5100's and TSB
Discussion in 'Suspension' started by deepseadiver, Apr 7, 2010.
  1. Apr 7, 2010 at 3:34 PM
    deepseadiver
    deepseadiver [OP] Well-Known Member
    william
    Norfolk, VA
    2010 prerunner
    Borla Exhaust Debadged AFE Pro Dry S Drop in
    To do this do i just bring my truck to the stealership and tell them. i bought my truck 3 weeks ago so does that mean they are sending the trucks out with the rear end already fixed. should i just bring them a pair of 5100's and tell them to install them set at 1.75 and fix the rear end?
  2. Apr 7, 2010 at 4:01 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Say this: "The ride is very harsh and the rear end bottoms out under small loads."
    And yes, do it all at the same time: alignment is free after the TSB and you'll need one after the front 5100's anyway so kill 2 birds.
  3. Apr 8, 2010 at 7:40 AM
    deepseadiver
    william
    Norfolk, VA
    2010 prerunner
    so if i do that how much actual lift will i get? a few inches? what size tires can i put on after front 5100's set at 1.75 and the rear tsb?
  4. Apr 8, 2010 at 11:14 AM
    nvdeserted
    Reno, NV
    You'll be about 1.5" higher. You can fit 265/75-16 tires, about a 32" tire.
  5. Apr 8, 2010 at 8:09 PM
    ComeOnToIt
    ComeOnToIt Member
    Northern New Hampshire
    '10 DBL.CB. TRD OR & '07 DBL.CB. SR5 4X4
    Bilstein 5100's- front, Rear spring TSB, Toytec 1.5" AAL, Goodyear Duratracs, Extang Trifecta Signature Series Tonneau
    Be careful about what the dealership will charge you to put your own parts on. They wanted to charge me over 300.00 to put mine on after doing the rear TSB.
    I have scheduled my local 4X4 garage to put mine on next week for 100.00, then the next day the rear spring TSB is scheduled- and I'll get the needed alignment done with that.
  6. Apr 9, 2010 at 1:30 PM
    razortaco
    razortaco Well-Known Member
    Houston, Texas
    2010 Black PreRunner TRD Off Road
    Bed Pocket Lights, Carriage Works Billet Grille, Aries Bull Bar with Warn Off-Road lights, Valor Exhaust Tip, OEM Tube Steps, OBX Sport Pedals, Stubby Antennae
    So has anyone else gone this route with adding the 5100s to the front only with the rear spring TSB? I'm thinking about doing this on a 2010 TRD off-road double cab. Did the dealer give you any trouble with swapping out the front shocks for you since the TSB does not technically cover removing the stock shocks in the TRD's case? How much did they charge you? Love this place - best source of information out there!
  7. Apr 11, 2010 at 4:38 PM
    Fistgar
    Fistgar Off-Road Limo
    Chance
    Denver, Colorado
    2010 TRD Sport LB 4x4 MGM
    Satoshi grille, painted engine cover, 20% tint on windows, OME 3" Lift, TSB in the rear with ToyTec AAL, , tinted tails, Hella 500's. 1" body lift
    Bump
    I'm curious about razortaco's question as well!
  8. Apr 11, 2010 at 5:16 PM
    Blue76
    Blue76 Well-Known Member
    Georgia
    08 Prerunner Double Cab
    Dealer installed Leather, Truck Cover USA roll up cover, Pop n Lock, Bilstein 5100's on 4 corners set at 1.75, Rear Spring TSB. USA Spec iPhone adapter, 265/75/16 Mickey Thompson ATZs.
    I did this... See before and after photos with measurements in my profile photos.
    I only got about 1" of lift fron the TSB... I have the 5100s set at 1.75 and it is pretty level. I am considering adding 1 to 1.5" of lift to the rear because I like the factory rake to the front. Just not sure how I want to do that yet.
    The dealership put the 5100s on all 4 corners while they did the TSB for $160.00.
    When I first had it done I had the stock tires... I bought new Mickey Thompson ATZs in 265/75/16 and now I have a noisy tire on the road and the steering is a little squirrly around big trucks and uneven lanes... After reading up on this I wonder if the dealership really did the alignment or if they used some kind of factory settings that did not take into account the 1.75 lift in the front. I am planning on taking it somewhere else to get the alignment checked.
    Overall I like the look of the truck with the 265s and I love the look of the tires but they are pretty noisy for an AT tire. I wish I had went a different route on the tires. The ride quality is good.... not harse or stiff like I was worried about. If my tires were quieter and the steering was more sure I would be thrilled.
    I just hope I dont need UCAs to correct the steering.
    Greg
  9. May 6, 2010 at 2:34 AM
    Scarab21
    Scarab21 Well-Known Member
    Tint, tinted tails + 3rd brake light, shaved tailgate, painted calipers. TSB Leafs+ AAL, PA/CB, 5100 Bilsteins set @ 2.5 up front. Satoshi line-x'd grill.
    bump...
    i wanna get 5100's and put 32"/33" tires on my stock 17" rims.. what tire size/specs should i get?
    Im looking for an inexpensive but meaty looking tire.. any suggestions?
  10. May 6, 2010 at 4:02 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Check your caster settings, that is what the wandering twitchy steering is. Most don't have issues with caster unless going 2.5 or more. My 5100s are set on 2.5, had the caster issues and LR UCAs fixed all that. Just save up and do it is my suggestion if the caster cannot be set right. They are beefier than the oems, worth it IMO. Also pay for lifetime or at least a year alignment thing so you can have it aligned for free afterwards every so often. Comes in handy when adding suspension mods down the road too.
  11. May 6, 2010 at 4:04 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    IIRC, 285/70/17 should put you in that range but as far as inexpensive AND meaty???? keep saving because those 2 things don't come together.... depending on your definition of inexpensive.
  12. May 6, 2010 at 7:49 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    This size will look good but keep in mind you will need wheel spacers to run 285's on the stock rim.
  13. May 7, 2010 at 3:47 AM
    Blue76
    Georgia
    Not sure where you are located but I have brand new Mickey Thompson ATZs on mine I would sell... I gave $900+ for them... would take $750... I have put about $150 miles on them. I drive too much interstate for them.
    Very good looking "beefy" tire.
    I am in North Georgia
    Greg
