5100 Bilstein fit on stock rear suspension?
Discussion in '1st Gen. Tacomas (1995-2004)' started by chriswh86, Nov 24, 2014.
  1. Nov 24, 2014 at 5:05 PM
    chriswh86
    chriswh86 [OP] Active Member
    Northern Vancouver Island, BC
    Hey all,
    I recently broke a rear shock and called up a shop for some alternative shocks to install into my truck that are a bit more heavy duty.
    I now have Bilstein 5100 series shocks in my possession and installed one on the drivers side rear. Install was simple obviously but I have run into an issue with the shock body only being a couple inches or so from bottoming out the shock shaft. I came here and I am getting the vib that the 5100 series shocks are for a slightly lifted truck if I am correct? I hear that the shock mounts differ by .5" as well, could I have two slightly different 5100 series shocks and I put the wrong one on the drivers side?
    I have been wanting to put new front springs in as they are very soft and collapse over minor bumps.
    I am also thinking of a small lift if I go ahead and get new 5100's for the front along with new springs and maybe an AAL setup for the rear? Would this be the best bet for the truck. I dont want to raise the truck up to much, enough to fit the 5100's on the back, maybe 1"? and match the front 1". Are there any issues I would run into with the AAL and 5100's and springs on the front? New shackles, brake line modifications?
    So basically, am I correct in that the 5100's are for a lifted truck. If so, is an AAL a good idea for the rear and if so, is 1" enough in the rear for the 5100's to work?
    Truck see's logging roads and some basic trails
    Chris,
  2. Nov 26, 2014 at 9:30 AM
    copacetic1
    copacetic1 Don't get stuck on stupid.
    Colorado
    03 SR5 4X4 Dbl Cab
    Front: Bilstien 5100 / OME 880 Rear: Bilstein 5125 / Wheeler 5-leaf
    My understanding is 5100s are for lifted applications, 5125s are for stock height. I recently put 5125s on my 2003 along with new leaf springs and have 5100 and OME 880s coils for the front in the garage waiting to get put on. With the new springs front and rear I'm expecting a slight lift once everything is on and broke in. This note is from Downsouth Motorsports site for info on the 5125 rear shocks in their 5100 front/5125 rear package: "NOTE: This shock set up is recommended for vehicles with no lift, or stock height in the rear. The collapsed dimensions are shorter than the 5100 rear shocks. Driver Side 8" Travel: Ext. 21.54" Col. 13.58" Pass. Side 8.5" Travel: Ext. 22.5" Col. 14.06".
  3. Nov 26, 2014 at 9:44 AM
    McPhiiil
    McPhiiil Member
    Indiana
    2015 AC Taco SR5
  4. Nov 26, 2014 at 2:00 PM
    chriswh86
    Are these the extended and collapsed measurements for the truck or the shocks? And what is Non-TSB?
    Cheers!
  5. Dec 9, 2014 at 10:00 PM
    chriswh86
    I have got these model numbers of Bilstein 5100 series
    BE5 D560 TO
    BE5 D559 TO
    I am wondering if anyone has the collapsed and extended lengths of these shocks? I cant find them on the Bilstein site.
    Also, is there a standard compress/extended shock length in the trucks? I measured the other day and would like to compare to what it was from factory if possible?
  6. Dec 10, 2014 at 1:02 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Don't use the PN's that McPhiiil gave, while he is partially right, those are for 2nd gen tacomas.
    Call DSM. they will get your the correct length 5100. normal ones are in fact TOO long for a truck that isn't lifted. DSM will hook you up or even just answer your questions. i used to know the PNs and travel numbers..but i have long since forgotten :eek: sorry.
    5100s/5125s are the same shock. Just different lengths are available.
    an AAL will work fine with the normal 5100s. That said, increasing the bump stop height will make them last longer.
  7. Dec 10, 2014 at 11:09 AM
    chriswh86
    I will contact them and see what they can come up with :)
    What is the best way to test the measurements of my truck? Best, safest way to articulate the rear end to get accurate shock mount measurements?
