5100 vs 5125 (or 5100+thread spacer)
Discussion in '1st Gen. Tacomas (1995-2004)' started by treyus30, Nov 10, 2019.
  1. Nov 10, 2019 at 1:21 PM
    treyus30
    treyus30 [OP] 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Couple questions I've been putting off asking (yes, I've used the search tool)...
    I replaced my worn out leaf springs a while back with Dakars. They gave me a ton of rear lift (that I didn't expect), and I figured they'd settle as used them. They didn't, and a few months ago I realize they completely topped out my rear 5100s to the point of working the thread loose on the driver's side.
    I haven't found a marketed shock extender for these, but if anyone knows the thread size, I'm sure someone makes one (Ace Hardware?). I could find this out myself, but kind of a pain the ass to buy a bunch of differently sized nuts and test them all.
    Before anyone suggests it, I'd rather keep the extra leafs in since its mainly a utility truck now, and when I put 6-800lbs of concrete in it, it's nice and level.
    It seems from reading forums that 5125s are softer than 5100s, but they come in multiple lengths. Is its softness (less damping?) really going to make a difference when the leafs are already so hard? I wouldn't mind a less bumpy ride anyway tbh. And then I just make sure the mounting point to the bumpstop is greater than or equal to the new shock's fully compressed length?
    Thanks
  2. Nov 10, 2019 at 1:34 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Consider removing a leaf from the Dakar’s.
  3. Nov 10, 2019 at 1:39 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Lololol:rofl:
  4. Nov 10, 2019 at 1:40 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    smh lol
    cruiserguy[QUOTED] likes this.
  5. Nov 10, 2019 at 1:50 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @treyus30 you do know there are 2 different length Bilstein 5100's for our truck right?
    One is for a 0-1.5" lift and 1-3" lift (I'm just estimating the numbers).
    I'd have to dig through my old posts to find the longer length shock part numbers, or you could wait until I get home tonight to post the ones I have; I've got the boxes set aside with my Fox shocks inside of them.
    I've got the longer shocks to accommodate my OME Dakar's.
    cruiserguy likes this.
  6. Nov 10, 2019 at 2:09 PM
    cruiserguy
    Elijah
    SEKS
    Aren't the 5125s the longer ones that people run with the taller springs? I'll have to double check
    Edit: I'm mistaken. 5125 vs 5100 refers to valving as OP stated in beginning of his post
  7. Nov 10, 2019 at 5:05 PM
    cruiserguy
    Elijah
    SEKS
    You prolly wanna hang out in forum whatever gen you have. It isn't this sub forum though
    Kwikvette likes this.
  8. Nov 10, 2019 at 7:49 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @treyus30
    Bilstein 5100
    Original, meant for 1.5-3" lift
    Part #, Extended length, Collapsed length
    F4-BE5-D559-TO 21.63 EXT 13.93 COL Driver side shock
    F4-BE5-D560-TO 22.57 EXT 14.65 COL Passenger side shock
    Newer style, meant for up to 1" lift (sure you could get away with 2")
    33-247724 21.26 EXT 13.62 COL Driver side shock
    33-247717 22.09 EXT 14.07 COL Passenger side shock
  9. Nov 11, 2019 at 10:24 AM
    Scoobz121
    Scoobz121 Member
    Hi any idea if this works with no lift/stock leaf in the rear?
  10. Nov 11, 2019 at 10:30 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I answered your other thread; go with Bilstein 4600's
  11. Nov 11, 2019 at 10:31 AM
    Scoobz121
    Scoobz121 Member
    Thanks!
  12. Nov 16, 2019 at 1:05 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Hmmmmmm. That's annoying.
    I'm like 99% sure I have the 1-1.5" ones... had no idea they came in more than one size.
    Edit: I'm trying to look for the F4-BE5-D559-T0 and F4-BE5-D560-T0 but they all say they're also 1-1.5"??
