5100 on 2wd
Discussion in 'Suspension' started by curtis, Jun 12, 2011.
  1. Jun 12, 2011 at 1:09 AM
    curtis
    curtis [OP] Member
    Curtis
    Tracy
    2000 prerunner
    8k hid straight pipe
    i want to raise the front of my truck so it is nose high or level. what should i set the billy 5100 to so i can achieve this. and what about wear and tear one the tires and bushings. also what about alignent and uca. thank you
  2. Jun 12, 2011 at 1:09 AM
    curtis
    curtis [OP] Member
    Curtis
    Tracy
    2000 prerunner
    what should i set them too 2.5 or 1.75??
  3. Jun 12, 2011 at 1:58 AM
    Ez2typethis
    Ez2typethis Well-Known Member
    Santa Maria, CA
    10 TRD sport 4x4 TRD S/C, TRD Cat back
    My 2010 4x4 TRD sport: Bilstein 5100's in the front set at 1.5" to level, TRD Supercharger, TRD Cat back, TRS retrofit, Satoshi grill, Redlinetuning hood struts, Socked ***SOLD***
    1.75 is pretty close to lvl
    Next setting up and it will look a little "baja'd" out unless you do an AAL in the rear.
    I have mine set to 1.75 and have had no adverse effects as far as wear and tear go.
  4. Jun 12, 2011 at 7:08 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    He has a first gen. The 5100s only have three settings: 0, 1.25", 2.5".
  5. Jun 12, 2011 at 9:02 AM
    curtis
    curtis [OP] Member
    Curtis
    Tracy
    2000 prerunner
    2.5 for baja look? thats wat im doin then.what bout wear and tear at that height
  6. Jun 12, 2011 at 10:17 AM
    Ez2typethis
    Santa Maria, CA
    What i said earlier is applies to second gen, sorry didnt notice you had a 2000 before. I'm not quite sure how 2.5 will look on the first gen. Dont know anything about wear n tear on them either sorry :(
  7. Jun 12, 2011 at 1:05 PM
    Slodgetto
    Slodgetto Über Posre
    Silas
    Dirty Terc
    Scratches, dents, and junkyard parts.
    I have a prerunnner as well and I used the bilstien 5100/eibach combo for 3" of lift and everything is fine...
    True. But you still have to be careful with the balljoint angles... we can't go to crazy... :p
  8. Jun 12, 2011 at 1:15 PM
    KPT
    09 Prerunner
    You only really need to worry about the ball joints if you have top plate spacers. That's because by lengthening the shock assembly itself, you are allowing the suspension to droop more than it was designed to.
    That's not the case with stiffer springs or coil spacers, because they lift by decreasing your available down travel on you shocks, but do not increase the total downward travel.
  9. Jun 12, 2011 at 8:13 PM
    curtis
    curtis [OP] Member
    Curtis
    Tracy
    2000 prerunner
    thank you every one. so billies at 2.5 it is with stock coilover and uca
  10. Jun 13, 2011 at 10:14 AM
    drifter
    drifter moderately modded
    Sam
    Oregon
    good stuff
    OME 880's/Nitrochargers, Rebuilt leaf packs, diff breather extension, hole in air box, truck toolbox, panasonic stereo, Mag light mount, Glasstite canopy, Custom designed/built light bar, Hella 500's.
    First I ever heard about different settings for the 1st gens than the 2nd gens. I considered buying the 5100's and setting them at 1.75, I guess I would have been a little surprised to find out they only had 3 settings as opposed to 4.
    Post pics when your done OP :thumbsup:
  11. Jun 13, 2011 at 12:04 PM
    KPT
    09 Prerunner
    Actualy I was wrong about the 1.25". The middle setting for the 1st gens is only 1". See the second pic from DSM's website.
    http://downsouthmotorsports.com/i-1...pre-runner-4wd-front-pre-load-adjustable.html
