5100s AND spacers?
Discussion in 'Suspension' started by Snake~, Jan 19, 2012.
  1. Jan 19, 2012 at 10:36 AM
    Snake~
    Snake~ [OP] Big Member
    Blake
    DFW
    2010 DCSB TRD Sport
    Autolumination Yellow fog light bulbs, Dynomax Ultra Flo muffler, AFE Pro Dry S air filter, tailgate security mods, TRD skid plate, DeeZee bed mat, Armor Lid tonneau, OEM roof rack, TRD center caps, Satoshi grille, Sockmonkey tailgate decal
    Tell me if this makes sense or if I'm way off base...
    Setting 5100s at .85 or 1.75 or 2.5 preloads the springs and stiffens the ride. True?
    Adding top plate spacers above the shock assemblies does not preload the springs or stiffen the ride. True?
    So if you install ToyTec's and set 5100s at 1.75 with stock springs, wouldn't you get 2.5" of lift with a slightly softer ride compared to setting 5100s at 2.5 with no spacers?
    All this lift geometry stuff makes me :confused:
  2. Jan 19, 2012 at 10:38 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You are corrct. Some companys like Pro Comp, offer a "split" type lift, giving half the lift via preload spacers, and the other half top plate spacers.
  3. Jan 20, 2012 at 11:15 AM
    Snake~
    Blake
    DFW
    2010 DCSB TRD Sport
    Cool, thanks Chris
  4. Apr 27, 2012 at 7:34 AM
    Snake~
    Blake
    DFW
    2010 DCSB TRD Sport
    Another question: Will doing a split lift to get 2.5" of lift help with getting the alignment within spec as opposed to just setting the 5100s at 2.5?
  5. May 24, 2012 at 5:51 PM
    lohrryan
    lohrryan Member
    patrick
    Texas
    06 TRD offroad blacked out
    3" lift, spc upper control arms, extended rear brake lines, aux port mod, AFE throttle body spacer and cold air intake , flowmaster cat back exhaust vsc/trac disable mod
    hey just wondering if you got your alignment done and if splitting your lift helped it any
  6. Jul 9, 2012 at 11:24 PM
    Redtaco704
    Redtaco704 Well-Known Member
    Jon
    Charlotte, NC
    05 DCSB 4x4
    Bilstein 5100's all around, Pro-Comp AAL, Pioneer in Dash DVD, Image Dynamics Component speakers, Custom 10" sub enclosure
    Wouldn't a 1/4" top plate spacer and the bilsteins set at 1.75 get you 2.25 of lift? Has anyone done this? I know the truck doesn't handle that well with them set at 2.5 so is this a option for someone wanting a little more than 2 inches in the front?
  7. Jul 9, 2012 at 11:26 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    5100 @ 1.75 plus 1/4" toytec top plate = 2.25" lift. Perfect for me
    also, stock UCAs and perfect alignment
    rides great, nothing notable, only been beat on hard a handful of times thus far but handles great on and off road. its a great height if you ask me
  8. Jul 9, 2012 at 11:27 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    awesome! ^
  9. Jul 9, 2012 at 11:30 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Of note, 1.5" 3 leaf progressive AAL plus stock OL = roughly 2", just shy
  10. Jul 9, 2012 at 11:31 PM
    Redtaco704
    Jon
    Charlotte, NC
    05 DCSB 4x4
    Perfect! Just what I wanted to hear. Got the 5100's on the way now just need to get the spacers. Thanks!
  11. Jul 9, 2012 at 11:32 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    no problem
    also, for thorough reference, those are 265/75r16s
  12. Jul 9, 2012 at 11:45 PM
    Jib Bandits
    Jib Bandits Pork eating crusader. An "infidel".
    Ari
    Cedar Fort, UT
    06 Access TRD Sport
    Red devil horn emblem, All-Pro Expo leafs, Fox shocks, K&N CAI, aFe throttle body spacer, Flowmaster american thunder dual exhuast, Defender roof rack, Hell Bent steel level kit, Rigid Dually LED lights, smoked halo headlights, smoked LED taillights, Cobra CB, red badge mod(+30 HP), Spider-Trax wheel spacers!
    Also wondering this myself... I just got some fox ext. 2.5s but don't wanna max em out at three. I just have a spacer leveling kit on top of the stock shocks right now but.... Could I use those in tandem with the fox shocks dialed lower? My thought process is that it wouldn't really be good with the off roading I do but I'm ready to try anything short of a drop bracket lift to get my 33s to stop rubbing :( I already trimmed the hell out of my fenders and did a cmc :crapstorm:
  13. Jul 9, 2012 at 11:55 PM
    Redtaco704
    Jon
    Charlotte, NC
    05 DCSB 4x4
    Looks to me like the access cabs rears are a little more raised than the double cabs so I wonder if the 1.5 AAL I was planning on getting will work out the same as yours.
  14. Jul 10, 2012 at 12:04 AM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    I have Wheeler's progressive AAL plus the stock overload is around a 1/2" thick-ish
    Keep in mind I like a truck to have some rake, as you can see. Your aal should be good, most people seem to be aiming more for level. I don't like level unless I'm loaded down
