5100 question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JackedTaco, Apr 5, 2010.
  1. Apr 5, 2010 at 6:29 PM
    JackedTaco
    JackedTaco [OP] Well-Known Member
    Johnny
    USA, Earth...
    07 Access Cab TRD Off Road
    Weathertech Mats, Thule rack custom install on bed caps. Foglite anytime mod. K&N air filter. Rear leaf TSB. Tinted passenger windows. TRD CAt Back exhaust. Bilstein 5100 front shocks at 1.75".
    I just ordered a set of Billy 5100's to lift my 07 1.75". My question is, do I need to also put on the spacer to prevent the taco lean, or am I ok because I am using my stock springs?
    Thanks in advance.
  2. Apr 5, 2010 at 6:30 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    if anything get the 1/4" toytec spacer to fix the lean. only thing is you will need longer screws in the top plate mount to accomodate the spacer
  3. Apr 5, 2010 at 6:36 PM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    Actually, I don't think you do need longer studs for the 1/4" plate.
    Is your truck level now? I'd probably buy the spacer and put it in. It's only $20 and easy to take out if you change your mind.
  4. Apr 5, 2010 at 6:39 PM
    08pretaco
    az
    sorry i meant the spacer lift from toytec which includes the new studs
  5. Apr 5, 2010 at 7:08 PM
    bakerla
    bakerla Man, Myth, Legend
    Lyndall
    Pearland, TX
    '10 4wd OR
    CBI Moab front and CBI Trailrider rear, Budbuilt skids, Shrockworks sliders, OME Dakars w/ OME Nitros, OME 886x w/ OME Nitros, Light Racing UCAs, stainless steel brakelines F/R, Cobra 75 w/ Firestik antenna, 255/85/16 Cooper ST Maxx on 1st gen alloys, Weathertech liners, Engo 9000S winch, stickars and other shit.
    Id recommend getting the 1/4 inch spacer. After putting 5100s on my truck the lean is more pronounced. Just be sure to have it handy when you compress your springs. I bought mine after the fact, not realising id have to recompress the springs to install it, which I still have yet to do.
  6. Apr 5, 2010 at 7:25 PM
    LostRebel
    LostRebel Well-Known Member
    Almost Canada, USA
    Black Access Cab 4x4 TRD Off Road
    Fisher plow, BakFlip and Snugtop cap, Demello Sliders, Scanguage,
    The Toytec 1/4" spacer installs between the top of the coilover assembly and the frame mounting bracket. It's not necessary to disassemble the coilover to install the spacer and the existing studs are long enough.
  7. Apr 5, 2010 at 7:31 PM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    You don't have to re-compress the springs. It loosely nestles between the three top nuts and gets sandwiched between the top plate of the strut assembly and the mounting bracket. It's a 30 minute job.
  8. Apr 5, 2010 at 7:54 PM
    bakerla
    Lyndall
    Pearland, TX
    '10 4wd OR
    News to me. I was told otherwise, its been sitting on my bench for a week. thanks! I've got a new project....even if its a 30 minute job.
  9. Apr 5, 2010 at 7:56 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    x2^^^^^^^^^^^
  10. Apr 5, 2010 at 7:58 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    i set mine to 2.5 and the lean is barely noticeable.
  11. Apr 5, 2010 at 8:01 PM
    kilgoja
    kilgoja Well-Known Member
    Alabama
    2009 regular cab 4x4 2.7L (silver)
    :mudding:
    my lean is only 1/8th of an inch...not a big deal at all...the rear is worse than the front
  12. Apr 5, 2010 at 8:03 PM
    JackedTaco
    Johnny
    USA, Earth...
    Thanks guys, i will install and then if noticable install after. Thanks again!!!
