5100's at 1.75" and 2" aal level?
Discussion in 'Suspension' started by xGManx, Dec 14, 2010.
  1. Dec 14, 2010 at 5:54 PM
    xGManx
    xGManx [OP] Well-Known Member
    Garrett
    South
    06 DC LB
    black rims, blacked out grille, blacked out exhaust tip, 5100's 1.75" with 2" rear block, pioneer head unit
    i have 5100's set at 1.75 in the front and stock in the back, its a little high in the front so i want it to be level without losing the height in the front. will a 2" aal level it or will that be too much? what do yall suggest to solve this problem?
  2. Dec 14, 2010 at 5:55 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    1.5 aal might level it..but might have rake
  3. Dec 14, 2010 at 5:58 PM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    What are the front/rear measurements from the ground through the hub to the wheel arch? I also think a 1.5" AAL would be better.
  4. Dec 14, 2010 at 6:01 PM
    xGManx
    Garrett
    South
    06 DC LB
    ehhhh im not 100% sure on the measurements, i thought 1.75" would level it but i mismeasured by like .5", is the toytec 1.5" aal a good product? ive been reading and it seems quite a few peope have it
  5. Dec 14, 2010 at 6:02 PM
    kinkrider101
    santa barbara
    wheels and tires
    i like my toytec 1.5 " aal. it does the job good..and does not make noise either
  6. Dec 14, 2010 at 6:10 PM
    xGManx
    Garrett
    South
    06 DC LB
    i also have this question, my rear springs squeak and sag and bottom out with 500 lbs just like the TSB says, it an 06 and i only have 29,000 miles on it. ive owned it for 2 years, does it qualify for the TSB? would the TSB level my truck? and i also just read a post that a guy has his 5100's set at 2.5" and the TSB brought it up to level so could i raise my shocks too?
  7. Dec 14, 2010 at 6:17 PM
    kinkrider101
    santa barbara
    wheels and tires
    yes i believe it might..i had the sama problem..i would bottom out with no load..now i never bottom out, even when towing 2 quads a dirtbike and a trailer plus camping gear
  8. Dec 14, 2010 at 6:32 PM
    Fabulous
    Fabian
    Calgary, AB
    Talk to your dealer to see if they will do the TSB... if not, snag a 1.5" Toytec AAL. I have a 2" one and they are a good product for the $. My leafs used to squeak a bit, but when I put my AAL in I cleaned the stock ones up real good, and put some grease on the pads... no more squeak.
  9. Dec 15, 2010 at 12:26 AM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    Billies at 1.75 with Toytec 1.5 aal w/ 5100's. This setup keeps the factory rake. It looks more raked in the first picture because it is parked on a hill. It hauls so much better now, hardly ever bottoms out any more unless I really load it down.
  10. Dec 15, 2010 at 2:11 AM
    808Raider
    808Raider Well-Known Member
    hawai'i
    the tsb is basically a free aal so if you qualify and can get it than go for it. you might have an issue having already altered the suspension with the bilsteins (maybe not if you only did the fronts) depends on your dealer, but a copy of the actual document is somewhere on here if you search for it. I have had the tsb aal done and my bilsteins set at 1.75 in my access cab and its pretty much leveled out with just a hair of a rake once the leaf springs settled. i think though the double cabs come stock with a less rake than the access cabs (or so it appears maybe long vs. short bed) so it should level with your truck. you can always measure the rear height with a tape measure and jack it up 1.5 inch vs. 2 inch too to see what you like better. thats what i did with my bilsteins when deciding whether to go 1.75 vs 2.5 on my front bilsteins.
  11. Dec 15, 2010 at 7:15 PM
    xGManx
    Garrett
    South
    06 DC LB
    yeah thats what i did for the front, i have the long bed too and only the front 5100's so i hope i qualify for the TSB, you think with the 5100's at 1.75" in front and TSB itll be level?
  12. Dec 15, 2010 at 7:21 PM
    BAP_29
    BAP_29 Well-Known Member
    Ben
    North Carolina
    05 Prerunner DC TRD Sport
    Bilstein 5100s at 2.5" and Toytec 1.5" AAL Eagle Alloy 063 Wheels on 285/60/18 Cooper Zeon LTZ tires Alpine iDA-X305 Head Unit MB Quart DKD 116 Discus-Line 6.5" Front Speakers (Baffles by Marv) Alpine 6-Disk CD Changer Toyota All-Weather Floor Mats Kobalt Low-Profile Toolbox 13" Wicked Flow Muffler w/ Chrome Tip
    I received my Toytec 1.5 inch AAL today to be installed with 5100s set at 1.75. I dont have the TSB AAL either, so Im counting on this setup to give me what I want
  13. Dec 15, 2010 at 7:51 PM
    docbrown
    docbrown Well-Known Member
    Tampa, FL
    05 Tacoma SR5 4X4
    Doug Thorley Long Tube Headers, Eclipse 6620 AVN GPS/DVD, K&N Drop-in Air Filter, Hose clamp mod, Redline Quick Lift Elites, Bilstein 5100's at .85, Firestone Ride Rite Air Bags, Weather Techs front and back, Bug Guard, and Factory Bull Bar, Wet Okole's up front, Bed Mat, LED interior lights, Fumoto Oil Valve
    I have that exact set up (5100's @1.75 and a Toytec 1.5 AAL) with a 2005 DCLB. I wound up with 24 1/2" Rear and 22" Front measured from the center cap. Pretty close to factory rake. Just an FYI - don't use the shims like I did - you shouldn't need them.
