5 TPMS Sensors??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rememberthecaptain, Dec 24, 2022.
  1. Dec 25, 2022 at 6:04 AM
    #41
    NoVa TRD Sport
    NoVa TRD Sport Well-Known Member
    Alexander
    Northern Virginia
    2021 Army Green TRD Sport
    Leer cap
    This is the answer. I have a matching spare with a TPMS sensor, but the sensor is inactive. When the time comes to rotate the 5 tires, the tire shop will reprogram the system so that the 4 active tires are recognized.
    BTW, when this bitter cold weather hit, the tire pressures fell (below 28 psi) so that the dash warning light came on. I haven't gotten around to topping off the air in the tires (precisely because of the cold weather), so the warning is still on. If I top off the tires, when the weather warms up, I think I will have an overpressure problem.
  2. Dec 25, 2022 at 6:27 AM
    #42
    NoVa TRD Sport
    Alexander
    Northern Virginia
    Leer cap
    Another solution is to just not have a TPMS sensor in the spare tire (even if it's a matching tire that will be used in a 5-tire rotation). When the time comes to do the rotation, after the tires are rotated you just press the reset button. The system will be fooled into thinking that the new spare (that has a TPMS sensor) is one of the active tires. It will now monitor the air in the spare, as well as 3 of the active tires. At least I think it would work that way.
  3. Dec 25, 2022 at 6:38 AM
    #43
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    :thumbsup::thumbsup:yep
    Idaholandho[QUOTED] likes this.
  4. Dec 25, 2022 at 6:48 AM
    #44
    Rexfordian13
    Rexfordian13 Well-Known Member
    J
    Albany/NY Capital District
    2015 TRD Sport DCSB MT
    I did, (the PVC TPMS Cask) couldn’t get it to trick the TPMS, now it sits in the garage and I have gotten used to the warning light.
  5. Dec 25, 2022 at 8:23 AM
    #45
    eurowner
    eurowner Duke Sky
    Scoty
    Nope, these trucks will only see 4, not 5 sensors. These trucks will only use four, not five, separate sensor ID#s. And the TPMS button does not program the PCM. Try again.
  6. Dec 25, 2022 at 10:03 AM
    #46
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Now hold on there Bronco Billy. As far as the $10 gauge reference i made i guess i should have clarified. The gauges i have were probably around $10-$15... but that was 40-50 years ago. Back then they were quality tools... same one's now days would be more. I've checked them against electronic gauges and they're spot on. Judging by the complaints people are having since tpms came out the pressure gauge is less complicated and more reliable.... and no batteries required! Just think what tpms will end up costing us in the same 40-50 year time frame.
    For those wishing they had a sensor in the spare... my 07 came with 5. Every time it got cold enough the difference in psi between the heated up tires and the cold spare was enough to set the dash light off.... complete pita. Be careful what you wish for.
    never been in a dollar store :rasta:
