5100's VS. 3" Spacer Kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chopperpat333, Jan 11, 2011.
  1. Jan 11, 2011 at 8:39 PM
    chopperpat333
    chopperpat333 [OP] Member
    Denver
    T|X Pro TRD
    Cheers Gents!
    I am new to Tacoma World and I need some advice. I have a 2011 TX Pro 4x4 and looking to get the best quality lift around 3". I want to run 285/75/16 BFG AT KO's but want a quality product. I need to stay below 3" on the lift to be able to fit in parking garages and keep my 16" wheels.
    If I buy Bilstein 5100's and adjust them to the 2.5" setting is that all I need to run 285's along with maybe some minor fender wall lining trimming?
    I do mild-moderate wheeling, but always stick to the trail. 6" lift is out of the question for me.
    Or should I go with a Tough Country 3" spacer kit. So confused, also because not sure if 5100's work with 2011 models.
    Any and all feedback will be greatly appreciated.
    I know there is a lot on info on 5100's but most is not applicable due to 2011 model year
    Please Help!!!
    Thanks fellas
  2. Jan 11, 2011 at 8:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    "Best Quality 3" lift"......You may want to consider an Old Man Emu set up. That would be better than setting the 5100's at a 2.5" setting.
  3. Jan 11, 2011 at 8:42 PM
    chopperpat333
    Denver
    T|X Pro TRD
    Thanks for your input, that helps!!!
  4. Jan 11, 2011 at 8:55 PM
    Ryan07
    Ryan07 Well-Known Member
    New Brunswick
    07 TRD DC,LB Sport 4x4
    Icon Ext. Coilovers, LR UCA's, Icon AAL, Nitro 9000 Shocks, 7"Kragen HID's/Billet Grille, Extang Solid Fold Tonneau Cover, Bed Lights, Diff Breather Mod, D-Rings Mod, LED Interior Lighting/Plate Lights, LED 4X4 Switch, Viper Starter, AVH-P4200DVD, PAC Interface, OEM Backup Camera/Pop&lock, Wet Okole Seat Covers, Weathertech Mats, Husky Mud Flaps, 8000lbs Champion Winch/Winch Cradle and Quick Connect Kit, 4,500lbs Champion Winch/Front Hidden Winch Mount, OEM Painted Rims, Spidertrax 1.25, 265/70R17 BFG KO's
    If you got the $ go for the 5100, but i didn't so i went spacer.
  5. Jan 11, 2011 at 9:11 PM
    NamBam
    NamBam Member
    Birmingham, Al
    2014 DBSC SSM Off-Road
    OME 887 on Bilistein 5100s. SPC UCA. Revtec Diff drop & OME Driveshaft spacer. AAL rears. SCS F5 16x8 w/ Nitto Ridge Grapplers LT285/75R16.
    cant go wrong with 5100 billies
  6. Jan 11, 2011 at 9:15 PM
    chopperpat333
    Denver
    T|X Pro TRD
    one more question, can i just buy the 5100's in the front, and call it a day? or do i need longer springs, any spacers, or basically anything else? not sure if i have to buy a full lift kit with 5100's or just the two front shocks?
    I know i must seem like a lome-o but just lost on all this...
    Thanks
  7. Jan 11, 2011 at 9:17 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    x2
  8. Jan 11, 2011 at 9:24 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I would go OME route, and get there 3" lift from Toyteclifts.com
    Or you could go with the 2.5" Billy's, but It would require more triming.
    With the 5100's you should lift the rear about 1.5" to get the truck more level, with a AAL (Add-A-Leaf)
    And 5100's in the rear would help the ride too.
  9. Jan 11, 2011 at 9:30 PM
    chopperpat333
    Denver
    T|X Pro TRD
    Thank you all so much. Each comment is clear and very helpful. I think the OME route sounds nice, just not to sure inf my budget can handle the OME and BFG 285's... but if anything's worth doing, its worth doing right... So, the more notable thread should be OME VS. 5100's... Both full lift kits are near equal in price...
    Thanks All!!!
  10. Jan 11, 2011 at 10:20 PM
    NamBam
    NamBam Member
    Birmingham, Al
    Its basically what your preference is with which route you go either Bilstien or Old Man Emu. (anything but spacers) I have billies set at 2.5 in the front with stock springs. In the rear, toytec AAL 1.5 with stock shocks. you can always buy billies for the rear later on if you care for them.
    you can also search what other people have done and their experiences with both. Dont worry about getting shims or driveshaft drops, i hear a lot more harm than any benefits. and remember "better" is subjective upon everyones opinions and experiences.
