5100s for 2016 3rd Gen Tacos
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 619HiluxLover, May 19, 2016.
  1. Jan 1, 2021 at 7:05 AM
    #481
    wingsformyway
    wingsformyway Well-Known Member
    Alex
    Vancouver Island, BC, CA
    2021 Tacoma TRD Sport DCSB 6MT Cement Grey
    Blackout badges & tailgate inserts; interior blackout (vinyl)
    I have yet to find a direct answer to this question.
    I initially wanted to level my third gen, and research led to the recommendation of 5100s, which I found out are adjustable. I figure if the rear can go +1" with help of a spacer/block and the fronts do +1,75-2" on the top setting, I should be able to get a leveled truck at +1" lift over stock? or maybe a very slight rake (mine seems worse than the third gen OR I had before this Sport)?
    I don't want to break the bank or go crazy. I simply figure get the extra inch if it's doable with this setup for slightly (32-32,5s) larger tires as I plan to replace wheels and tires as well.
    Thanks
    71tattooguy likes this.
  2. Jan 1, 2021 at 10:06 AM
    #482
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    You could do 4th setting and a 1 inch rear block would look great. Alignment should be good. 32’s will look great as well
  3. Jan 1, 2021 at 10:15 AM
    #483
    wingsformyway
    Alex
    Thank you! That's exactly the kind of answer I was looking for. I hate posting without searching first. Often, I can find what I need and I learn so much from searching; however, after awhile things get muddy and confusing, especially when tackling tire and wheel research at the same time. This is also my first on any of these fronts so really, thank you and everyone else for your responses, help and dialogues
    71tattooguy[QUOTED] likes this.
  4. Jan 1, 2021 at 10:17 AM
    #484
    71tattooguy
    Dino
    Petaluma , Ca (707)
    No problem glad I could help
  5. Mar 19, 2021 at 8:18 AM
    #485
    davidblake20TRD
    davidblake20TRD New Member
    David
    2020 Cement TRD off road
    anyone have any experience with 285/75/16 with 5100s on the 3rd or 4th notch? 2020 trd-offroad
  6. Mar 19, 2021 at 8:20 AM
    #486
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    Yes, tons of people do. There's a tire thread about it etc
