5100's set to 0" and 16" Eibach coils question
Discussion in 'Suspension' started by Joe B, Apr 16, 2009.
  1. Apr 16, 2009 at 7:57 AM
    Joe B
    Joe B [OP] Well-Known Member
    Another thread here got me thinking and a bit curious..
    May be a stupid question but...
    I believe the stock coils are 14".
    Would 5100's set to 0" and 16" Eibach coils lift the front and not screw up the stock alignment numbers?
    If the Eibach does lift,how much?
  2. Apr 16, 2009 at 8:28 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Any lift is gonna mess with the alignment. Seems most people can have their truck returned to "Spec." at any lift under 2".
  3. Apr 16, 2009 at 8:34 AM
    Hydrabyte
    Hydrabyte Well-Known Member
    Florida
    1987 4Runner
    I have the bilsteins set @ 2.5, no issues getting my alignment within specs
    .02
  4. Apr 16, 2009 at 8:40 AM
    Joe B
    Yeah,I thought so after I posted.
    Brain fart!:)
  5. Apr 16, 2009 at 9:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What is your Caster?
  6. Apr 16, 2009 at 10:04 AM
    Hydrabyte
    Florida
    1987 4Runner
    interesting, examining the print out now and caster is shown but no caster numbers "actual" / "before" - guess i got hood-winked for $80 beans. So here's a negative plug for SunTire Corp!
  7. Apr 16, 2009 at 12:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If your at 2.5" lift, Im guessing your Caster is well below 1*....maybe around .6* or so. Honestly, as long as your Toe and camber are set to 0*, your fine.
  8. Apr 18, 2009 at 10:07 AM
    canuck_tacoma
    canuck_tacoma Well-Known Member
    BC, Canada
    SR5 4X4 Tacoma Access Cab
    1.5" Eibach Front Coil Lift, Rear TSB, 265/75/16 BFG A/T's
    You will get at least 1.5"'s with the Eibach springs. You will need an alignment done, but there is no need for a dif drop.
    I had a 2" lift and felt some vibrations and when I wnet to the eibach's, the truck drove smooth again. Plus with the 2" lift the alignment shop was just able to get my front in spec with the settings max'd out. With the 1.5" lift they had no problem aligning the truck to factory spec.
    I would highly recommend these coils if you're only looking for a mild lift.
    My truck with Eibach's and stock TRD shocks.
