5100/Toytech coikovers - is it a good buy
Discussion in 'Suspension' started by douglasmc, Dec 23, 2012.
  1. Dec 23, 2012 at 10:48 AM
    douglasmc
    douglasmc [OP] Active Member
    Ga
    2013 tacoma sport 4x4 V6
    Fog light mod, 12 volt power full time, inverter 400w full time, Added 115v outlets in cab, Trimmed off 4in from front mud flaps, more to come ;)
    I have a new 2013 Tacoma DC sport, I'm looking at this set of coilovers for it. I would just like some info about how y'all feel about setup.. I have read the discussions about not doing the spacers and instead opt for a coil over setup.. So how does this look. Looking to put 32 or 33s on either a 17 or 18 in wheel.. Not wide as all I would like is better traction in the fields and such.
    3" lift kit with Bilstein 5100 Height Adj. Coilovers
    Price per Unit (Kit): $919.99
    Complete 3" lift kit for 2005 & UP Tacoma with Bilstein 5100 Height Adjustable front shocks
    INCLUDES:
    Bilstein 5100 height adjustable front shocks
    Toytec/Eibach 112620 front coils
    Fully assembled with Toytec Aluminum top mount and Urethane bushings
    Preset at 3" Lift (Lift heights may vary depending on how much front weight you have installed on your vehicle)
    Rear options: select one below
    -----TAC-AL - ToyTec Rear "long" add-a-leafs featuring anti friction pads for quiet ride
    Also includes:
    -----Extended length Bilstein 5100 rear nitrogen gas shocks for optimum performance on and off road
    -----TT-RS - rear axle degree shims for proper pinion angle alignment
    -----UB-4 - (4) new rear ubolts
  2. Dec 23, 2012 at 10:50 AM
    douglasmc
    Ga
    Oh and I'm not going to be adding weight to front end other than maybe a avid offroad guard, or a bull guard.
  3. Dec 24, 2012 at 10:51 AM
    douglasmc
    Ga
    Anyone use this setup
