5100 and tire size
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bamahoyt, Nov 1, 2010.
  1. Nov 1, 2010 at 8:41 PM
    Bamahoyt
    Bamahoyt [OP] Well-Known Member
    Ted
    Knoxville, TN
    2014 TRD Sport DC LB 4x4
    I just put on some 5100's in front and set them at 1.75 and I don't have anything in the rear. My question what tire size would be a good upgrade over 265/65/17's? I want to go bigger for sure but only want all terrains unless I got a steal on Muds. Also I am thinking about putting a 1 inch AAL in the rear and stepping the front up to 2.5. would give me some tire sizes if I did that. thanks for the help
  2. Nov 1, 2010 at 10:36 PM
    squamish VFR
    squamish VFR Well-Known Member
    Squamish B.C. Canada
    '06 tacoma 4door shortbox
    Bilsteins set at 2.5" OME Dakar rear leaf packs, FJ manual TC conversion, basket winch front and rear, hidden hitch in the front behind licence plate. Spyder headlights, tailgate seals.
    I went Billies all the way around. I found that the rear shocks were topping out even that they were a longer shock. (OME Dakar leaf packs) I made my own shock extensions. I set my fronts to 2.5" due to higher than expected lift in the rear. I run 285 70 17's but I wish I had choosen 285 65 17. Minor rubbing of the front of the wheel wells with FJ cruiser rims but I found out that if you hit the plastic with a heat gun it shrinks, making it easy to direct in the areas that rub. I have my 16" OEM rims P/C black with snowtires and wheel spacers for clearance for tire chains for the winter time only.
    Hope that helps.
  3. Nov 1, 2010 at 10:41 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    I'm currently running 265/70/17 with no lift / no rub . I'm not sure you will clear 285's at only 1.75 " up front .
    Edit : Sorry OP I misread that you are thinking of going up to 2.5 " in the front . My Bad .
  4. Nov 16, 2010 at 6:22 PM
    Bamahoyt
    Ted
    Knoxville, TN
    Think I could get 285/65/17's to clear without rub with my fronts set at 1.75?
  5. Nov 16, 2010 at 7:56 PM
    OZ-T
    Peter North
    British Columbia
    I doubt it , not without trimming .
  6. Nov 17, 2010 at 5:40 AM
    Bamahoyt
    Ted
    Knoxville, TN
    Would the next size down be 265/70/17's then?
  7. Nov 17, 2010 at 6:30 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Correct. That's the next (common) size down.
  8. Nov 17, 2010 at 9:17 AM
    kessler89
    kessler89 Well-Known Member
    OH
    12' Pro4x 6MT
    TBA
    i have 265/70/17 AT's on mine with nothing done to the rear and 5100's set at 1.75 on the front, i think it looks about perfect but i'm putting a winch bumper on, that's the reason i went 1.75, glad i did cause i dont really think it looks all that front high as it is right now
  9. Nov 17, 2010 at 10:45 AM
    trd09
    trd09 Well-Known Member
    Chuck
    NW Ark
    17 TRD Pro 6AT
    have the same setup, 265/70/17 with 5100s at 2.5 and rear tsb. sits real nice
  10. Nov 17, 2010 at 6:50 PM
    squamish VFR
    I think if they rubbed at 1.75 it would be minor, I wish I'd gone with that tire size. Do the lift and get the tire shop to hang a tire on it and see, most will accomodate you when you're poised to drop $1000.
    Just my $.02
    I'm out
    Sq
  11. Nov 17, 2010 at 6:56 PM
    OZ-T
    Peter North
    British Columbia
    FWIW , the pic of my truck I posted at the beginning of the thread is on 265/70/17 MT's with no front lift and the ( TSB ) 4 leaf pack in the rear .
  12. Nov 23, 2010 at 11:52 PM
    kram
    kram Well-Known Member
    Squamish, British Columbia
    09 TRD Offroad Access Cab 6spd MGM
    URD Short Shifter TSB Leaf Pack, Bilstein 5100s front (1.75") and rear. 285/70/17 Duratrac on Rhino Sidewinders. Weathertech Digifit Floormats
    I have 285/70/17 Duratracs on rims with 4.5in BS with a 1.5in spacer lift that came with the truck. I have ordered the 5100's and am in the process of trying to decide what setting to use. After spending 4 hours on here, I have decided to go with 1.75. I had to trim quite a lot of plastic and I also took the angle grinder with a sanding disc to the cab mounts to round them off very slightly. I haven't rubbed at all yet, but only done some minor dirt road driving so far. So I think this will only improve with the extra 1/4in I'll get with the 5100s. But if I do find that I rub the cab mounts I will have not problem going ahead with the chop.
    A bit OT, but the reason I decided (for now) to go with 1.75 is because I don't want the ride to be too harsh and 2.5 will definitely be firmer. I also don't want vibes or alignment hassles and I could do without extra wear on the CV boot. I also didn't want to add more expense and firm up the rear any more by having to AAL to keep it level. The fact that I can avoid all that and still fit 33s with no problem, I think it's a good choice and I think it already looks awesome. If money was no object, I would have gone Icons with UCAs and a leaf pack, but the extra $2K in my perspective is better spent on mountain bikes and ski resort tickets.
    Here's a pic so you can get an idea of about that amount of lift with 33s
  13. Nov 24, 2010 at 7:56 PM
    squamish VFR
    When I did my 5100 lift to 2.5" I found right away that I got a noise, (whomp womp womp) that I'm 99% sure is coming from the LH inner CV joint. I fabbed up my own 1" diff drop kit and that has reduced the issue and I think I'll run it until the CV is NFG and live with the noise. I'm considering at some point (maybe when I get new tires in a couple years 285 65 17 to lower it to 1.75" and get a bit more improvement. My truck has over 100,000Km on it so newer shafts may not see this noise. If anyone is doing this work on a high miler you might as well toss in new wheel bearings while you're in there, mine weren't shot but well on their way to being so. I also would recommend getting bearings withthe hub already installed to make the job easy. Plain bearings are a PITA unless you have the ability to fab up jigs to hold and press the hub out.
  14. Nov 24, 2010 at 9:51 PM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    1.75" front with TSB rear...I have 265/70/17 and they fit perfectly. No rub and gives the truck a great look - not too high but high enough (like me :D).
    I have the Bridgestone Dueler A/T Revo 2:
  15. Nov 25, 2010 at 7:52 AM
    Bryan07sport
    Bryan07sport Well-Known Member
    Bryan
    Smyrna, Delaware
    '22 TRD off-road.
    Bilstein 6112/5100. Icon progressive AAL. Overland Torque Tune. Toyota roof rack. Toyota bed extender. Gator trifold tonneau. Bora .75" wheel spacers. 265/75r16 tires.
    5100s at 1.75, Rear TSB, 265/70/17. No rub, but wouldn't go any bigger. Hope it helps.
  16. Nov 25, 2010 at 8:07 AM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    What is the diffrence in the 75 to 70???
  17. Nov 25, 2010 at 8:25 AM
    TexasTacoma37
    For 265's, it 's about 1" in diameter difference.
