5100 length vs stock Bilsteins
Discussion in '2nd Gen. Tacomas (2005-2015)' started by roamineye, Jul 5, 2011.
  1. Jul 5, 2011 at 12:51 PM
    roamineye
    roamineye [OP] Member
    Oklahoma
    TRD Sport
    Anyone know how much longer the front 5100's are than the stock billies that come with the 2010 DC TRD SB Sport? Thanks in advance....
  2. Jul 5, 2011 at 12:57 PM
    roamineye
    Oklahoma
    TRD Sport
    Clarification - fully extended length
  3. Jul 5, 2011 at 12:59 PM
    roamineye
    Oklahoma
    TRD Sport
    The Toytec guys are telling me the 5100's are longer, but can't tell me how much. Thought someone might have measurements.
  4. Jul 5, 2011 at 1:08 PM
    roamineye
    Oklahoma
    TRD Sport
    OK, so we have the same wheel drop constraint after a 2" front lift whether we use the 5100's or leave the stock billie's on?
  5. Jul 5, 2011 at 1:43 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Christian is right, the fronts are the same. Theres a side by side pic floating around here somewhere.
  6. Jul 6, 2011 at 8:19 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I am not sure, but the front should be the same, were you get the lift is in the compressed spring and seat position. The rears they state will be able to fit a stock to a 2" lift in the rear suspension, which suggests to me the rears may be longer. The stock Bilstein shocks are nice for an OEM factory option, but the 5100's are a completely different animal, and a much better shock. For a leveling option and or a upgrade to the factory shocks, this is the best bang for the buck IMO... :cool:
  7. Jul 6, 2011 at 8:20 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    i have seen the picture before... i think chris 4x4 posted it. but i thought they were like a inch or so different. unless im thinking of a different picture
  8. Jul 7, 2011 at 4:49 AM
    roamineye
    Oklahoma
    TRD Sport
    Thanks everyone....I appreciate the input. I'm mostly concerned with the reduction in downward wheel travel when lifting with 5100's and how often the shocks would hit the limit of travel. From what I've read on this site, it doesn't seem to be much of a problem except in fairly aggressive offroad conditions, which I don't do.
  9. Jul 7, 2011 at 5:15 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    How many times have you bottomed out recently? If your answer is never, then you will find these shocks will be a great upgrade to the stock shocks, TRD or not. If your bottoming out and getting air, time to upgrade beyond the 5100's. :cool:
