5100 help vibrations!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by countryboy22, Oct 24, 2009.
  1. Oct 24, 2009 at 11:28 AM
    countryboy22
    countryboy22 [OP] Well-Known Member
    Arizona Mountains
    05 SR5 4x4
    TRD cold air intake, Bilstein 5100's @ 2.5, Toytec 1.5" aal w/rear bilsteins. MBRP tip, Flowmaster Delta Flow 50 series, Toytec axle shims and carrier bearing drop.
    so i jus installed 5100's on all four corners and set the fronts at 2.5" i also installed a 2" aal in the rear. I took it in and had it aligned but I am still getting a vibration i am not sure where its coming from but i think it may be the driveline. i feel it most when i am accelerating or slowing down. I was wondering if anyone on here has had this issue and what they did or had to do to fix it thanks.
  2. Oct 24, 2009 at 11:31 AM
    TexasIslandBoy
    TexasIslandBoy THE RED DRAGON!!
    Andrew
    South Texas. SPI
    07' trd offroad 4X4 (For Sale)
    pro comp 6inch lift 35'' tires moto 950's radfo coilovers magnaflow exhaust 5/16" front skidplate usa spec ipod interface tree pin strip mod dry drop in filter full size BFG KM2 spare
    have you got your tires looked at they could have knocked a weight off
  3. Oct 24, 2009 at 11:32 AM
    countryboy22
    Arizona Mountains
    05 SR5 4x4
    no i havent but it doesnt feel like its coming from the tires.
  4. Oct 24, 2009 at 11:33 AM
    Spootypuff
    Spootypuff Well-Known Member
    Jacksonville, FL
    SWB Sport Double Cab SB 4x4
    Satoshi
    Search for lift vibration
  5. Oct 24, 2009 at 12:06 PM
    Jimirich
    Jimirich Well-Known Member
    Hawaii
    08 4x4 Dbl cab shorty O.R. pkg
    DTRL, Debadged, Donkey tethered in the bed that rips 142 db farts so I can piss off the neighbors and rattle the windows on my house when I'm parked in front.
    x2
    After lift Vibration between 5-9 mph while accelerating:
    Had it-freaked out-searched it-tried to fix it-accepted it was a nebulous prospect-gave up and currently live with it as do hundreds of million gazillion other lifted taco owners.
  6. Oct 24, 2009 at 1:17 PM
    Good351
    Good351 Well-Known Member
    Ames, IA
    03 4Runner V8
    Probably your rear driveshaft. I had the same vibration, ended up taking the aal off. Vibration went away.
  7. Oct 24, 2009 at 2:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You can get some axel shims for the rear to correct the vibe IF its comming from the rear, and not the tires. You feel rear vibes in the seat.
  8. Oct 24, 2009 at 2:18 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    The low speed vibration is usually driveline angle. Shims will adjust the angle hopefully in the correct direction. If it gets worse you may have put them in backwards.
    If it is around 60 mph it tends to be tire ballance.
  9. Oct 24, 2009 at 2:20 PM
    aces2
    aces2 Senior Arshole
    Cody
    Hampton, VA
    08 SR5 RR AC 4x4
    Flowmaster 40, K&N CAI, RED brake light bulbs, BHLM, Rear dif breather line, Factory Skidplate painted BLACK, DRL's, YELLOW bulbs in Fogs Turn Signals and Marker lights, Custom "Toy Machine" center emblem, Sockmonkey "Nor-Cal" decals all BLACK, Redline tailgate damper and hood sruts, Painted steering wheel emblem BLACK, 12V always on, Foglight mod, 16" Pro-Comp 7089 rims BLACK powdercoated acorn lugnuts, BFG KM2's 285-75-16, Painted exhaust pipe BLACK, BLACK emblems all the way around, Rear BLACK bumper from base model, Radical RED "sport" grille-surround, Factory Toyota Bed extender, RED maglight mounted on each seat's side, TRD ball-type shift knob, Custom mounted Scangauge II under stereo, Aftermarket HU, Hardwired Garmin GPS 260W, TSB w/AAL and 2.5" 5100's, Weathertech floor liners, Removed front mud flaps, 95-04 "4WD" rear mudflaps, 3rd Brake light "TACO", BLACK front lip
    I just did the same set up man and have a vibration from 45-65ish, it's in the steering wheel bad. The crazy thing is, about 25% of the time the vibe is 100% gone.
    I have seen a driveshaft coupling part of some sort on ebay sold from a guy who SWEARS that his part he's selling WILL 100% fix this vibe, I just am not going to take the chance.
    Another thing is the tire balancing like stated above. I would rotate to see if it helped, but when I just put on the lift I did a fresh rotation also. So I might just deal with the vibe for a full 5,000 miles.
  10. Oct 24, 2009 at 6:28 PM
    Agent7
    Agent7 Senior Executive of Nothing.
