5100 install before/after
Discussion in 'Suspension' started by adamw, May 25, 2011.
  1. May 25, 2011 at 10:34 PM
    adamw
    adamw [OP] Well-Known Member
    sunnyvale, CA
    06 prerunner-> FJC 4x4 swap
    I just put in 5100s in the front today. took about 2 1/2 hours total the first side took longer but the other took about 1/2 an hour. I was able to do it on shop class at school so and all the tools and lifts which made life very easy! I dont have any AAL or TSB in the rear and I set them at 1.75" and it sits level.
  2. May 26, 2011 at 7:21 AM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    Those times sounds right. I'm pretty good at tearing down the frontend by now and it takes me 2 hours with hand tools and a floor jack so you are doing great!
    Looks really good! I maybe looking into a set of billies for the front soon?
  3. May 26, 2011 at 7:53 PM
    adamw
    sunnyvale, CA
    thanks! the only thing I got hung up on was knocking loose the uca ball joints and needed a special tool but other then that every thing was straight forward.
  4. May 26, 2011 at 8:21 PM
    brelandt
    Terry
    Dublin, CA
    not sure on the 2nd gen but on my first gen i just unbolt the 4 bolt for the lower ball joint and swing it all out of the way. much much faster and easier.
  5. May 26, 2011 at 11:04 PM
    adamw
    sunnyvale, CA
    yeah this was kinda a pita
