5100's at 2.5 ..... How many ran into issues?
Discussion in 'Suspension' started by SandyEggo, May 9, 2010.
  1. May 9, 2010 at 10:12 AM
    SandyEggo
    SandyEggo [OP] Member
    So Cal
    2013 Prerunner SR5 access Cab
    I'd like to put the front at 2.5 and see what happens but am hesitant to waste time and money if there is an alignment issue or rubbing. Some say they are good to go, some say they should have started at 1.75.
    Whats the verdict here?
  2. May 9, 2010 at 10:33 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    2.5 no rubbing but ...your alingment will not be perfect
  3. May 9, 2010 at 10:40 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Your probably going to need new UCA's to get your alignment in spec.
  4. May 9, 2010 at 11:24 AM
    blackwatertaco
    blackwatertaco If you ain't stuck, You ain't tryin hard enough.
    Jay
    Alvin/Pasadena, Tx
    08 taco, 4x4 2.7 5spd.
    One fucked up diff. breather mod, 265/75/16 Destiny Dakota M/T Black gulf states rims BHLM Magnaflow 14" muffler with cut off tail pipe. 10" pioneer slim truck sub with JBL 600W amp. PROJECT BLACK OUT
  5. May 13, 2010 at 7:24 PM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
  6. May 14, 2010 at 1:01 PM
    562Tacoma
    562Tacoma Well-Known Member
    Southern, CA (SoCal)
    08 PreRunner TRD Off Road 4x2
    -Maxtrac 4in lift spindles -5100's all the way around -Drilled and slotted rotors with ceramic break pads -Pro comp 1in AAL -17in wheels with a -6 offset (4.5 backspace) -1 - 10inch kicker comp (ported box)
    I am looking into purchasing the 5100's as well and have been looking for feed back I would also like to run them at the 2.5 height but am werry of what the consequences might be ... My main concern was the alignment, does anybody on here have the 5100's and had any problems running them at that height? Your input would be appriciated...
  7. May 14, 2010 at 9:27 PM
    SandyEggo
    So Cal
    I ended up doing 1.75 and with the rear tsb 4 spring it sits close to level. I put on 265.75.16 BFG AT's and it dialed in perfect on alignment. No vibes, wobble, or any issues as of now. Im stoked it worked out well.... not too sure if going 2.5 would have been trouble free.
  8. May 15, 2010 at 12:00 AM
    Htnswches
    Htnswches Well-Known Member
    E
    Lost Angels
    2006 Precummer Tacoma
    310,000 and counting
    I have the same set up and works great for me too. Post pix
  9. Oct 6, 2010 at 4:52 PM
    eddieEndo
    eddieEndo Well-Known Member
    Eddie
    Fullerton, CA
    Scion FRS
    get the billstein 5100s and set them at .85 combine them with 1.65 eibach or old man emu lift springs and you'll have 2.5!! no issues no nothing
  10. Oct 7, 2010 at 9:25 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    Yup...I put my new 5100's at 1.75" and did not have a problem getting in to align. My truck sits perfectly level with just the TSB 4 spring pack.
    It was also NO rougher of a ride than my stock TRD Sport Billies.
    I put some 265/70/17's under it and am very happy!
  11. Oct 7, 2010 at 3:57 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    I had the 5100s set at 2.5 and the tires were slightly bowed in after the alignment. Like this but not as extreme. \ /
    It was noticable when looking at the truck from the front. I'd set them at 1.75. I have UCAs and the Toytec adjustable coilover now so it's not an issue.
  12. Oct 7, 2010 at 4:09 PM
    raswank
    raswank Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    so 1.75 with the tsb will pretty much level it?
  13. Oct 7, 2010 at 10:10 PM
    SandyEggo
    So Cal
  14. Oct 7, 2010 at 10:20 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    I did 5100's a few weeks ago and set them at 2.5. install went great and the alignment shop said that the alignment was all-in-all pretty close to spec. also i had no vibrations afterwards.
    I say go for it
  15. Oct 8, 2010 at 6:20 AM
    Veccster
    Veccster bass turds
    Eric
    2020 Pro
    ^ nice...do you think "pretty close" will cause any long-term issues? Maybe some uneven wear on the tires? Maybe some light drifting at higher speeds?
  16. Oct 8, 2010 at 6:30 AM
    Evil Monkey
    Robert
    Escondido, CA
    Some have complained of a drifty feel at 2.5". Mine did not feel drifty. I didn't have mine setup like that long enough to notice any tire wear issues (I got into a Toytec Group buy that got me a good deal on the adjustable coilovers and the Light Racing UCA).
  17. Oct 8, 2010 at 6:36 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    On 2.5 the camber and toe can still be set right and those 2 are what wears tires. The caster is gonna be low and truck will feel skiddish on grooves and uneven pavement. It is annoying but will not wear the tires, just your last nerve. LR UCAs are about 450, others are higher. The LR UCAs will give additional camber and caster adjustability. They will allow you to get caster back to 2.4 or more so the skiddish feeling wandering crap goes away. I have prerunner so no issues with driveline vibrations or CV angles. You can do lift then save up for UCAs without damaging anything except your last nerve, lol. Worth it IMO. Just get a 1yr, 3yr or lifetime alignment somewhere that knows what their doing and then get free alignments as you change stuff or every so often just to keep it good.
  18. Oct 8, 2010 at 8:07 AM
    Veccster
    Veccster bass turds
    Eric
    2020 Pro
    Interesting...thanks.
    Unless it was necessary to clear bigger tires, I would recommend setting at 1.75" until you save up for the UCA's. Wandering and skiddish are not terms I would define as "safe" in a vehicle that can kill you or innocent bystanders instantly. Its nice to think that you'll be aware of your surroundings and will not allow it to drift off center. But it only takes a split second of NOT being aware to do life altering damage.
    Once you get the UCA's, you have to rip things apart anyway. Move up to 2.5 at that time and get it realigned. The only downside is needing a spring compressor again. But many "back-alley" shops will do it for just a few dollars anyway. I paid $10 for a guy to do both on a wall mounted compressor.
    If you're getting 33's though, you'll need the clearance and need that 2.5.
  19. Oct 8, 2010 at 8:39 AM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    possibly, but im not too worried.
  20. Oct 8, 2010 at 2:33 PM
    DesertRatOffroad
    DesertRatOffroad Well-Known Member
    We install this set up all the time in our Tempe store and just today put some up to 2.5 for customer that had us set them at 1.75 when first installed. We did not have any issues with rubbing.
