5100 help!!!
Discussion in 'Suspension' started by binx61904, Jun 21, 2012.
  1. Jun 21, 2012 at 8:32 PM
    binx61904
    binx61904 [OP] Member
    Micah
    SOCAL
    12 White / Gray DC
    watch dog bhlm btlm tint debadged 3" toyo open country fake ass bead locks
    So I installed my adjustable 5100s and clearly did something wrong...when the shock travels, the shaft moves up and down in the hat rather than the shaft traveling in and out of the shock body. It looks like if I hit a big enough bump or dip the shaft might pop through the inner fender well...if that makes any sense.
    One other thing: I didn't install the black boot that came with the shocks. The one that covers the shaft. Does that have something to do with it?
    Thanks in advance for the help
  2. Jun 22, 2012 at 5:38 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Can you take a pic? I can't picture what you're describing.
  3. Jun 22, 2012 at 5:41 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Shaft is moving in the top plate, where the bushing sits.
    Improperly installed bushing is my guess.
  4. Jun 22, 2012 at 9:00 AM
    binx61904
    Micah
    SOCAL
    12 White / Gray DC
    From what I've read, the top plate on the 2nd gens have the lower rubber bushing already in place. From bottom shock mount at lca up, my placement goes: shock, coil, top hat (and supposed existing bushing) small washer, 1" rubber spacer, big washer, top nut. When I looked at the black boot that would go on the shock shaft inside the coil it did have a metal ring at the top where it would touch the top plate...so maybe that is what I am missing?
    I'll have a pic up as son as I get home
    Thanks
  5. Jun 22, 2012 at 2:43 PM
    binx61904
    Micah
    SOCAL
    12 White / Gray DC
    Max2345:
    What bushing order would be proper for this install?
    Thanks
  6. Jun 22, 2012 at 2:47 PM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Should be from top to bottom- nut, washer, rubber bushing, top hat. IIRC. Then under the had should be a washer then the the dust boot. Actually, the washer and boot might be one assembly. I can't really remember.
  7. Jun 23, 2012 at 7:20 AM
    binx61904
    Micah
    SOCAL
    12 White / Gray DC
    Zac808:
    You are correct. I found a few pics and talked to the boys at downsouth ms. I pulled it all apart, recompressed the coil, changed the washer/bushing assembly order...and note sh tides like a dream.
    Thanks everyone
  8. Jun 23, 2012 at 7:21 AM
    binx61904
    Micah
    SOCAL
    12 White / Gray DC
    *she rides
    not sh tides
  9. Jun 23, 2012 at 11:39 AM
    Manwithoutaplan
    ID
    Where in so cal are you I done a bunch of install , I could take a look at it.
  10. Jun 24, 2012 at 10:41 AM
    binx61904
    Micah
    SOCAL
    12 White / Gray DC
    Manwithoutaplan:
    I split my time between redondo beach and san diego...but I got the shocks figured out. Thanks for the offer though
  11. Jun 24, 2012 at 10:45 AM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    If up LA area contact Manwithoutaplan if you need any help...
    In SD I will lend a hand as I can...
