5 spd trans won't go into 1,3,5
Discussion in '1st Gen. Tacomas (1995-2004)' started by bwheat1, Jul 9, 2014.
  1. Jul 9, 2014 at 12:46 PM
    bwheat1
    bwheat1 [OP] New Member
    Brent
    Roswell NM
    95 Tacoma ext-cab
    none yet
    I have a 1995 Tacoma with a 5 speed manual transmission and it wont go int 1,3, or 5th gear but it goes into 2 and 4th just fine could somebody tell me where to start.
  2. Jul 9, 2014 at 1:34 PM
    dispatch55126
    dispatch55126 Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
    Since you live where you live...
    :alien::alien::alien:
    Seriously though, when is the last time you changed your gear oil? Mine was difficult getting into 1st and 3rd and after changing the oil, shifting is much easier. Beyond that, it could be your shifter seat not allowing you to fully shift in that direction.
  3. Jul 9, 2014 at 1:43 PM
    XR1200
    XR1200 Active Member
    SF Bay Area
    00 PreRunner SR5 V6
    Synchros could be shot. I had a Mitsubishi truck that lost 3rd and afterdraining the fluid and seeing too many metal flakes and then taking off thecover allowed me to see a synchro that had broken apart. However, in your caseit may not be a synchro but a shift fork, can also be a shifter ball that has disintegratedcausing too much slack, which can cause engagement issues.
    Drain the oil into an empty pan and look for foreign material like brassflakes and/or pieces.
  4. Jul 9, 2014 at 2:05 PM
    Indy
    Indy Master of all I survey.
    Hmmm, that's odd. :D
  5. Jul 9, 2014 at 2:27 PM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    Common result of a shift rail issue, or detent ball. However extremely dirty trans fluid can cause issues like this as well. Is it just really difficult to get it in those gears, resulting in you having to force it, or will it just not go in those gears at all, any time? (driving, sitting still, engine on or off, etc)
  6. Jul 9, 2014 at 3:30 PM
    bwheat1
    Brent
    Roswell NM
    95 Tacoma ext-cab
    none yet
    Found it, it was the plastic bushing on the end of the shifter. Thanks for the comments though.
  7. Jul 9, 2014 at 3:52 PM
    dispatch55126
    MN
    2004 Xtracab SR5
    Marlin Crawler makes a replacement cup made out of a more durable material.
  8. Jul 10, 2014 at 12:02 PM
    BamaToy1997
    Bill
    Navarre, FL
    I may need to get that fix from MC. My shifter is a bit sloppy.
  9. Mar 26, 2016 at 7:27 PM
    jmlinne
    jmlinne Well-Known Member
    Mitch
    Montana
    '97 Tacoma 4x4 w/ 5-speed manual and locking hubs, stock for now
    This discussion may fit my problem. My 97 4x4 w/ 2.7L 4 cyl and 5-speed manual has become difficult to shift to 1st only. This trans. has been super smooth for over 200K miles. I replaced the clutch at engine overhaul at 180K. The problem has only just begun and is intermittent. I thought it might be the blocker rings in the synchro. I'm a mechanic but have never touched a manual trans. I could also use some help finding an overhaul manual for the trans.
    eweezy1007 likes this.
  10. Mar 26, 2016 at 9:26 PM
    CodeSeven
    CodeSeven Yo
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    manual trans are very easy. start a new thread asking for this info and well go from there. best not to revive old threads when unnecessary. :)
  11. Mar 31, 2016 at 11:29 AM
    CodeSeven
    CodeSeven Yo
    Serge.
    Coachella Valley
    you really trying to say im clueless about not reviving old threads and starting new ones?
  12. Mar 31, 2016 at 12:09 PM
    MrRiverMan
    MrRiverMan Compulsive tinkerer
    WNC
    96 Taco 2.7 4x4 & 96 T100 3.4 4x4
    Found her junked on the bank of a river w/216k. Replaced most of it, now at 275k and still ticking.
    Check the shifter seat and bushing. These are easy parts to replace - see the link above to the Marlin Crawler kit.
  13. May 11, 2016 at 8:51 PM
    stumblestacks
    stumblestacks Well-Known Member
    North lake Tahoe
    Beat up 98taco 3.4L limited xtracab TRD
    Finally blew the motor at 230,000, sprung for a Jasper with 100,000/3 year warranty. The birdpig has a new set of wings! OME heavy load lift kit, Dakar leafs w/AAL, frame mounted energy suspension 4.5" bumpstops, 882 coils, nitrocharger sport shocks, trail gear sliders, addicted offroad front bumper, KC 130w daylighters, Warn M8000, 31" BFG KM2's, custom dents and Nevada pinstripes.
    I tried to install the Marlin Crawler seat and bushing today but the wiring clip that connects the push button 4wd on the t-case knob would not release. I couldn't get enough room to work under the whole boot/floor plate assembly without detaching that wire. I don't know if it's just fused together with 18 years of baked-in dirt and grime or what. Anybody have any tricks to get that wire clip separated?
  14. May 12, 2016 at 1:33 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Did you try spraying it down with WD or something similar?
  15. May 12, 2016 at 7:36 PM
    stumblestacks
    North lake Tahoe
    Yes I did but it didn't help. I might just have to cut the wire and put in a new clip. I haven't been able to find any info on the wire or the clip online. The guys at Marlin Crawler hadn't heard of anybody having the same problem. I wonder if my wire is shorter than normal so I can't just take the knob off and slide the whole boot/plate assembly up enough to do the job.
