5100 with aftermarket coils????
Discussion in 'Suspension' started by BBBsti LTD, Mar 25, 2011.
  1. Mar 25, 2011 at 12:15 PM
    BBBsti LTD
    BBBsti LTD [OP] Well-Known Member
    Ashburn, VA
    2010 TRD Off Road 4WD
    I thought that the 5100 with Eibach springs were a good combo but after reading the Lift FAQ I am confused. It says that aftermarket coils are not recommended.
    Below the quote from the FAQ.
    "Bilstien 5100's This is a great affordable lift kit. These replacement shocks are great to add a few inches to the front of your Tacoma, it is adjustable and have a slightly better valving system than the stock shocks that come with the Tacoma's. (But please take note NO One recommends it to be used in conjunction with after market coils) This may result in damage of your suspension components."
  2. Mar 25, 2011 at 12:18 PM
    Andy2010
    Andy2010 Well-Known Member
    Andy
    Bucks County, Pa
    2010 TRD Sport Mag Grey 4x4
    EGR inline vent visors, Trimmed front mud flaps, Hose clamp mod, AFE Pro-Dry S air filter, Bed mat off my '97, 5100's up front @1.75, Rear TSB, Tow package, Black TRD center caps, Weathertech Digitals, Wet Okole's in front
    You can use them on the 0 or .85 setting with Eibachs from what I've read.
  3. Mar 25, 2011 at 12:21 PM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    I have them at 0.85" with Eibach coils. No problems at all. I'm switching to OME 886's and 90000 shocks to better support my front bumper and winch though.
  4. Mar 25, 2011 at 12:25 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Toytec's website states the Eibach coils are ok to use with the Bilstein 5100's. There is a debate as to whether or not the OME 884 or 885 coils can be used with the 5100's. They will work, it can just cause warranty issues since Bilstein or OME won't warranty their product unless paired with one of their own products.
  5. Mar 25, 2011 at 12:31 PM
    RecklessTaco
    RecklessTaco Livin the Dream
    Topaz Lake, Nv.
    08 Dbl Cab Prerunner TRD Sport Debadged
    ENGAGE LT KIT, King 2.5x 8" coilovers w/600lb 18"coil springs, a custom built leaf pack in the rear by OMD, and a custom built prerunner bumper by SurfInferno. 35x12.50-17General Grabbers on 17x9 Black MB Wheels rims, Volant CAI w/Amsoil dry filter, Volant Ram Air, Poweraid Throttle body spacer, URD MAF Calibrator, Flowmaster40, Uniden Bearcat cb w/ 4' fire fly firestick antenna, & a Icom V80 Handheld(Modded for race channels)
    If paired with the Eibachs they will still warranty them. Eibachs are the only coils that have been tested with the Bilstien 5100's. So there for they will warranty them. I have called to confirm this! I am running the 5100;s with Eibachs/Toytec coils and i love ot way better than stock and way better than the stupid spacer lift i had originally
  6. Mar 25, 2011 at 12:39 PM
    drewskie
    drewskie Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    I'm in the same boat, I ordered 51 hundos and currently have 884's. Is there any reason it shouldn't work properly? Do the Eibachs provide lift as well, or are they just to accommodate the 5100/?
  7. Mar 25, 2011 at 12:41 PM
    RecklessTaco
    Topaz Lake, Nv.
    They give you 1.6 Inches of lift and then you set the 5100's to .85 to achieve close to three inches of lift.:D
  8. Mar 25, 2011 at 12:42 PM
    RecklessTaco
    Topaz Lake, Nv.
    With the OME 884's you leave the 5100's set at o to achieve the same amount of lift as the Eibach?Toytec coils:D
  9. Mar 25, 2011 at 12:44 PM
    RecklessTaco
    Topaz Lake, Nv.
    Its just that the 884's are more stiffer than the Eibach/Toytec coils. I only know because my buddy Gregero has the 88'4,s and i have the Eibachs.:D
  10. Mar 25, 2011 at 12:45 PM
    RecklessTaco
    Topaz Lake, Nv.
    :DYes i just said that i got right close to 3inches of lift with th Eibachs and 5100's set at .85
  11. Mar 25, 2011 at 2:15 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Bilstein doesn't make coils to pair with their shocks.
  12. Mar 25, 2011 at 2:39 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I don't think this it is a question of will they work. Its a question of how long they will function correctly.
    There seems to be some indication of stiffening ride issues as time goes by. The argument goes, the 5100 are designed for the stock coils which are ~375# coils. The problem is the toytec eibachs are 620# coils, way stiffer than stock.
    So far this is mostly anecdotal information so it may or may not happen to all.
  13. Mar 30, 2011 at 7:43 PM
    drewskie
    Drew
    Burbank, CA.
    Im still confused....so can I use the 884's with theh 5100's?
  14. Mar 31, 2011 at 4:27 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Yes, if you set them at "0".
    Whatever combination you choose, don't go over 3" of total lift and you'll be alright.
  15. Mar 31, 2011 at 4:38 AM
    Pugga
    Massachusetts
    Did say they did... I put a link to Toytec's website where they state that the Eibach coils are acceptable to use with Bilstein shocks, including the OEM shocks.
  16. Mar 31, 2011 at 4:03 PM
    drewskie
    Drew
    Burbank, CA.
    cool, and if i set them at zero, that should give about 2 inches of lift? I am going to remove the spacer that came with the toytec kit.
