5100s and rear spacer
Discussion in 'Suspension' started by RyanK1, Oct 6, 2011.
  1. Oct 6, 2011 at 11:16 PM
    RyanK1
    RyanK1 [OP] Well-Known Member
    Penticton, British Columbia
    2006 Tacoma TRD Sport
    Bilstein 5100's @ 2.5, TSB rear with block spacer, Procomp ES9000's, CBI Moab 2.0 front bumper, swaybar removed, DIY HiLift mount, Rear diff breather mod, ABS Kill Switch, Flowmaster 40 series muffler, Superwinch 8500
    I am currently running a Revtek spacer lift and was looking into dumping it and picking up some billys. Looking to save myself a bit of money, could I just get them up front, set them to 2.5" and leave the rear spacer and ranchos.
  2. Oct 6, 2011 at 11:21 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    yes, you could. by rear spacer you mean blocks right?
  3. Oct 6, 2011 at 11:22 PM
    RyanK1
    Oh yes sorry, an aluminum block with a 4 leaf pack.
  4. Oct 6, 2011 at 11:30 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    if your shocks are long enough and are working now, then they'll be fine when you change the front.
    A lot of members on here are gonna tell you to change those blocks though, there's better rear lifts out there :D
  5. Oct 7, 2011 at 5:54 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    You would have to remove the leveling kit front the front if you are setting the billys above zero.
  6. Oct 7, 2011 at 12:34 PM
    RyanK1
    Yeah I figured most people would say ditch the rear block, but as of right now I cant afford billys on all corners. KPT, that was the plan, ditch the spacer up front and set the 5100s to 2.5"
  7. Oct 16, 2011 at 1:59 PM
    RyanK1
    Just a little update: 5100's on the way, excited to get those revtek hockey pucks outta there. Thanks to downsouth motorsports.
  8. Nov 10, 2011 at 8:02 PM
    tommytacoma
    tommytacoma MEMBER
    Tommy
    New Jersey
    2005 Toyota Tacoma TRD Off-Road
    -Bilstein 5100's all around, OME 885's, Toytec 2inch AAL, Toytec 1/2 top spacer -265/75/16 General Grabber AT2 Tires -Gibson Exhaust -K&N Intake -Front lightbar with KC Off-Roaders -Throttle Body Spacer -Wires and plugs -Stereo
    HEY BRO LET ME KNOW HOW THE TRUCK LOOKS WHEN YOU LOSE THOSE HOCKEY PUCKS AND PUT IN THE BILLIES AT 2.5! I AM THINKING OF DOING THE SAME SETUP, I JUST WANT TO MAKE SURE I'M NOT GONNA GET LESS LEFT WITH THE BILLIES!!
  9. Nov 10, 2011 at 11:33 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Prob still going to ride the same as it did with the spacers. The springs are still preloaded to 2.5"! Most dudes get a diff/longer coil designed to handle some preload......eibachs will give you 1.5" and set the 5100's at .85" and you're set! For rear you could get a 1.5" aal (toytec $79) and keep the shocks in the rear until you upgrade! Ultimately depends on your budget and still better than spacers. Good luck!
  10. Nov 11, 2011 at 5:45 AM
    KPT
    09 Prerunner
    But the billy's are valved to properly dampen the preload, while the stock shocks are not. The ride will be better with the 5100's than with a spacer lift and stock shocks.
  11. Nov 11, 2011 at 9:24 AM
    ponethousand
    ponethousand Well-Known Member
    Paul
    Virginia Beach
    04 trd dc limited
    regeared, locked, armor, and stuff
    I just ordred 5100's for the front with the eibach set up. Ditching the same lift. I currently have the revtech lift and getting rid of the hockey pucks! I am keeping the 2" block in the back until I decide to either aal or whole new leaf back. Budget was my issue. If it rides like junk then I'll most def get either leaf set up soon. Good luck!
