5100 and OME 885 install problems. HELP!!
Discussion in 'Suspension' started by jakeworthy, Oct 20, 2012.
  1. Nov 18, 2012 at 1:10 PM
    #161
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    or , the billies are set at one setting higher than the OP thinks in each case
  2. Nov 18, 2012 at 1:11 PM
    #162
    DrewH
    DrewH Well-Known Member
    Very possible.
  3. Nov 18, 2012 at 1:20 PM
    #163
    jakeworthy
    jakeworthy [OP] Well-Known Member
    Jake
    HB
    2019 DCLB
    i know for a fact they are on the 0 setting. lowest possibly. i have checked this too many times to count because everyone keeps saying that. shocks are part number# 24-186711
  4. Nov 18, 2012 at 1:23 PM
    #164
    DrewH
    You got me then. Do you have a top plate spacer installed?
  5. Nov 18, 2012 at 1:31 PM
    #165
    jakeworthy
    Jake
    HB
    2019 DCLB
    Just a 1/4 on driver side
  6. Nov 18, 2012 at 10:03 PM
    #166
    stattonmw
    stattonmw Well-Known Member
    Statton
    Redmond, WA
    2014 DCLB Tacoma TRDsport
    5" RCD Lift TOYO ATII Extreame 295/70R18 XD Addict wheels Factory toyota side steps TRD exhaust
    I really am taking a stab in the dark but are you a v6 or 4 cylnder??? Could be a huge difference.
  7. Nov 18, 2012 at 10:06 PM
    #167
    OZ-T
    Peter North
    British Columbia
    V6
  8. Nov 18, 2012 at 10:18 PM
    #168
    jakeworthy
    Jake
    HB
    2019 DCLB
    Yup. Prerunner
  9. Nov 20, 2012 at 10:09 AM
    #169
    Reeves
    Reeves Well-Known Member
    Colorado Springs, CO
    08 TRD Rugged Trail
    Drive it a few days, they will settle
  10. Nov 22, 2012 at 8:05 PM
    #170
    tommytacoma
    tommytacoma MEMBER
    Tommy
    New Jersey
    2005 Toyota Tacoma TRD Off-Road
    -Bilstein 5100's all around, OME 885's, Toytec 2inch AAL, Toytec 1/2 top spacer -265/75/16 General Grabber AT2 Tires -Gibson Exhaust -K&N Intake -Front lightbar with KC Off-Roaders -Throttle Body Spacer -Wires and plugs -Stereo
    I just ordered this setup for my 05' TRD off-road v-6 double cab. Should I have gone with 885's instead of 884's (no heavy bumper or added weight). I'm doing a 2 inch Toytec AAL in the rear with 5100's all around. I have a 3 inch Revtek spacer/block lift now. I would like my truck to sit a little higher with the new lift. What do I have to set my front at to sit level with the back. Was glad to find this thread b/c everyone sounds very knowledgable about this topic. Thanks everyone.
  11. Jan 25, 2013 at 12:29 PM
    #171
    Gabassman
    Gabassman Drive it like a 4WD
    Tyler
    Georgia
    Did thus guy ever figure this out?
  12. Feb 5, 2013 at 6:19 AM
    #172
    dtopgun515
    dtopgun515 Well-Known Member
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    5100's up front set to 1.75, SCS Stealth 6 wheels, Nitto Terra Grappler AT's
    OP when you put your 5100's on at the 1.75 setting with stock coils did you still have the problem of not being able to tighten the top screw down because the shaft seemed to long? My truck is in the shop right now and they have assembled mine more than once but the bolt on the top of the shaft can't be tightened. I'm currently in a holding mood cause I don't and they don't really know what to do. From factory there is a washer, then the top plate, then rubber boot, then washer, then screw. Should I need to add anything or am I missing something? They said those were the parts that came off and what went back on. The top sleeve is also on the shock. This is the thread I started if anyone can help me....
    http://www.tacomaworld.com/forum/suspension/261637-5100-cant-tighten-top-bolt-shaft.html#post6388396
  13. Apr 30, 2013 at 6:52 PM
    #173
    hakabo
    hakabo Well-Known Member
    Jacob
    Concord, NC
    08 urban runner 4x4
    im looking at doing the 885x on 5100s and this thread scares me. it appears this is a one in a million issue but was it ever resolved?
  14. Apr 30, 2013 at 6:56 PM
    #174
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    I've got a set of 885s I plan on installing with 5100s.
