5100 leveling question?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JanBoothius, Aug 23, 2011.
  1. Aug 23, 2011 at 12:57 PM
    JanBoothius
    JanBoothius [OP] Well-Known Member
    Jan (Pronounced Yon)
    Upstate New York
    2015 TRD OR DCSB 6 speed
    Heavy stuff big tires drives like hell
    Should I set the Bilstein 5100's at .85", or 1.75" to level a 2nd gen with the rear leaf/harsh ride TSB?
    Anybody have pics of this setup? Note: I'm not using an add-a-leaf, just leaf TSB.
    Thanks everyone!
  2. Aug 23, 2011 at 1:03 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Go with 1.75 you will still have a rake if you get the tsb done. I set mine at 1.75 and no rear tsb and I'm half inch higher in the rear.
  3. Aug 23, 2011 at 1:14 PM
    JanBoothius
    Upstate New York
    Sounds good, thank you!
    Do you have pics of your truck with Billies @1.75"?
  4. Aug 23, 2011 at 1:37 PM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SAnta Paula CA
    18 TRD sPort 4x4 (11mgmsport)
    oem pro grill 17” pro rep wheels Fox dsc shocks
    Pic in my gallery if 1.75 + tsb
  5. Aug 23, 2011 at 1:39 PM
    The1youluv2hate
    Peps
    SAnta Paula CA
  6. Aug 26, 2011 at 4:39 AM
    waterwolf603
    waterwolf603 Well-Known Member
    New Hampshire
    2011 SR5 v6 4x4
    I actually am getting the rear tsb done this week and I just picked up some 5100's as well would 2'' or 2.5'' be too high for the front and make it not be level.... Is the 5100's all that is need to lift the front end? (not to hyjack the thread)
  7. Aug 26, 2011 at 4:55 AM
    drewskie
    drewskie Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    So you have stock rear set-up, and the back is still higher? Even with the front at 1.75? How is that?
  8. Aug 26, 2011 at 5:14 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Because it is 2 1/2 or more higher to start with......
  9. Aug 26, 2011 at 5:32 AM
    waterwolf603
    New Hampshire
    2011 SR5 v6 4x4
    stock is 2.5 inches higher to start with? So setting the 5100's at 2.5 should be close to level with the rear tsb done?
  10. Aug 26, 2011 at 9:13 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
  11. Aug 26, 2011 at 9:25 AM
    WaGood24
    WaGood24 Well-Known Member
    Michael
    Dayton, OH
    2010 Double Cab PreRunner TRD Sport
    Extang Full Tilt tonneau, VX Series Exhaust, Nitto Terra Grapplers, Stainless Nerf Bars, Bilstein 5100s all 4 corners, rear-leaf TSB
    The rear TSB will raise the bed about 1"-1.5". But from what I've read, each truck may be a little different. I set mine at 1.75" and got the rear TSB and my back end is about .5"-1" higher now. But I think mine was only about 1.5" higher to begin with. Another thing to keep in mind is that I've heard that the rear TSB settles some over time and that setting the 5100s at 2.5" is more prone to vibes and other potential issues. Also, be sure to put the shocks on first and that way Toyota alligns your truck for free!
  12. Aug 26, 2011 at 9:28 AM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Pic in my photos of 1.75 w/TSB. Look at the one with the black lower valance, not the plain white. I plasti-dipped it after I saw how KPT plasti dipped his. :boink:
    lol
    :burnrubber:
  13. Aug 26, 2011 at 9:29 AM
    waterwolf603
    New Hampshire
    2011 SR5 v6 4x4
    Nice thanks for the help I actually am having them put the shocks on while they add the tsb so allirgnment is covered i just pay labor for the shocks being put on... so 1.75'' is the way to go did you notice much of a difference in the height of the truck? Do you think if I went 2 that it would be ok and or level after settling?
  14. Aug 26, 2011 at 9:34 AM
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    5100s set at 1.75, with rear TSB. This was done last week, and I expect the rear to settle down a bit over time:
  15. Aug 26, 2011 at 9:38 AM
    waterwolf603
    New Hampshire
    2011 SR5 v6 4x4
    Nice man truck looks good!! Thanks for the help
  16. Jan 18, 2012 at 2:56 AM
    Wallygater
    Wallygater Well-Known Member
    USA
    '11 SR5 DBL Cab 4x4 6 speed
    Softopper, All-pro bolt-on sliders, Tom Wood's drive shaft, Goodyear 235/85/16 Dura-trac's, SG, USA-Spec I-pod adaptor, Amsoil in everything
    OLD THREAD REVIVE during a search ;)
    Much like the OP was planning, I want to put the 5100's @ .85 in the front and get the rear TSB. I think he was talked into going 1.75. I don't want to go that high. Yes this will give me some rake but I use my truck as a truck. I am getting the TSB because of this and not for looks. Knowing this, how much will the TSB rear springs settle after break in? Will I still have a front biased rake after they settle with the 5100's at .85? Any one know how much of a rake (after settling) or does anyone have this setup? Thanks. :cool:
  17. Jan 18, 2012 at 3:44 AM
    JanBoothius
    Upstate New York
    With the 5100's at 1.75 and the leaf TSB, my truck is close to level, but the front is still a little lower.
    Since installing the 5100's and getting the TSB done, it has saw plenty of heavy work hauling firewood and work supplies around until November '11, and then a 2,200 mile drive fully loaded to Utah, and bouts of offroading throughout.
    The 5100's ride significantly better than the TRD Offroad shocks did, and set at 1.75" give a perceptible frame-clearance increase (though the slightly oversized tires help too).
    Pleased with this setup, works very well until I can afford a proper lift and Dakar leafs.
  18. Jan 18, 2012 at 6:22 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    1.75 w/ rear tsb.
  19. Jan 18, 2012 at 6:26 AM
    TexasTacoma37
    That picture was my inspiration.
  20. Jan 18, 2012 at 2:09 PM
    Wallygater
    USA
    Thanks for the replies. Still can't decide. I'm leaning towards putting them at .85" in the front. :cool:
