5100 / 885x 2" of lift
Discussion in 'Suspension' started by darkstar85, Aug 23, 2012.
  1. Aug 23, 2012 at 7:37 AM
    darkstar85
    darkstar85 [OP] Member
    Hawthorne CA
    2012 DCLB SPORT 4X4
    20% tint Plasti dip badges, 5100/885x LR UCAs
    I have a 2012 4x4 DCLB Sport. I recently installed LR UCAs, 5100's with 885x at the 0 setting and acheived ~2" inches of lift. The truck has the factory 4 leaf springs in the rear so it sits dead level right now. I was hoping to get more lift with this setup without preloading the springs.
    Should I add a top spacer or preload to the .85 setting? (shooting for 2.5-2.75" of lift)
    I plan on using a block in the rear to match the front.
    thanks!
  2. Aug 23, 2012 at 7:43 AM
    98tacoma27
    Ben
    Not Beech Creek
    I'd just do the 13mm plate from Wheelers. It should get you 3/4 - 7/8"... and it's cheaper than the 10mm plate <--:crazy:
  3. Aug 23, 2012 at 8:06 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    AAL > Blocks for the rear
  4. Aug 23, 2012 at 8:07 AM
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    x2, you'll spend about the same on both, go with the aal
  5. Aug 23, 2012 at 8:09 AM
    98tacoma27
    Ben
    Not Beech Creek
    True but he is adding less than an inch to the front.
    Personally, I'd leave the rear alone.
  6. Aug 23, 2012 at 8:17 AM
    Pugga
    Massachusetts
    Oh, I misread. I thought he was getting the front set and then going to adjust the rear with blocks. I missed the part about it being level now. :eek:
    Blocks under 1" wouldn't really have any negative impact.
  7. Aug 23, 2012 at 8:43 AM
    darkstar85
    Hawthorne CA
    2012 DCLB SPORT 4X4
    Thanks for the input!
    Looks like ill go with the top spacers.. hopefully I don’t need to compensate for the "taco lean".
    I thought about the AAL but I don't need much lift. I will probably run .5" blocks in the rear or just leave it alone as Ben suggested.
