5100 down travel at full lift
Discussion in 'Suspension' started by 86ceeten, Jan 7, 2010.
  1. Jan 7, 2010 at 5:28 PM
    86ceeten
    86ceeten [OP] Well-Known Member
    Brian
    NW Florida
    08 TRD Off Road PreRunner
    Limo tint, 18x10 Diamo Karat, Toyo 285-60's, Rear TSB, 5100's all around, front at 2.5", Debadged, Sound System (evolving)
    Been researching lifts and was about ready to (back)order a set of 5100s but I have a question. At full the lift setting will the shocks be topped out, as in no "droop"? If so I would imagine a rough ride, like a truck with maxed out torsion bars.
    Thanks!
  2. Jan 7, 2010 at 5:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    At the max lift, there is still a couple of inches down travle with the stock UCA's.
  3. Jan 7, 2010 at 5:47 PM
    86ceeten
    Brian
    NW Florida
    Cool. So maybe it's not too bad. Another question, can a top plate spacer be added to get a full 3 inch lift? Gonna be running 285-60-18's on 18x10's with 5"bs. I know it's gonna be tight.
  4. Jan 7, 2010 at 5:50 PM
    86ceeten
    Brian
    NW Florida
  5. Jan 7, 2010 at 6:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont think that will work with that offset. Maybe if you get some different UCA's. Im running the same zize, and with a 4.57" BS wheel, I had about 1/8" clearance from the sidewall of the tire to the UCA.
  6. Jan 7, 2010 at 7:10 PM
    86ceeten
    Brian
    NW Florida
    That's weird. I am running 285-50-20 now on 20x9's with 5.7 bs and have plenty of room. I hope they fit, the new wheels are in the garage still in the box.
  7. Jan 7, 2010 at 7:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hmm....That is kinda strange.
  8. Jan 7, 2010 at 7:17 PM
    86ceeten
    Brian
    NW Florida
    Now I'm worried. Gonna bolt one up tomorrow and take some measurements.
  9. Jan 8, 2010 at 10:19 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Maybe because they are 20" s. Puts the rim further away, axially speaking?
    :notsure:
  10. Jan 8, 2010 at 12:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It could be....I dont know much about the wheel thing....:eek:
  11. Jan 8, 2010 at 12:27 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    :goingcrazy:
  12. Jan 11, 2010 at 4:43 PM
    86ceeten
    Brian
    NW Florida
    Pulled a wheel today and did some measuring. My current wheels are 20x9 and measured 5.75 backspacing. with 285-50's I could fit my hand between the tire and UCA. My new wheels are 18x10 amd measured 5" backspacing. I clamped a aluminum bar to the inside wheel edge and have about 1 3/8" of clearance to the UCA. My current 285's stick out 5/8" past the wheel. So I should be fine. I will probably need to trim fenders but the UCA should clear.
