5100 Help - Not level from Passenger to Driver
Discussion in 'Suspension' started by magnatacoma, Apr 3, 2016.
  1. Apr 8, 2016 at 5:04 PM
    #61
    Stags863
    Stags863 Bye Felica!
    Florida
    2014 DCSB TRD Off Road 4x4
    - Bilstein 5100's set at 1.75 - 265/70/r17 Goodyear Wrangler Authorities - 6000k headlight and fog light bulbs - NiLight off road LED rear lights - Light bar mounted behind front bumper - White LEDs in dome, map, and sun visor - Tint (5% around / 35% front) - Universal 13 inch metal antenna - Beer bottle opener in bed - Organizer storage box in center console and glove compartment - Mounted MagLite to top of center console storage box - MGM grille - MGM rear bumper - CamLocker toolbox - Rubber floor mats - 2 USB and Cig lighter chargers in rear of center console - Headrest mounted iPad holders for rear seats
    Are you 100% sure the coils you bought were stock oem coils?
  2. Apr 8, 2016 at 5:04 PM
    #62
    magnatacoma
    magnatacoma [OP] Well-Known Member
    East TN
    11 Tacoma DC TRD OR
    AFE Stage 2 si, OEM Roof Rack, Raptor 4" Oval Steps, 15% Tint all around Skyjacker Leaf Springs, Bilstein 5100's all around, Eibach Springs
    Stags863 what are your hub to fender measurements?
  3. Apr 8, 2016 at 5:04 PM
    #63
    T4RFTMFW
    T4RFTMFW Well-Known Member
    No expert diagnosis?
    You've already ruled out everything incorrectly.
  4. Apr 8, 2016 at 5:06 PM
    #64
    magnatacoma
    East TN
    11 Tacoma DC TRD OR
    May start with sway bar. They came loosely attached to a tacoma strut however I don't know for absolute sure. They have no colored paint stripe at all. They are just black.
  5. Apr 8, 2016 at 5:10 PM
    #65
    Stags863
    Florida
    There are several other things that could be checked. The coils that were purchased may not be stock oem springs. No color scheme on them. From the pics the sway bar is missing. Don't really think that could be the problem but I'd put it back on to see if it makes any difference? Where's your "diagnosis" at to try and help the OP? Oh that's right. I don't see one.
  6. Apr 8, 2016 at 5:13 PM
    #66
    Stags863
    Florida
    Are they set on the second one up from the bottom or the third? Second would be .85 and third would be 1.75.
  7. Apr 8, 2016 at 5:13 PM
    #67
    magnatacoma
    East TN
    11 Tacoma DC TRD OR
    I took the sway bar out for this install to give me more room. I will try the sway bar first. Thanks everyone for your help in this. I'm about out of ideas.
  8. Apr 8, 2016 at 5:14 PM
    #68
    magnatacoma
    East TN
    11 Tacoma DC TRD OR
    They are set on the third one up. There is only one snap ring location showing above the bottom spring mount.
  9. Apr 8, 2016 at 5:18 PM
    #69
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    Is the passenger side suspension articulating correctly or does it seem to be bound up?
  10. Apr 8, 2016 at 5:19 PM
    #70
    magnatacoma
    East TN
    11 Tacoma DC TRD OR
    I'll have to check it again tomorrow but on a quick test drive to see if the height would settle the truck felt good and rode smooth.
  11. Apr 8, 2016 at 5:20 PM
    #71
    T4RFTMFW
    Did you measure before they were installed?
  12. Apr 8, 2016 at 5:21 PM
    #72
    magnatacoma
    East TN
    11 Tacoma DC TRD OR
    Do the above numbers seem right other than the Front Passenger? Bilsteins set at 1.75 and Skyjacker 1.5 - 2.0 inch lift springs.
  13. Apr 8, 2016 at 5:22 PM
    #73
    magnatacoma
    East TN
    11 Tacoma DC TRD OR
    No I didn't measure before install. I still have the assembled struts that I may put back in and measure if the sway bar doesn't level it up.
  14. Apr 8, 2016 at 5:31 PM
    #74
    Stags863
    Florida
    From the ground to the top of the wheel well in the front on both sides I'm measuring 37 1/4 inches on the driver side and just a hair over 37 1/4 on the passenger side. That's measuring from the middle of the wheel. Now I do have 1/2 inch shims in the rear on both sides so it may make a slight difference in the front but it should be a pretty close comparable measurement for you to compare to.
  15. Apr 8, 2016 at 5:33 PM
    #75
    T4RFTMFW
    No.
    Ground to fender is not the way to measure.
    You need to measure from the center of the hub to the fender to actually know what lift height you have.
  16. Apr 8, 2016 at 5:47 PM
    #76
    Stags863
    Florida
    Gotcha. Makes sense. I'll re-measure in the AM.
    T4RFTMFW[QUOTED] likes this.
  17. Apr 9, 2016 at 12:10 PM
    #77
    magnatacoma
    East TN
    11 Tacoma DC TRD OR
    Update: Parked truck on level ground and loosened and tightened rear leaf spring bolts to make sure those weren't hosing me. Put old struts in along with the sway bar this time. I'm back to within 1/4 from left to right on both the front and rear. I'm not for sure now if the new/used springs are at fault, the rear end was a little out and is now back, or the sway bar actually makes that much difference. So the next course of action is to take the old back out and try the new with the sway bar. Also verified without a shadow of doubt that the 5100's are set up correctly on the 1.75 notch. Thanks again for all yalls help. I'll keep updating until my truck is right again.
  18. Apr 9, 2016 at 4:26 PM
    #78
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    Yeah, might have been easier to put the sway bar on first with the new struts before swapping them out to see, but I think that's your next move. New struts with sway bar and see how it sits.
  19. Apr 30, 2016 at 1:56 PM
    #79
    magnatacoma
    East TN
    11 Tacoma DC TRD OR
    Final update: ordered some eibachs and installed them. I was within 1/4 inch afterwards. Already been lined up and driving it around. It rides awesome. Thank you all for your help.
