5100 vs 5125 rear with 1.5" AAL
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mtsrunner, Oct 23, 2015.
  1. Oct 23, 2015 at 6:19 AM
    mtsrunner
    mtsrunner [OP] Well-Known Member
    I'm ready to order my lift and ran across a table from DSMS's site that has me confused. I was ready to go with 5100s for my rear shocks, but I saw this table:
    Rear Shocks Application Table-
    MODEL YEAR REAR LIFT REAR PART # SHOCK SERIES NOTES
    4wd/2wd Tacoma 6 Lug (Prerunner) 05-15 0-1" 24-186728 5100 Series
    4wd/2wd Tacoma 6 Lug (Prerunner) 05-15 2" 33-230337 5125 Series
    4wd/2wd Tacoma 6 Lug (Prerunner) 05-15 3-4" RCD BE5-B110-T5 5100 Series
    Please make sure to reference the table above to choose the right shock for your vehicle.
    Since I will be adding 1.5" to the rear with the AAL, should I go with 5125 instead of 5100???
    If it matters, this is on a 2016 DCORSB and I am removing the factory overload spring and the AAL will be a 3 leaf progressive 1.5" (either Deaver, Wheelers or Toytec).
    Also havent decided between 5100s on stock coils up front or 6112s. Just going to lift the front about 1.5" also to get good clearance on 255/85 16s. Maintain factory rake or slightly less.
    Never tow and don't haul much. 90% dd/10% offroad, but nothing too technical or rough.
    Thanks so much, I am new to lifting and this forum has been awesome in helping me gain some knowledge.
    dylmatik likes this.
  2. Oct 23, 2015 at 6:22 AM
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    No, go with 5100 because 5125 is more for a custom application. You would need to get an adapter so that the 5125s can mount properly.
  3. Oct 23, 2015 at 6:26 AM
    mtsrunner
    Thanks! Thats what I thought. I have seen a bunch of people running 5100s with 1.5" AAL. Just wanted to make sure.
    Now, I just need to know if the 6112s up front are worth the extra $$ over the 5100s. I usually subscribe to "buy once, cry once", so I wouldn't mind paying more if the ride is noticeably better on and offroad with the 6112s
  4. Oct 23, 2015 at 6:27 AM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    I can't help with that one but here have a free bump!
  5. Oct 23, 2015 at 6:29 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Which 5100?? Aren't there 2 choices - or is one adjustable?? I'm new here!
  6. Oct 23, 2015 at 6:39 AM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Front 5100's are adjustable. Rear 5100 are not
  7. Oct 23, 2015 at 7:25 AM
    mtsrunner
    Thanks. I think I'm going with the 6112 front set on the middle setting (#3, 1.59"). 5100s rear with Wheelers 1.5" progressive 3 leaf AAL without the factory overload. This should give me approximately 1.5" overall lift and maintain close to factory rake. Should have clearance for my Cooper SST 255/85R16s without need for new UCAs. Going to be on SCS SR8s in matte black. Inferno DCORSB. Should be done around Halloween.
    0uTkAsT likes this.
  8. Oct 23, 2015 at 8:33 AM
    mtsrunner
    I thought about trying to go stock, but I wanted a little lift anyway. Hopefully, I will get a better ride, too. I sure hope so because I will end up being in to it for about $3K for lift, wheels, tires and installation.
    0uTkAsT[QUOTED] likes this.
  9. Oct 23, 2015 at 8:38 AM
    cgchambers93
    cgchambers93 Well-Known Member
    Christopher
    Houston
    14 Tacoma SR5 4x4
    Wheels and tires, Billstein suspension
    I am using 5160s with my icon AAL.
  10. Oct 23, 2015 at 10:46 AM
    NV_Tacoma
    NV_Tacoma Well-Known Member
    Paul
    Northern Nevada
    2013 MGM ACLB TX Off Road
    2016 White DCSB TRD Off Road (Sold)
    Make sure you post some photos once you do it! I've been trying to decide on 255/85s stock or just 265/75s.
  11. Oct 23, 2015 at 12:30 PM
    Ras61
    Ras61 Well-Known Member
    Arlington VA
    '12 4wd TRD Sport Dbl Cab
    Icons front, Bilstiens 5125 rear, 35/12.5/17 MT/Rs and some trimming
    I am using 5125s in the rear with a tsb (Toyota factory AAL basically) and a ToyTec AAL. I'd say it puts me about 2.5 inches over a non-tsb, stock truck. No issues so far, but I don't wheel it super hard (I do hit some pretty bad roads though). The ride is good.
    Like Rattletrap66 said, they don't exactly fit right. I had to cut some of the rubber bushing off to mount them and even then it was a PITA. In your case, I'd go with 5100's back there.
  12. Oct 23, 2015 at 12:54 PM
    NV_Tacoma
    Paul
    Northern Nevada
    Oh I won't haha! I'll be looking forward to it, its going to be a while before I can put some new ones on my baby anyways (hopefully some 5100's as well). My savings is pretty depleted:annoyed:
  13. Oct 23, 2015 at 3:01 PM
    NV_Tacoma
    Paul
    Northern Nevada
    Unfortunately that is the case... The list of mods just keeps adding up!
  14. Oct 23, 2015 at 3:47 PM
    NV_Tacoma
    Paul
    Northern Nevada
    It'll be worth the wait! Which Tacoma did you end up ordering? I'm still trying to decide if I want to do the wheels or tires first once I have some extra $$.
  15. Oct 23, 2015 at 4:06 PM
    NV_Tacoma
    Paul
    Northern Nevada
    Nothing wrong with that at all! It'll still be an amazing truck and it'll leave you more money for the mods. I think the all black wheels look better than the OR's silver and black.
  16. Oct 23, 2015 at 5:31 PM
    NV_Tacoma
    Paul
    Northern Nevada
    You're welcome! I wish the OR had some different wheel options...
  17. Oct 25, 2015 at 7:28 PM
    SSG665
    SSG665 Well-Known Member
    Georgia
    18 Tacoma
    Be sure to post pics when u get it..Interested in the SR myself..
  18. Nov 7, 2016 at 12:10 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
  19. Nov 7, 2016 at 12:16 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    OP did you ever pull the trigger on this? If not, I would highly recommend getting aftermarket coils. You can get a set of OME coils from Headstrong off-road for around $170 and it'll be a night and day difference on the ride quality up front.
    bobrown14 likes this.
