5100 setting question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Phils514, Jun 2, 2014.
  1. Jun 2, 2014 at 3:08 AM
    Phils514
    Phils514 [OP] Well-Known Member
    Phil
    Dcsb
    I read in a post saying the 2.5 inch setting is too high, you lose travel and is not recommended. I'm thinking of getting AAL in the back and hopefuly airbags too. What are you're thoughts? And also where is the best place to get them. I see on eBay someone has the fronts for 88.99 a piece.
  2. Jun 2, 2014 at 7:07 AM
    wobble
    wobble Well-Known Member
    Ridgefield, WA
    2014 TRD OR
    Modified RCD Lift, 315/70R17 STT Pros
    I ran 5100s at 2.5 w/AAL for 2 years. It rode pretty good. It's an affordable way to lift and gives better ride quality than using spacers. You do lose some downward wheel travel doing this type of lift though.
    I've had positive experiences buying from Downsouth Motorsports, Toytec, and Wheeler's.
  3. Jun 2, 2014 at 7:12 AM
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Its all based on opinion on how it rides. I haven't had this setup, but many people think it rides quite stiff at 2.5 setting. I plan on putting mine at 1.75 then a 1/4" spacer on both sides for a little more lift. By the way, front spacers lift about double their height, so 1/4"=.5", 1/2"=about 1". And most people I spoke to only got about 1.5-1.6" of lift at the 1.75 setting
  4. Jun 2, 2014 at 8:10 AM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    I just got all four corners for $319 from downsouthmotorsport free shipping. Set the front to 1.75 had lifted the back 2" already. Sits really close to factory rake.[​IMG]
  5. Jun 2, 2014 at 9:00 AM
    Phils514
    Phil
    Dcsb
    What did you use to get the 2 in the back, I also see 5125 available for rear shocks any thoughts?
  6. Jun 2, 2014 at 9:14 AM
    yota243
    E.J.
    north Alabama
    I welded a plate on top and bottom of playground coils that i cut 12" disconected my shock and bolted the top to the frame and used factory ubolts on the bottom. This pic was before the billies. It has gotten mixed reviews since spring steel weakens when heated but ive been keeping an eye on it and itsb een on 2 months now. Also this way my leaf springs are still the limiting factor so 5100 shouldnt bottom out.[​IMG]
  7. Jun 2, 2014 at 9:28 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I just grabbed the ones off ebay for 88.99 a piece because i wanted to go with Old Man Emu N182 shocks in the rear for more travel than the rear 5100's.
    I also went with a full length ad a leaf off ebay.
    http://www.ebay.com/itm/1995-2011-T...fits=Model:Tacoma&hash=item3a6e43d757&vxp=mtr
    36inches long, supposed to make for a much better ride than all the short ad a leafs out there.
  8. Jun 3, 2014 at 12:45 PM
    Haskett039
    Haskett039 Well-Known Member
    Rob
    Ontario, Canada
    2012 TRD Alpine White
    I just had Billys installed @ 1.75 today and ended up with almost 1.75" on the driver side and a bit more than 1.5" on the passanger side
  9. Jun 3, 2014 at 1:35 PM
    MTopp
    05 SR5 4x4
    Huh, I guess it all depends on truck too for how much lift you get. I should say that most I spoke to got right around 22 1/2" hub to fender up front, so it depends on what your truck was beforehand
    Looks good^^^
  10. Jun 3, 2014 at 1:38 PM
    yota243
    E.J.
    north Alabama
    I imagine newer trucks see more lift since the springs are less wore. Also with a full tank and a driver haskett should be sitting pretty level
  11. Jun 3, 2014 at 7:41 PM
    Haskett039
    Rob
    Ontario, Canada
    Actually that's something I never thought of, truck is running close to E right now...but after the install I am still approx. 0.5" high in the rear end so I am really happy with the result.
    Now on to tire shopping...I like the way 255/75/17 fills out the wheel well but its hard to find anything I want in that size...275/70/17 is a nice common size around here but nearly $40+ per tire compared to the 255...
  12. Jun 7, 2014 at 9:17 PM
    Cdm2009
    Cdm2009 Member
    Hokes Bluff, Alabama
    09 sr5 trd sport
    Arb bumper, bilstein 5100 all around, inno roof rack
    I have billies all the way around. Set at 1.75 in front on stock coils and and 1.5 aal in rear. I'm running 255/75/17 BFG km.
  13. Jun 7, 2014 at 9:32 PM
    bueller
    bueller Well-Known Member
    AZ
    How would 5100's set at 2.5 give any better ride than spacers when they both do the exact same thing? I see people saying this and it makes no sense. Am I missing something?
  14. Jun 8, 2014 at 5:38 AM
    MTopp
    05 SR5 4x4
    Well the 5100s preload the coil instead of sitting on top of the coil assembly, but also the 5100s are designed and valved to provide lift by preloading the coil, unlike an OEM Toyota coilover/strut/shock. At 2.5, it probably rides almost like a spacer, but at 1.75 many have said it's a much better ride than a spacer lift.
  15. Jun 8, 2014 at 5:51 AM
    Hawkeye888
    Hawkeye888 Well-Known Member
    How do you like that aal? I'm looking to pick one up, wouldnt mind a quick review.
  16. Jun 8, 2014 at 11:51 AM
    bueller
    AZ
    I didn't realize we were talking about top spacers. I was thinking something like a Revtek spacer that preloads the coil. Top plate spacers are going to ride pretty much just like stock, so I doubt 5100's set at 1.75 would ride better unless you prefer a stiffer ride, which some people do.
  17. Jun 8, 2014 at 2:28 PM
    nd4spdbh
    SoCal
    I have yet to put it on... probably will do so in the next week or two. look for a review then.
  18. Jun 8, 2014 at 6:55 PM
    MTopp
    05 SR5 4x4
    From what I've read most people said that top plate spacers made the ride rougher as well as coil spacers. I've never had them, so I'm not 100% sure on that
  19. Jun 8, 2014 at 7:49 PM
    nd4spdbh
    SoCal
    top plate spacers (the spacers that go above the top of the strut in between it and the body mount) should never be used.... it will cause your shock to bottom out before your truck hits the bump stops.
