5100's expert help please!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xwillx93, May 8, 2011.
  1. May 8, 2011 at 2:06 PM
    xwillx93
    xwillx93 [OP] Well-Known Member
    Will
    Stuart, FL
    09 Tacoma
    MBRP "Cool Duals" dual side swept exhaust, Volant Intake, Blacked Out Tail lights, Touchscreen Kenwood DDx616 with a 10" Kicker CVR in a custom Box, 2 Kicker Comp 6" Speakers, Removed front and rear mud flaps, Weathertech Floormats, Kobalt Slim Toolbox, Chevrolet Air compressor
    09 reg cab, super white, 2.7l 4 banger. I want a lift to comfortably fit 33's and am resulting to the bilstein 5100's for ride quality too.
    I have a list of questions before i purchase these guys:
    1. how big can i set them before i have to get new UCA's?
    2. at that height, can i fit 33's without trimming?
    3. If trimming is necessary, does anyone have a link to a thread with trimming instructions? i cant seem to find any :(
    4. if anyone had any experience with the 5100's, please share!
    here she sits now!
  2. May 8, 2011 at 2:59 PM
    xwillx93
    Will
    Stuart, FL
    09 Tacoma
  3. May 8, 2011 at 4:41 PM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    you can set them at 2.75 w/o going with new UCA's although your truck will perform better with new UCA's. With the 33's you will probably need to re-gear from 410 to 456 if you stick with 32's you should be good with 410's
  4. May 8, 2011 at 4:42 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    You will need to trim and chop the cab mount. You can chop the cab mount with a $20 grinder with a cut off wheel in it.
    Boxing it back in is recommended but not a necessity. Any monkey with a mig welder can do that.
  5. May 8, 2011 at 5:00 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    5100s are only adjustable up to 2.5"...not 2.75
  6. May 8, 2011 at 5:01 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    You are correct sir.
  7. May 8, 2011 at 6:35 PM
    xwillx93
    Will
    Stuart, FL
    09 Tacoma
    thanks guys. i think i might just go with setting the billys at 1.75" and gettin some 33" BFG muds. because im hearing at less than 2" i dont need a new UCA right away. time to trim it up!!!
  8. May 8, 2011 at 6:38 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    i dont think that you can fit 33's with only 1.75" lift. not even with 3 inches unless you do some chopping
  9. May 8, 2011 at 6:46 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    dude you won't need new UCAs if you stay at 2.5" or under...
    and 33" tires WON'T fit with only 1.5" of lift...you'd have to do ALOT of cutting!
  10. May 9, 2011 at 3:40 AM
    xwillx93
    Will
    Stuart, FL
    09 Tacoma
    I spoke with beef taco no rice and he fit 33's with only a leveling kit and a little trimming?
