5100's @ "0" and Eibachs w/ (1) 1/4" spacer
Discussion in 'Suspension' started by Gabe911, Feb 1, 2012.
  1. Feb 1, 2012 at 9:32 AM
    Gabe911
    Gabe911 [OP] Well-Known Member
    FLORIDA
    10 PreRunner MGM
    Debadged, Rear TSB, Blue LED dome and Bright White Map Lights, Hard Top Tonneau Cover, OME885 coils (no top plate spacers)OME shocks and struts, 1.5" AAL for TSB Rear,285/70/17 Trail Grapplers, 17x9 XD Addicts with 4.5 bs, Black 4" exhaust tip, Bed pocket lights, rear diff breather Mod
    I am getting different numbers with this set-up. On a dbl cab 2wd is there anyone that has this and got 1.75 or is it closer to 2.15" due to the 1/4" spacer on the driver side. I have the TSB and want to be a little higher in the rear .5" is fine?? anybody have this set-up?? Thanks
    Eibachs = 1.6"
    + (1) 1/4" spacer would be total 2.10 ????
  2. Feb 1, 2012 at 11:56 AM
    Gabe911
    FLORIDA
    10 PreRunner MGM
    Great appreciate the info...currently after the tsb I am 2.5 inches higher in the rear so I would still be rear higher after the eibachs and 5100's 0...probably with about .5" rake ...sounds right?
  3. Feb 1, 2012 at 12:05 PM
    Gabe911
    FLORIDA
    10 PreRunner MGM
    gotcha will end up getting AAL...thanks
