cab, one for each front wheel (must have been abs so he could force them to lock up) and when he lifted a tire in the front, or one was spinning in sand he could lock that one and send the power down to the other. bretty brilliant. then he got an ARB and that was the end of that haha
  6. Sep 29, 2013 at 12:02 AM
    #646
    Brendo Ballz808
    Brendo Ballz808 Slammed or lifted.. ANYTHING IS BETTER THAN STOCK
    BRENDEN
    Oahu
    SNOFLAKE
    Check out my build:)
    Mines didn't come with and I installed em
    I bought the eBay smoked ones which are still all there just the swith was POS so I used a different one
    Instead of tryna wire it up with the fog light mod connected it straight to the battery grounded it and ran power to the switch so mines are done manually by a switch which I don't mind if they don't go off automatically or not
    Fairly simple honestly should be a no brainer bro
  7. Sep 29, 2013 at 2:51 AM
    #647
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    I installed a set of PIAA lamps on mine and could not be happier. Install was not all that hard. I have a feeling that when I need to replace a bulb it will be a minor pain since I will need to remove the entire lamp to replace the bulb.
  8. Sep 30, 2013 at 1:55 PM
    #648
    Shauncho
    Shauncho Embrace your inner Bro-ness
    Shaun
    Parts Unknown...
    none
    ok, so I have this '96 5 lugger that I'm thinking about building up a little bit. I've only done a little research so far but it looks like a lot of the suspension stuff is intended more for 6 luggers.
    What are my suspension options for my '96 5 lugger?
    I don't want to spend an arm and a leg but would like something that's at least a slight improvement over stock. At this point, pretty much anything would an improvement over taco leaf spring frown.
    Here's more vehicle specs:
    '96
    AC cab
    4 banger
    all stock for now.
  9. Sep 30, 2013 at 1:59 PM
    #649
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    What do you want to do to it?
    For front suspension you could get custom CO's, spindles, or a LT kit.
    For the rear any leafs will work if they work on the 6 lugs, shocks will be different length (i think)
  10. Sep 30, 2013 at 2:03 PM
    #650
    Shauncho
    Shaun
    Parts Unknown...
    none
    First, thanks for taking the time to help me. :D
    Main thing I want to do is just update the shocks/leafs which are all but blown. If I can, I'd like to add a little lift to it as well since stock height is pretty damn low. It's only a 2wd, 4 banger so there's only so much I can do with it. It's kinda more of a project car. don't really have any real plans for it but at the same time, there's nothing stopping me from doing whatever I want with it (other than money of course). so it's kinda wide open. I'm open to suggestions.
  11. Sep 30, 2013 at 2:07 PM
    #651
    MowTaco
    Kansas
    You have frowny leaves on a 5 lug? I haven't heard of that yet. 6 lug leaves will lower your truck, probably don't want that. I'd say go with an AAL if your leaves are weak (I don't know of any replacement packs offered for us other than just some junkyard ones out of a wrecked truck). Another option (which is what I went with) is shackles for about 2" of rear lift. You retain stock ride quality/load handling but get lift. In your case I think your leaves need help so an AAL would be the best bet. Spindles are probably your cheapest option out front, or maybe extended coils. Again, the spindles will maintain stock ride and handling characteristics so I chose them over coils.
  12. Sep 30, 2013 at 2:09 PM
    #652
    95 taco
    95 taco Battle Born
    No problem
    For the leafs you could get new ones, a add a leaf, or refurbish your current ones
    For rear shocks you could go with OEM replacement from auto zone, or you could go with bistein shocks.
    For the front springs, i believe moog makes a replacement spring, if you put a v6 spring in it'll lift the truck roughly 1'' or 1.5''.
    If i had a little money and time, and fab skills i'd turn the truck into a SAS 5 lug.
  13. Sep 30, 2013 at 2:11 PM
    #653
    95 taco
    95 taco Battle Born
    I've got frowning leaves on my 5 lug, it's had a camper shell on it for a while, but not a whole lot besides that.
  14. Sep 30, 2013 at 2:19 PM
    #654
    Shauncho
    Shaun
    Parts Unknown...
    none
    The leafs may not be totally frowny (I haven't seen the truck in a little bit)...but from what I remember, they were at the very least, almost flat. I'm gonna swing by my folks place today and check out the truck and take some pics of it so I can start planning. So no one sells new leaf packs for 5 lugs? lame...
    yeah, I was thinking spindles/shackles would be my best bet. So as far as shocks go, what are my options there. Will the same bilstein/OME options for 6 lugs also work for 5 lugs?
  15. Sep 30, 2013 at 2:29 PM
    #655
    Shauncho
    Shaun
    Parts Unknown...
    none
    Yeah, I'm thinking AAL for the leafs. Don't have time to refurb my own. possibly different shackles if it'll help give a lift.
    Won't adding a v6 spring in there make it ride a little rough? I was hoping to maintain somewhat of a factory ride. I'm kinda leaning towards spindles for the lift aspect and just get something close to OEM for the struts/springs.
  16. Sep 30, 2013 at 6:46 PM
    #656
    Shauncho
    Shaun
    Parts Unknown...
    none
    yup, definitely frowny. :(
  17. Oct 4, 2013 at 9:03 PM
    #657
    Nathan
    Nathan Well-Known Member
    Nathan
    Frederick County, MD
    2010 5 lug single cab
    What's everyone's favorite street tire?
  18. Oct 7, 2013 at 8:03 AM
    #658
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    How true do we know this to be?
  19. Oct 7, 2013 at 9:44 AM
    #659
    KCDuran
    KCDuran Stormtrooper
    Kyle
    South Jersey
    5 Lug'n 4 banger
    Icon/TC Mid Travel Kit, Kenwood Deck, Helix Audio System, BHLM (With Tinted Reflectors), Tinted Taillights, Satoshi Grill (color matched to super white), Stormtrooper sticker, Air Force sticker HUA! Re colored gauges (White numbers and ODO with Blue Needles) Magnaflow Glasspack Muffler, Stainless steel exhaust tip, 8k HIDs, LED Satoshi, Eye Lids, ARB locker (4.10 Gears), 8k FOG HIDs, LED Head Lamp, Tonneau Cover
    Way above my head... You may want to post this in the general discussion thread just so all TW guys can give their input. Not many look at the 5 lug area
  20. Oct 7, 2013 at 9:45 AM
    #660
    MowTaco
    Kansas
    Well I'll be damned. On your shocks question, you're kinda on your own. I ended up ordering a set from Doetsch because they offered a kit that was identical to what I was doing to my truck and already had the shocks worked out for it. Obviously the fronts stay the same as stock since the only changes were below the LCA with the spindles, the rears are a little longer.
    I'm sure you can find Bilstein and OME shocks that'll fit but I wouldn't just automatically use the same ones 6 lugs use.
