5100 with what AAL?
Discussion in 'Suspension' started by matt86, Feb 4, 2010.
  1. Feb 4, 2010 at 6:32 PM
    matt86
    matt86 [OP] Well-Known Member
    NC
    2008 Tacoma SR5 4x4
    I have 5100's waiting to be installed and I am going to set them at 2.5 inches. Which add a leaf should I go for to level it out? The Toytec 1.5" or the 2.0"? I have searched but it is hard to tell if the pictures most people are posting are with or without the TSB. I do not have the TSB so I am thinking the 2.0" one would work best and leave me just a slight rake. I will be installing them with the factory TRD offroad shocks in the rear. Thanks
  2. Feb 5, 2010 at 11:55 AM
    matt86
    NC
    2008 Tacoma SR5 4x4
    Nobody has any pictures with a 2 in toytec add a leaf?
  3. Feb 5, 2010 at 11:57 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Measure the rear, and the front and see how much higher the rear is. Then factor in the front lift. See how much you need to lift the rear to have it level, or a little rake. Most trucks get by with the 1.5" to level. I wouldnt use the OEM shocks with any rear lift though. Get some 5100's for the back too.
  4. Feb 5, 2010 at 11:58 AM
    jonny
    jonny Betty White Edition Heep ZJ
    i think the 1.5 aal will do the trick. or..have the tsb leafs installed :thumbsup:
  5. Feb 5, 2010 at 11:58 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I've gotta 1.5" AAL with my no TSB...
  6. Feb 5, 2010 at 12:01 PM
    matt86
    NC
    2008 Tacoma SR5 4x4
    Are you running the 5100's in the front at 2.5? Thanks
  7. Feb 5, 2010 at 12:06 PM
    jonny
    i believe Scotty has a 3" strut spacer w/LR uca's. :thumbsup:
  8. Feb 5, 2010 at 12:07 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
  9. Feb 5, 2010 at 12:18 PM
    matt86
    NC
    2008 Tacoma SR5 4x4
  10. Feb 5, 2010 at 12:20 PM
    kinkrider101
    santa barbara
    wheels and tires
    i just went ahead and got the 1500 pack at dsm for like 280 bucks
  11. Feb 5, 2010 at 12:38 PM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    check with toytec if that's where you get the aal. from past conversations I had with Darrick @ toytec, the aals are specific to the leaf pack you have. If you had the tsb done, the 2" aal doesn't fit, I believe. If you have the 3 leaf pack, a 2" aal will fit.
  12. Feb 5, 2010 at 12:42 PM
    kinkrider101
    santa barbara
    wheels and tires
    they told me that the 2'' or l.5'' tsb aal would fit, i got the 1.5 even though i dont have the tsb done.
  13. Feb 5, 2010 at 1:13 PM
    matt86
    NC
    2008 Tacoma SR5 4x4
    They told me that both would work but to go with 1.5 to level it out with the highest setting on the 5100's. I might just go with the 2" ones and keep a little rake. Are there any other disadvantages to running the stock shocks besides a rougher ride?
  14. Feb 5, 2010 at 2:09 PM
    matt86
    NC
    2008 Tacoma SR5 4x4
    Well I just sucked it up and ordered the 2 in add a leaf from ToyTec. Thinking about ordering the 5100s for the rear too from wheelers offroad but still on the fence about doing it now or later. I think I'm going to see how it performs without them first as I won't be doing a lot of wheeling.
  15. Feb 5, 2010 at 2:10 PM
    kinkrider101
    santa barbara
    wheels and tires
    get the 5100 set from dsm you will get a discount
  16. Feb 5, 2010 at 8:09 PM
    matt86
    NC
    2008 Tacoma SR5 4x4
    I already have the fronts... I think I'm going to pick up the rear ones down the road a bit. I'll take pics when its all installed
  17. Feb 5, 2010 at 8:24 PM
    kinkrider101
    santa barbara
    wheels and tires
    ok cool are you using the stock coil.
  18. Feb 5, 2010 at 8:27 PM
    Inked Tacoma
    Inked Tacoma GOT INK?????
    Jeremy
    Central Coast Cal
    2019 Tacoma TRD Sport DCLB
    2019 Tacoma TRD Sport DCLB De-Badged, Tent done Coming soon Bilstein set at 2 inch fronts rear 1.5 AAL 17 inch wheels and 265 BFG AT..... Speaker replacement sub and amp and of course window tent! Gone but not forgotten 08 Prerunner TRD Rugged Trail ICON Coil-overs/2.5 V.S. Series Remote Resi Shocks ICON Uni-Ball arms Camburg lift spindles ( Removed Swaybar) Dever 3 inch Lift Springs & Flip Kit, KMS XD Enduro 16x8 258/75 Mickey Thompson BAJA ATZ TRD Cat-Back Tint 30% side/Limo in back. The one that started it all 1999 Tacoma Preunner 6 inch Fabtech drop-bracket with custom kings all the way around AllPro 5 inch springs 35's custom paint and one bitch-en Alpine seystem for sound!!!
    Billys at 2.5 and a 1.5 AAL... I think to would be to much front rake (stink Bug) look....
  19. Feb 5, 2010 at 8:39 PM
    kinkrider101
    santa barbara
    wheels and tires
    i have 3 up front and 1.5 im rear and it was nose high but now its level.
  20. Feb 6, 2010 at 5:29 PM
    matt86
    NC
    2008 Tacoma SR5 4x4
    Your truck looks pretty level like that. I think it will end up looking about like factory as far as the rake goes... Just higher.