    Toronto, Canada
    07 Tacoma TRD Sport 4x4 6spd
    BHLM, Stubby Antenna, Custom Front Grill, Debaged Tailgate, Added TRD Emblem, Removed Factory Pinstripes, Leer 100XL Cap, Prolumen 6000K HID Kit with custom glare shields, Eurolite Yellow fog lights, 20" Fast Hustler wheels (black w/3" deepdish polished lip), Cooper Zeon LTZ 275/60/20's, Spidertrax 1.25" Wheel Spacers, Custom LED Gauges, Pioneer AVIC F700BT All-In-One Indash Navigation (Hacked)
    My vibrations got better over time.... cause I don't care about them anymore. :)
  11. Oct 24, 2009 at 6:58 PM
    Edrin55
    Edrin55 Well-Known Member
    Ron
    Chula Vista, CA (Eastlake)
    2010 Magnetic Gray TRD Sport Access Cab
    Avid Off Road Light Bar Line-X'd, Black Sand Pearl Hood Scoope, Truck Covers USA metal roll up bed cover, Thule Custom lockable light bar, TRD Sport Exhaust, Line-X'd TRD skid plate, Slee Off Road Sliders, Upgraded 3.5" Rearview Mirror/Monitor, Anytime Foglight Mod. (TY Jeff), Smoked Foglights, SilverStar Headlight & Foglight Bulbs, Tinted windows all around, Vent visors, Bed mat with security mod, Wet Okoles front & back, Race/Sport Pedals, Tailgate Clamps, PopNLcok 5300 Tailgate Lock, All weather mats, Helo 17x8 Hubcentric Rims & BFG All Terrain 265/70/17, Blisteins 5100's all around with mini leaf add to the rears, AFE Pro Dry drop in filter, Go Rhino Hitch Step, TRD License Plate Frames and Tire Valve Covers. GrillCraft MX Mesh upper and lower grills with "old school TOYOTA" FJ emblem, Cobra CB Radio, Firestick CB Antenna with custom mount.
    I had the same problems when I had my lift installed. It was the tires. They needed to be rebalanced. Shimming and vibrations are now gone.
  12. Oct 24, 2009 at 7:19 PM
    countryboy22
    Arizona Mountains
    05 SR5 4x4
    ya i just ordered the carrier bearing drop and axle shims hope it fixes it i will let ya know. i still running the same tires and wheels as i was before the lift. i got the vibes when i put the aal in. is it going to ruin my truck to drive it until i get the parts??
  13. Oct 24, 2009 at 8:04 PM
    aces2
    Cody
    Hampton, VA
    08 SR5 RR AC 4x4
    So you're saying you had a shimmy that shook the steering wheel back and forth in your hands at certain speeds?
  14. Oct 24, 2009 at 8:08 PM
    Edrin55
    Ron
    Yuppers.... as soon as I would hit about 50mph to 65mph. A tire rotation and rebalancing took care of it. I know mine were new tires, but they balanced them using different weights the 2nd time.
  15. Oct 24, 2009 at 8:10 PM
    aces2
    Cody
    Hampton, VA
    08 SR5 RR AC 4x4
    and now it's all the way gone? no more vibes at all?!
  16. Oct 24, 2009 at 8:13 PM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    2021 TRD Off-Road 2wd Cement Grey
    Bilstein 6112/5160 set at notch 2/3, OEM TRD Pro Wheels, 275/70/17 Falken Wildpeaks, OEM TRD Pro Grill, Debadged, Ceramic Tinted Windows
    why is it when people get an aftermarket rear lift they get a vibe, most of the time, but the TSB springs don't cause this problem. Neither did the deavers on my old taco. The leaf springs should be designed to give the correct angle for the drive shaft
  17. Oct 24, 2009 at 8:21 PM
    testedone
    testedone Speak English..it's America
    Rick
    U.S.A.
    2010 Tacoma TRD Sport
    Weathertec Mats, Pioneer AVIC-X930BT, Pioneer GEX-P920XM (SAT), Pioneer Premier TS-D602P 6.2, Blaupunkt THb 200A Sub, Trimmed Mud Flaps, BF Goodrich AT/KO 285/70/17 ... Toytec Ultimate Lift, Tuffy Bed Box, A.R.E. Cover, Pop-n-Lock, TRD Exhaust
    yeah I installed the toytec 1.5 AAL ( I do not have the TSB installed) and I also put the shims in while I had it apart..I have some small vibration, I might take the shims out and see if the vibe goes away..I only have 1.5 inches of lift!
  18. Oct 28, 2009 at 12:51 PM
    SamSter0077
    SamSter0077 Happy Camper
    Katy, TX
    09 Tacoma 4x4 TRD OR
    OME 886 Coils, and Struts, Rear Toytec TSB AAL/ OME shock absorbers, Fog Lamp anytime mod, Voyager Brake Controller.
    I have a very slight vibration under hard acceleration in the PEDAL after installing TSB AAL from toytec. I did the front first, and it has it's own set of issues, going to correct with new UCA. the back is 39" high now, and it Vibrates a little.. stock tires, 5,000 miles on them. Going to try the Carrier Bearing Shims first, will let you know if it works for me.
  19. Oct 28, 2009 at 1:00 PM
    testedone
    Rick
    U.S.A.
    I tried CB shims (1/4 inch) and I did not notice any difference. With my rear shims removed, it seems that the vibration moved to a different rpm/speed area, instead of the vibration at 5-10 mph, it now happens at 15-20 mph, same intensity which is really minor...??
  20. Oct 28, 2009 at 1:02 PM
    SamSter0077
    Katy, TX
    sounds like you need to go the other way.. :) Take them off, no TSB, and how much lift in the back. Sounds like you should not need anything to me.. But I am not the expert.
