5100's height and misc problems - Help
Discussion in 'Suspension' started by Jay_bruce, Sep 8, 2008.
  1. Sep 8, 2008 at 6:10 PM
    Jay_bruce
    Jay_bruce [OP] Active Member
    Southern Illinois
    07 Double Cab, TRD 4x4
    5100's up front @ 1.75, LT285 75R Nittos on 16" MB Predator rims.
    Please, can someone help answer my questions? I had the 5100's installed on the front of my DC TRD Off Road 4x4 last week. I also have the TSB leaf.
    I had the shop use the 1.75" setting. Here's my problems:
    * I only got a 1" lift on the 1.75" setting. (went from 35" ground to fender to 36") How can I get the full amount???
    * I hear popping noises when starting in forward and reverse. (never noticed it before)
    * Also hear a rattling noise when at 50-60 mph on the front right side.
    The shop said everything is aligned to factory specs. Any ideas?
    Thanks-
    Jay
  2. Sep 9, 2008 at 4:08 AM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    Only thing I can think of, The c-clip was set in the second ring.(.85) from the bottom. :) Sorry I can't help w/your other problems.:(:eek: I've had mine in for two months w/no issues.
  3. Sep 9, 2008 at 8:44 AM
    Jay_bruce
    Southern Illinois
    Thanks for the reply. I can see 2 full rings, so it appears that the 3rd setting or 1.75" is being used. Was thinking that maybe my coils are bad, however the truck is a 2007 with 40K on it.
    Jay
  4. Sep 9, 2008 at 1:13 PM
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    Coils could easily be bad.....the factory coils fade pretty quick and with the progressive spring rate they seem to all accept spacer lifts differently.... I said to hell with the 5100's because they rode to damn soft and just went all Icon and Deaver and will never look back...the only suspension to be done on my truck from here on out will be when I put the D60's under it.......
  5. Sep 9, 2008 at 6:35 PM
    Jay_bruce
    Southern Illinois
    Mr.TRD,
    Thanks for the reply. the more I research, the more I think that the factory coils may be the problem with the lift height. Been looking at some Toytec 885 coils, not sure if that is what I might need. I plan on using the 5100's with whatever I can find to get me to at least a 2 1/2" jack in front. Looked at the Bilstein coil over, but read where they have caused some people problems and setbacks.
    Still not sure why I have popping noises after the 5100 install. Can it be that I might need a diff drop? Doesn't seem right from what I have read.
    Jay
  6. Sep 10, 2008 at 8:10 AM
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    The popping is definitely not "right" If you plan on using the adjustment on the shocks for the lift then you need to get the softest ones OME makes...or you can get the OME's that provide the lift and leave your bilsteins on the bottom setting. If you go both lift springs and lift on the bilsteins you will get a terrible ride and no flex....and probably more problems down the road.
  7. Sep 10, 2008 at 2:41 PM
    Jay_bruce
    Southern Illinois
    Thanks for the info! If I go with OME 885 and lower the 5100's to stock, any idea if I may need a block in the back?
    Had the TSB done a month ago and the bed still sits high. May be that I have a short bed with no loads.
    Jay
  8. Sep 10, 2008 at 2:45 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you may need to later on, but you may want to opt for an aal instead of a spacer. the aal will be safer, ride better, and wont cause axle wrap. just a heads up.
  9. Sep 10, 2008 at 10:31 PM
    sooner02r1
    sooner02r1 Well-Known Member
    Generally popping from the front is noise from a CV joint that's either in a bind or bad. Maybe you should pull the front end apart yourself and make sure it's done right. You never know what minimum-wage monkey is putting your stuff together at a shop...
  10. Sep 11, 2008 at 4:03 PM
    Jay_bruce
    Southern Illinois
    Thanks, I was wondering about that. I know that Toyota did replace one of my front wheel seals after I purchased the truck. I just added the 5100's on 1.75" up front and can't see how that may have already wore out the ball joints.
    I have the extended warranty for the truck, but think I'll take the truck to a different mechanic that I trust to get a opinion on what this could be.
    I also read in another thread that it could have something to do with the yoke?
    http://www.tacomaworld.com/forum/1st-gen-tacomas/10096-dreaded-thump-clunk.html.
    Jay
