50T Long Travel Leaf Packs
Discussion in 'Engage Offroad' started by Engage Offroad, Mar 3, 2010.
  1. Mar 3, 2010 at 11:03 AM
    Engage Offroad
    Engage Offroad [OP] Dezert Lovers Unite Vendor
    Engage Marketing
    Pomona, CA
    PM me directly here on TW for prices.
  2. Mar 3, 2010 at 11:05 AM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    thats sexy
  3. Mar 8, 2010 at 10:09 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    ^^^so buy a pair. Way better then deaver and they have a warranty too.
  4. May 12, 2010 at 4:18 PM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    what all is needed to run these mama jammas
  5. May 12, 2010 at 6:59 PM
    Engage Offroad
    Engage Marketing
    Pomona, CA
    the 50T pack is NOT a bolt on leaf, so new front hangers, new rear hangers, and everything else that is needed for any leaf to function....Hassim...EngageOffRoad....909-238-6788
  6. May 13, 2010 at 3:54 AM
    EL TACOROJO
    BURRY
    south mills NORCAK
    Got any pics of the 50t installed on a 1st Gen
  7. May 13, 2010 at 8:44 AM
    Engage Offroad
    Engage Marketing
    Pomona, CA
    the truck in the flyer at the very top of this thread is a 1st gen with the 50T pack installed
  8. May 19, 2010 at 11:17 AM
    th3bigk0
    th3bigk0 GETTN IT
    Dylan
    Lamecaster
    13 TRD Double Cab
    Fox 2.5 RR C/O's,Camburg UCA,Camburg Spindles,KING 2.5,OME Dakar Leafs,285 KM2,XD HOSS 16'',BHLM,HID's,CB,Hornblasters Shocker 540 train horn,KICKER 12 ported....
    Is this the only leaf pack for the 1st gen u guys have?
  9. May 19, 2010 at 8:08 PM
    Engage Offroad
    Engage Marketing
    Pomona, CA
    yes this is the only pack we sell, we do not have any bolt on applications:D
  10. May 19, 2010 at 8:23 PM
    mreimann
    mreimann Well-Known Member
    Denver, CO
    '15 double cab Limited
    Icon C/O, Fox 2.0, All Pro Expo 2.0 leafs, Total Chaos UCA's, Airflow snorkel, Custom Built Bed Rack, Pelfrey aluminum front bumper and IFS skid, All Pro aluminum rear bumper, SmittyBuilt winch. RTT
    do you carry most of the stuff needed to make these packs fit?
    and if you don't, do you have references to some place that does?
  11. May 20, 2010 at 12:46 AM
    Engage Offroad
    Engage Marketing
    Pomona, CA
    Yes, we fabricate all the parts needed to mount the leaf packs to the truck.
    You can PM for details.
    :thumbsup:
    - Mohawk Mike
  12. Sep 26, 2010 at 5:54 PM
    joey34mx
    joey34mx Well-Known Member
    Joey
    Southern California
    2005 Tacoma V6 prerunner
    How many inches will these leafs lift the rear end?
  13. Sep 27, 2010 at 6:14 AM
    Engage Offroad
    Engage Marketing
    Pomona, CA
    this is a spring under kit, you can have 2-4 inches of lift depending on how you set up the rear pack, these leafs are in no way a bolt on deal...Hassim...EngageOffRoad...909-238-6788:D
  14. Sep 27, 2010 at 10:13 AM
    joey34mx
    Joey
    Southern California
    alright so on access cab how many leafs would you remove if you wanted just a couple inches of lift.
  15. Sep 27, 2010 at 11:17 AM
    EL TACOROJO
    BURRY
    south mills NORCAK
    wouldn't that be defeating the purpose off the packs if you started pulling the leafs out
  16. Sep 27, 2010 at 9:13 PM
    Tacorunner87
    Tacorunner87 Well-Known Member
    Chino Hills Ca
    To much to list!
    Well I removed the 5th leaf from the bottom for my 01 ext. Cab just cause I dont have a full Cage.
  17. Sep 28, 2010 at 8:07 PM
    Engage Offroad
    Engage Marketing
    Pomona, CA
    all depends on the entire weight you will have when the truck is done, 1-2 spares, quantity of fuel and so on
    no the pack holds up x amount of weight, if you are under weight you can pull out a certain leaf for a certain weight, the packs are designed for heavy race trucks,
  18. Oct 1, 2010 at 10:38 PM
    zero4
    zero4 Metal Cutter
    Will
    Northridge, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Are you guys open Saturdays or even there Sundays sometimes? I'd like to cruise by one day & check out the shop, parts, trucks... :D
  19. Oct 4, 2010 at 9:05 AM
    Engage Offroad
    Engage Marketing
    Pomona, CA
    we are open mon.-fri. 9-5, sat we are sometimes open as we are at races, prerunning or events, call us to see if we are in when you want to stop by, sundays we are closed...Hassim...EngageOffRoad....909-238-6788
  20. Dec 7, 2010 at 3:36 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
