5100 install help - Video inside
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kite, Sep 28, 2011.
  1. Sep 28, 2011 at 2:57 PM
    kite
    kite [OP] Well-Known Member
    Squamish, BC
    Red Truck
    In the middle of throwing in some 5100s and am having little trouble.
    Following the video below for instruction as it seems to be the easiest method I've found.
    Any idea why my LCA won't just drop like in the video after unbolting and loosening everything?
    Mine seems to be spring loaded some how which keeps it from being pushed down.
    http://youtu.be/QdyE8VkIqPg
  2. Sep 28, 2011 at 3:01 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    The UCA long bolt is torqued at ride height, the bushings are not letting it drop down. I placed my bottle jack inside the fender with the base against the top of the metal wheel well liner and jacked the UCA downwards.
    edit: The long UCA bolt needs to be torqued at the neutral (ride-height) position to prevent the bushings from tearing.
  3. Sep 28, 2011 at 3:02 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Did you loosen the nuts on the eccentrics?
  4. Sep 28, 2011 at 3:13 PM
    ajohnson
    Andy
    Charlotte, NC
    oops, I scanned through that and thought you were talking about the UCA. The video isn't working for me.
  5. Sep 28, 2011 at 4:34 PM
    kite
    Squamish, BC
    Red Truck
    I ended up disconnecting the UCA from the spindle and didn't need to drop the LCA down much.
    All done now.
    Thanks,