  8. Dec 10, 2014 at 1:03 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    If you have access to a forklift, that is the easiest way I have found.
  9. Dec 10, 2014 at 1:12 PM
    chriswh86
    If I add a progressive AAL 1.5" lift in the back, follow it up with a Bilstein 5100 1.5" lift in the front with new springs will I need to extend any brake lines etc? Any other work aside from the AAL and struts?
    Here are the shock lengths I got from RCD.
    F4-BE5-D559-T0 Collapse 13.93” Extended 21.63” (Drivers Side)
    F4-BE5-D560-T0 Collapse 14.65” Extended 22.57” (Passenger Side)
  10. Dec 10, 2014 at 1:17 PM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    I'll just add that while they look the same and are essentially designed the same the valving is actaully noticeably different. The 5100s are vehicle specific and the 5125s are not. Blackdawg I'm pretty sure you are aware of this, I just wanted to add this info so folks here are aware.
    In terms of ride, the 5125s make for a stiffer ride whereas the 5100s ride quite a bit better.
  11. Dec 10, 2014 at 1:31 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Hmm... I wonder about whether this is true or whether it is an urban legend.
    Below is a quote from DSM on this topic from a couple of years ago. I will acknowledge that things may have changed since then. However, I came to trust what Marco had to say. YMMV
    edit: Here is the source thread.
    http://www.tacomaworld.com/forum/suspension/224363-there-difference.html
  12. Dec 10, 2014 at 11:40 PM
    chriswh86
    Any other method aside from a fork lift? I have the wheelers bump stops coming. After they get put in id like to measure the shock eyes but i have no access to a fork lift
  13. Dec 11, 2014 at 10:46 AM
    Mr Salty
    Hermmy
    Lots of chrome
    look at my post again, I'm talking about the difference between 5100 and 5125, not 5100 and 5100 with an RCD label.
    5100 when compared to 5125 are valved different, this is a fact and I have felt the difference myself doing a manual compression test. Anyone who says the valving is the same or they feel the same has no idea what they are talking about.
  14. Dec 11, 2014 at 12:44 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Which stops did you end up ordering from wheelers?....curious...
  15. Dec 11, 2014 at 12:47 PM
    Digiratus
    Roaming the PNW
    The RedHead
    There are only the two types. There are RCD/Bilsteins, what folks on TW as 5100's and there are Bilstein 5100 series, which include 5125s. So 5125s are 5100s. :D
    In Marco's DSM post, it was these two types of shocks he was referring to and it was what the thread was about.
  16. Dec 11, 2014 at 4:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea 5100/5125/5150 are all basically the same.
    5100s come in limited lengths.
    5125s come in lots of lengths
    5150s come in lots of lengths and valving types...or did..they are discontinued now. now 5160s do this and 5125s i believe come in a couple different valvings now
    the RCD 5100s are barely any different. Different? yes..but not by much, not a drastic amount.
  17. Dec 11, 2014 at 8:01 PM
    chriswh86
    Those are the ones I ordered.
  18. Dec 11, 2014 at 8:02 PM
    Mr Salty
    Hermmy
    Lots of chrome
    Put it this way man, if Marco from DSM says the 5100 and 5125 shocks are the same as far as valving goes he's wrong. The whole reason why I chimed in was to inform folks that if they get the 5125 shocks as an alternate to the 5100 shocks the ride will not be the same, the 5125 shocks ride stiffer. As mentioned before I know this because I have done a side-by-side test comparing the two.
  19. Dec 11, 2014 at 8:02 PM
    chriswh86
    any ideas what the stock toyota shock to shock mount lengths are compressed and extended?
  20. Dec 11, 2014 at 8:09 PM
    Mr Salty
    Hermmy
    Lots of chrome
    I would disagree and say the two (5100 & 5125) are noticeably different, but that's just my opinion based on my own compression and rebound testing.
