5100 and OME 885 install problems. HELP!!
Discussion in 'Suspension' started by jakeworthy, Oct 20, 2012.
  1. Oct 20, 2012 at 11:30 AM
    jakeworthy
    jakeworthy [OP] Well-Known Member
    Jake
    HB
    2019 DCLB
    Well right now I'm jut swapping out coils and Putin stock ones back on with new billies set at 1.75
  2. Oct 20, 2012 at 12:16 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    You should get a full 3" lift with the 885x's but they need to break in and settle. After install and setting it down on the ground it is going to be way up there until you drive around for a couple weeks. Double check all your part numbers, if everything is correct and you are still not happy, throw the stock coils on like you said.
  3. Oct 20, 2012 at 12:32 PM
    jakeworthy
    Jake
    HB
    2019 DCLB
    I put my stock ones on set at 1.75 buys still really high. About 3/4" Lower than it was when I had 885 set at 0" so looks like I need to set it lower. Still!
  4. Oct 20, 2012 at 12:36 PM
    jakeworthy
    Jake
    HB
    2019 DCLB
    And I can't find any number stamped on the coils. Just the 885 x sticker that was on them
  5. Oct 20, 2012 at 12:38 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    FYI OP , 885's , no top plate spacer lifted me 2 1/2" on my DCLB 4x4 , it hasn't settled at all in over a year and a half
  6. Oct 20, 2012 at 12:42 PM
    jakeworthy
    Jake
    HB
    2019 DCLB
    Thanks man. I think the 885s just much be a bit much for me. It would be perfect if I was getting 2.5 bu I'm getting like 4 :/
  7. Oct 20, 2012 at 12:46 PM
    OZ-T
    Peter North
    British Columbia
    Something is not right
  8. Oct 20, 2012 at 2:52 PM
    jakeworthy
    Jake
    HB
    2019 DCLB
    I don't know what it could beee
  9. Oct 20, 2012 at 4:46 PM
    jakeworthy
    Jake
    HB
    2019 DCLB
    Well. As of now I have her in the new billies set at 1.75 with stock coils. Giving me about 2 inches right now up front. Got a 1.5 AAL in rear. From is sittin about 1in lower than rear. Now I jut need to figure out if toytec will exchange these 885. Wht should I try next? 884? Or get some eibachs?
  10. Oct 20, 2012 at 4:47 PM
    TRD6Speed
    TRD6Speed senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
    something is fubar'd Patmac just put on 885x with a 1/2" top spacer......with 5100s......he got exactly 3" lift hub to fender. Exactly what Im doing too with an AC. Even if you're a prerunner you shouldnt get 4" from 885x. And if you are still real high with just the 5100s at 1.75 then thats not right either.
  11. Oct 20, 2012 at 5:03 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Did the other rubber bushing and washer get left out from under the top plate and the shock ? The boot has a little bit more thickness to add but not near what you are short.
    The rest looks correct. from what I can tell.
  12. Oct 20, 2012 at 5:05 PM
    jakeworthy
    Jake
    HB
    2019 DCLB
    Ok. Any insight to what the problem might be?
  13. Oct 20, 2012 at 5:06 PM
    jakeworthy
    Jake
    HB
    2019 DCLB
    Thanks man. And ya all the washers got put back on and the top parts are looking good now, it's just the rise height that's bugging me ha. Idk If the billies are stiff or what.
  14. Oct 20, 2012 at 5:07 PM
    jakeworthy
    Jake
    HB
    2019 DCLB
    And yes the second time around I got the boot/dust cover on.
  15. Oct 20, 2012 at 5:16 PM
    #35
    OZ-T
    Peter North
    British Columbia
    OP , what is your hub to fender measurment up front ?
  16. Oct 20, 2012 at 5:30 PM
    #36
    jakeworthy
    Jake
    HB
    2019 DCLB
    Right now right stock coils and billies set at 1.75?
    About 23 1/4
  17. Oct 20, 2012 at 5:31 PM
    #37
    OZ-T
    Peter North
    British Columbia
    Something is fucked up , at 1.75 you should be at 21 3/4 - 22
  18. Oct 20, 2012 at 5:33 PM
    #38
    ajohnson
    Andy
    Charlotte, NC
    X2 man. Something is not right. A 3" lift is about 23" hub to fender IIRC.
  19. Oct 20, 2012 at 5:38 PM
    #39
    jakeworthy
    Jake
    HB
    2019 DCLB
    ok. but do you guys see anyhting wrong with my setup? i followed that video, and the only thing i didn't do was the top washer under the top plate at first, but got that fixed. i dont know what else it could be? any more thoughts?
  20. Oct 20, 2012 at 5:40 PM
    #40
    OZ-T
    Peter North
    British Columbia
    For sure current coils are stock OEM ( Toyota ) coils ?
