5000 lb Boat up the Ramp?
Discussion in 'Towing' started by Florida Guy, Aug 16, 2012.
  1. Aug 16, 2012 at 4:34 PM
    Florida Guy
    Florida Guy [OP] Member
    I am lookingfor a tow vehicle to pull a 5000 lb boat – total load including trailer, fuel,gear, etc. Until two days ago I used a 1996 F150 with a 4.9 liter in-line-6. It pulled the boat great. But it was killed by another vehicle and has gone to truck heaven. I love Toyotas (have had several – still have a Camry – and like the Tacoma over the Tundra. I’m sure with a 6500 lb tow rating the Tacoma can pull my boat on the road, but my concern is pulling up the incline of the ramp.The F150 claimed 145 hp @ 3400 rpm and 265 ft-lbs @ 2000 rpm. The Tacoma 4.0 liter V6 claims 236 hp @ 5,200 rpm and 266 ft-lb @ 4,000 rpm. At first look the torques are close, but theF150 has it on the low end where you need it when slowly coming up a ramp. The ramp I usually use is about three miles away and has excellent traction – deep grooved surface for traction– and I’ve never lost traction even with the light back end of a truck and a very wet ramp. Has anyone out there had experiences good or bad pulling a similar load up a ramp with a Tacoma? And if it will do the job, do I want to put that kind of strain on it? I don’t want to go to a Tundra, but I will if I must. Thanks in advance for your thoughts.
  2. Aug 16, 2012 at 4:40 PM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    I pull a pontoon boat all the time up some steep grades it still accelerates going up hill
  3. Aug 16, 2012 at 5:57 PM
    Florida Guy
    Sounds good. My boat is a fiberglass 22 ft Mako - pretty heavy rig. Do you know how much your total weight is?
  4. Aug 16, 2012 at 6:13 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2017 trd off-road dcsb
    just use 4 low.
  5. Aug 16, 2012 at 6:17 PM
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    itll pull it no problem at all.. ive had 7k pound equipment trailers behind my taco...i just upgraded my rear springs ;)
  6. Aug 16, 2012 at 6:18 PM
    hard2kill
    Rhinebeck NY
    i would deff get an automatic over the 6spd though the autos are a great tranny our 6spds not so great...
  7. Aug 16, 2012 at 6:39 PM
    SVHANC
    SVHANC Kermit
    Sam
    Knoxville, TN
    '10 4x4 5sp 4cyl Access Cab
    Weathertech Floor Liners, Scangauge 2, Tailgate Hose Clamp, Rear Seat Headrests Removed
    I pulled a 7000 lb wooden boat up a steep ramp with my 4cyl stick. I just put it in 4lo and let out the clutch. It idled up the ramp. No problem. No wheelspin either.
  8. Aug 17, 2012 at 5:35 AM
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    The Tacoma has 4 low, I bet it would tow the boat up the ramp no problem even in high range 2WD.
    Make sure to put a breather hose on your rear differential routed to somewhere high like your gas filler neck.
  9. Aug 17, 2012 at 5:38 PM
    Florida Guy
    Please excuse my ignorance, but what is 4lo? Is that only on the 4x4 Tacos, or do all the manual trannys have a 'granny' gear including the 2x4?
  10. Aug 17, 2012 at 7:09 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    yeah 4lo is only for 4x4
  11. Aug 18, 2012 at 4:13 AM
    Florida Guy
    I guess I should point out that I am considering a 2 wheel drive automatic transmission Tacoma to pull with. Do you guys still think it will pull a 5000 lb boat out of a good ramp?
  12. Aug 18, 2012 at 5:07 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Yes, I have a 2wd PreRunner and my boats tow fine, it can get slippery on some ramps but overall you will be fine. I assume it is the 6 cylinder and not the 4?
  13. Aug 18, 2012 at 5:27 AM
    4x4Taco2012
    4x4Taco2012 Well-Known Member
    Philadelphia, PA
    2013 DCSB TRD Sport 4x4
    Tacoma Bed Mat, TRD Front Skid Plate, Pop'N'Lock Tailgate Lock, Weathertech Digifit Floor Mats, BAK Roll-X Tonneau Cover, Toyota Wheel Locks, Sliding Rear Window Lock, Center Console and Glove Box Motion Detection LEDs, BFG Rugged Terrains, PrimusIQ Brake Controller, Toyota Cargo Net, Entune w/Nav.
    Buy a 2wd PreRunner (obviously with the 4.0L) and you'll be fine.
