5100 install price
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Icepuck72, Jun 25, 2012.
  1. Jun 25, 2012 at 7:08 AM
    Icepuck72
    Icepuck72 [OP] Well-Known Member
    Mark
    Richmond, VA
    2006 DC TRD
    OME 885's, Dakars, TRD Trail Edition Wheels, 285x75x16 Goodyear Duratracs, Magnaflow 12256 muffler, Fog Light mod, 2 Baby seats
    Just called a local 4WD shop to get an estimate...around $310 for the install and alignment. I've only called one in the area, just wanted to see what you guys thought of that price.
    If I get the 5100's first, then get the rear TSB, Toyota should do a free alignment, right? That should cut down on the cost.
  2. Jun 25, 2012 at 7:13 AM
    evh5150
    evh5150 Well-Known Member
    Eddie
    Auburn,Ma
    2010 D/C S/B V6 6 Speed
    Bilstein/5100 combo from Toytec. LR UCA's.1.5 AAL's Full audio upgrade.Pioneer 8400, JL Audio subs. All Boston Acoustic pro speakers, and a Kenwood XRS 5 amp. Grillcraft, Smittybuilt stainless steps. Debadged. Soon 17x8 ATX Ledge wheels w/285/70/17 BF Goodrich
    If the tech knows how to align a lifter truck. Is that price for all 4 shocks
  3. Jun 25, 2012 at 7:24 AM
    AbqTRD2010
    AbqTRD2010 Well-Known Member
    Michael
    Rio Rancho, NM
    '10 4x4 DblCab Long Bed Sport
    TRD FJ TeamTrail Blk Rims| BFG AT KO 265/75/16| TRD Cat-back Exhaust | TRD CAI | UNICHIP Installed| 5100 Billies @ 1.75 | Rear Leaft TSB & 1" Block| Grillcraft Satoshi Grill | Exclusive Element Light Bar w/ Hella 500FF | Aftermarket Black Headlights & Black LED Tail Lights| Preimium Hook Struts | SungTop LS Tonneau Cover |Black OEM Running Boards | Window Tint @ 20%| Blacked Out Emblems| Shortened Antenna | Flyzeye LED Interior Accent Lighting
    I payed $150+tax to get all four installed. Since I already had my TSB done I couldnt get the alignment done for free by the dealership. I took my truck to a different place to get the alignment done. They charged be $85+tax for lifetime alignment, but if I get the truck lifted anymore then wont be able to honor the lifetime alignment.
    For my gf's tacoma we got the 5100s installed for the same price then got the TSB done on the truck. Free alignment by the dealership!
  4. Jun 25, 2012 at 7:32 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    $310 for install and alignment is a rip off! Rear shocks are very simple and the fronts won't take a shop long to install at all. Shouldn't be more than $200 tops since you're buying the shocks and bringing them in.
    Double check the TSB to make sure it comes with an alignment. They used to because they were replacing the black SR5 shocks with stock Bilsteins but since your TRD already has Bilsteins, they have no reason to mess with the front end so they might not have to align it. I'm not familiar with the newer versions of the TSB so just check before you bank on that for a free alignment.
  5. Jun 25, 2012 at 7:39 AM
    Icepuck72
    Mark
    Richmond, VA
    2006 DC TRD
    This is just for the front two shocks....wow. Sounds like I need to shop around!!!
  6. Jun 25, 2012 at 7:44 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    I paid about 150 more for my whole 3" lift install including new UCAs and alignment. So you should be much cheaper just for 2 fronts.
  7. Jun 25, 2012 at 7:48 AM
    Pugga
    Massachusetts
    Yes, do some looking. Stealership alignment pricing is just under $100, most smaller shops will do a front end alignment for $60 - 75. For a competent shop, a shock swap shouldn't take more than an hour unless bolts are really rusted on and take some coaxing to free up. Assuming $100 for a shop rate, your max should be $200 but you shouldn't have any trouble finding a shop to do it for $150ish.
  8. Jun 25, 2012 at 7:48 AM
    TacomaRockStar
    TacomaRockStar Well-Known Member
    LUCA
    Lacey Twp, NJ
    TRD Sport
    Toytec 3" lift with Bilstein all around, LR UCAs, AAL. Custom decals, short antenna, weathertech floor liners, Nfab Steps, Custom Emblem, LED lights all around, HID.
