5100 and OME 885 install problems. HELP!!
Discussion in 'Suspension' started by jakeworthy, Oct 20, 2012.
  1. Nov 3, 2012 at 6:48 PM
    #141
    jakeworthy
    jakeworthy [OP] Well-Known Member
    Jake
    Socal-HB
    05 Access Cab PreRunner
    anywayssss. So i think im going to order up those 884's. You guys recommend i dont put up my 885's for sale until i get my new ones in?
    What do you guys think about some 1.25 wheel spacers? i am liking the stance these give on trucks =)
  2. Nov 4, 2012 at 7:00 AM
    #142
    masshole taco
    masshole taco Well-Known Member
    Big Daddy
    Massachusetts
    2011 Tacoma Sport
    Fox 2.5 C/O's Fox 2.0 rear shocks Total Chaos UCA Trifecta Tonneau Cover K&N FIPK Sirius Satellite Radio Toyota OEM roof rack Wet Okole Seat Covers Homer Taco Custom Grill w/ M1 Mesh and Toyota Emblem
    a lot of people run spacers on the site..I say throw'em on and see how it sits with the 885's... YOu may like how it sits and it will save you time and money in selling the 885 and buying 884's... JMO.
  3. Nov 4, 2012 at 7:23 AM
    #143
    huntark03
    huntark03 I'd rather be hunting!
    Maumelle, AR
    2005 Limited Tundra DC 4X4
    Spidertrax Wheel Spacers aFe Pro Dry Drop in Air Filter Weathertech Liners Bilstein 5100s w/ OME 885 coils and ToyTec 1.5" AALs Light Racing UCAs
    I have some 884's that I am going to install to see what kind of lift they give me on my 03 Tundra. They might be for sale or trade for your 885s??
  4. Nov 4, 2012 at 1:17 PM
    #144
    jakeworthy
    Jake
    Socal-HB
    Spacers with my 885? No it's already too high, 884 would give me less lift then 885
  5. Nov 4, 2012 at 5:32 PM
    #145
    jakeworthy
    Jake
    Socal-HB
    Does the tundra use same as Tacoma?
  6. Nov 4, 2012 at 7:26 PM
    #146
    huntark03
    Maumelle, AR
    Yes...the Tacoma coil will work on the Tundra if a Tacoma spring isolator is used...
  7. Nov 5, 2012 at 7:33 AM
    #147
    masshole taco
    Big Daddy
    Massachusetts
    2011 Tacoma Sport
    LOL.. Spacers won't raise the height or suspension of your truck it will just push the wheels out a little bit and the height/stance of the truck may look okay when you do that.. I say put them on and put some pics up.. :cool:
  8. Nov 5, 2012 at 8:01 AM
    #148
    jakeworthy
    Jake
    Socal-HB
    Ohh you talking about wheel spacers. Just needed to be more specific I guess. I thought u ment like a spacer lift
  9. Nov 10, 2012 at 10:14 AM
    #149
    marcballz
    marcballz Well-Known Member
    Marc
    Mcallen,Texas
    08 PreRunner SR5 TRD
    Electrical: 24/7 aux pwr, cabin ac outlet, fog light on, 55 watt hids (5k), engine bay lights, dash color swap, led cab/footwell lights, Exterior: air compressor w/ dual tank & dual horns, toolbox, headache rack Audio: pioneer head unity 12" jbl sub , (4) db drive 6x9, 360 db amp, 600 dual amp
    hey if you sell your eibachs im looking for some so just let me know if you do swap them out :D
  10. Nov 17, 2012 at 12:16 PM
    #150
    jakeworthy
    Jake
    Socal-HB
    Well finally got the 884s. It's funny, taking them out of the box, they look almost identical to the 885s. I can't even tell a height difference. Installed them but have hadn't a chance to measure yet I see the difference in right height yet.
  11. Nov 17, 2012 at 12:33 PM
    #151
    jakeworthy
    Jake
    Socal-HB
    Matt- ill for sure let ya know and take some pics! Probably tomorrow
  12. Nov 18, 2012 at 11:20 AM
    #152
    jakeworthy
    Jake
    Socal-HB
    well, suprise suprise, the 884s are giving me almost the exact same lift as the 885s... they looked identical to me right out of the box.
  13. Nov 18, 2012 at 11:53 AM
    #153
    jakeworthy
    Jake
    Socal-HB
    no i dont. but i know its right. got the 5100 on the 0 setting, all bushings and washers in correct place, coil alligned correctly on the shock bottom plate part. not upsidedown or anything like that.
    (and i didn't do install like you, did the other method without coil compressor)
  14. Nov 18, 2012 at 12:19 PM
    #154
    jakeworthy
    Jake
    Socal-HB
    hmmm i dont really see why that would make a difference. im not going to go rent a coil compressor just to do it that way. that way scares me. i feel much safer doing it this way. so idk man.
  15. Nov 18, 2012 at 12:45 PM
    #155
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Something is not right
    again
  16. Nov 18, 2012 at 12:47 PM
    #156
    jakeworthy
    Jake
    Socal-HB
    coils were labled 884x on them. standing side my side the 885x they look the same, therefor giving me about the same lift.
  17. Nov 18, 2012 at 12:50 PM
    #157
    OZ-T
    Peter North
    British Columbia
    Something has to be wrong in the assembly for you to be getting a full inch more lift than anybody else
  18. Nov 18, 2012 at 1:00 PM
    #158
    OZ-T
    Peter North
    British Columbia
    Going back to the beginning , you seem way too high at this point ^^^
    The common denominator is the billies
  19. Nov 18, 2012 at 1:02 PM
    #159
    DrewH
    DrewH Well-Known Member
    The 885's should be 10mm longer than the 884's. You should get 3/4" - 1" more lift from the 885's.
  20. Nov 18, 2012 at 1:07 PM
    #160
    DrewH
    Truth.
    I'm at 22.5" with stock coils on Billies @ 1.75. What are the Part #'s on your 5100's?