    Josh where are you because the damn shops around me quoted me from 400-700 to install my in hand lift and alignment!:mad::mad::mad::mad::mad:
  9. Jun 25, 2012 at 7:52 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    $310 = $100 alignment, $210 labor more or less. Its probably a 2hr job start to finish with the proper equipment and you know what your doing. Remove tires, remove shocks, disassemble original front struts to remove coils, then install coils to the new 5100's, then install all shocks. Replace and torque tires, then do the alignment. So maybe a little high, but if you could get a lifetime alignment (avg $150 or so in value) it may be worth it. Also, if its a good shop, sometimes paying for it once to get what you want and done right is also worth something... :cool:
  10. Jun 25, 2012 at 7:52 AM
    Pugga
    Massachusetts
    I'm guessing you have a friend at the shop or someone owed you a favor. If not, you got one hell of a smoking deal and should put the shop's name up so others can get the same deal. $150 for a lift install including alignment is crazy low and the shop would definitely lose money on that deal.
  11. Jun 25, 2012 at 7:53 AM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian aka B-Lang
    San Luis Obispo, CA
    2010 Tundra
    it can be free!! installing it yourself is super easy!!!! :thumbsup:
  12. Jun 25, 2012 at 7:55 AM
    jtav2002
    Josh
    Reading, PA
    Place I went to was J&B Motorsports near Pottstown. Its probably about 40 min NW of Philly give or take. Good guys there. IIRC it was about 450. Perhaps could find cheaper but I thought it was a fair price and I heard good things about them on a couple other forums. If that's within reasonable travel time for you I'd shoot Brian there an email or phone call.
    Pugga, meant 150 more than one OP was quoted.
  13. Jun 25, 2012 at 7:56 AM
    Icepuck72
    Mark
    Richmond, VA
    2006 DC TRD
    Yep....just that I'm not too comfortable doing it by myself....would just rather pay a reputable shop with lifetime alignment to know it's done right, especially while my truck has only 11k on it. :)
  14. Jun 25, 2012 at 7:57 AM
    evh5150
    Eddie
    Auburn,Ma
    doesn't mean they know how to properly align it.
  15. Jun 25, 2012 at 7:58 AM
    tacokid09
    Brian aka B-Lang
    San Luis Obispo, CA
    2010 Tundra
    i want either, trust me haha. i was 17 when i put my whole UCA, Shocks, Bumper and wired all my HIDs up just because everything had a write up on here! but that life time alignment does sound nice.. :pout: i wish we had a firestone around in my town :(
  16. Jun 25, 2012 at 8:00 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    Also, some guys have had their 5100's installed prior to the TSB since an alignment is necessary with the Rear Leaf TSB. You may want to clear it with the shop mgr. If the dealer does it, it should be cheaper, they have to remove the rear shocks for sure, but not the fronts. So you would have to pay for the coil swap and the uninstall and reinstall of the front struts. But still get the alignment for free
  17. Jun 25, 2012 at 8:02 AM
    Pugga
    Massachusetts
    I guess I need to work on that whole reading comprehension thing :eek:
    Don't mind me, carry on...
  18. Jun 25, 2012 at 6:23 PM
    dpak
    dpak Well-Known Member
    Richmond, VA
    09 4x4 TRD Offroad DCSB
    Toytec/Eibach coils w/ 5100's set at 0, Toytec 2.0 Aluma Rear Shocks, Toytec Boss Leaf Springs, TRD Catback Exhaust, SCS F-5 Matte Gray Wheels, Elusive Elements Mesh Grill
    I'm in Richmond also. Where did you get that quote from? I took my truck to Truck Outfitters and had them install front shocks with eibach springs and rear shocks. They charged me almost $400 for it. Stay away from them.
  19. Jun 25, 2012 at 6:27 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    its pretty great1 i get a alignment after every tacomaworld trip... :cool:
  20. Jun 25, 2012 at 6:33 PM
    trussell456
    trussell456 Well-Known Member
    Tyler
    Maine
    03 TRD V6 5-Speed
    Bilstein 5100's / Eibach's / AAL / All Pro Front Bumper / Skids / Billet Grill / 33x12.5x15 Duratracs / Dick Cepek DC-2's / TRS Retrofit / 20" Light Bar / 6" HID Fogs / Wet Okoles / WeatherGuard Tool Box
    What about installing them yourself? When i did mine i just had a shop put my 5100's and eibachs together and i installed them. He charged me 35 bucks!
