5100s vs Spacers
Discussion in 'Suspension' started by Lane Cypert, Oct 28, 2008.
  1. Oct 28, 2008 at 4:00 PM
    Lane Cypert
    Lane Cypert [OP] Well-Known Member
    Lewisville, Texas
    2008 silver prerunner double cab TRD
    I am trying to decide between the Bilstein 5100's set at 2.5 on the front or a 3 inch spacer lift. I was leaning towards the 5100s until the guy from 4wheel parts told me the bad thing about the 5100s set to the highest setting is they are hard to align and will wear out more parts over time than the spacers. Sorry for the run on sentence! I am definitely going to do add a leaf on the rear.
  2. Oct 28, 2008 at 4:08 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    15 Lariat Sport 5.0L
    3rd gen forum caused me to get a Ford
    spacers do the same thing as the 5100's set at top. both throw the caster outta wack and all...gotta get new UCA's to fix that
  3. Oct 28, 2008 at 4:17 PM
    Brunes
    Brunes abides.
    Rotorhead
    +1...Any lift will need some other parts to make sure they fit correctly. Depending on what you want to do with the truck is how you should decide what life to use.
  4. Oct 28, 2008 at 5:36 PM
    Lane Cypert
    Lewisville, Texas
    Do most people get new UCA's or just run them with the stock ones? I am not going to offroad and the lift is all for looks
  5. Oct 28, 2008 at 5:41 PM
    jhodge83
    SC
    w/o the uca's u'll do like said before and add stress to other components and the alignment will never be exactly right. for 4x4's it'll help to do the diff drop no matter what
  6. Oct 28, 2008 at 5:46 PM
    bvalistic
    bvalistic Well-Known Member
    long beach ca
    trd sport
    what's the right number too see on caster to know that your truck is on spec??...i had mine lifted 1.75 + tsb...thanks
    Don
  7. Oct 28, 2008 at 8:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Caster should be 2.5* to 3.1* to be in spec. Thats with Camber at 0* and toe at 0*
  8. Oct 28, 2008 at 9:52 PM
    bvalistic
    long beach ca
    trd sport
    thanks Chris...glad you caught this...i will now look at the numbers on my alignment sheet...
  9. Oct 28, 2008 at 10:02 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    im kinda starting to think i should do a diff drop on my tacoma since i just installed my new suspension. i got a little lift out of it, maybe 2 inches for the front with the ome881 coils............not real sure if its needed tho. i know im gonna save for some tc uca's later on too.
  10. Oct 28, 2008 at 10:11 PM
    bvalistic
    long beach ca
    trd sport
    tacoma 4x2 : 2007-08: pre runner double cab: standard bed (mexico)
    this is the actual reading after lifting (1.75 setting on bilstein and tsb) and aligned per specification of above truck description: my question: is my alignment number wrong? should i let them change it? or should i stay on standard specified number that this truck required...thanks
    Don
    left front
    camber 1.0 *
    caster 1.0*
    toe .13*
    right front
    camber 1.0*
    caster 1.0*
    toe .13*
    specified range for 4x2 pre-runner dbl cab 2007-2008
    camber -0.0* to 1.5*
    caster 0.9* to 2.4*
    toe 0.6* to 0.17*
  11. Oct 29, 2008 at 6:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont think you need the Diff drop. It only changes things a few degrees, and it moves your diff down and more likely to hit something when off roading.
    Ummmm.......If I were you, I would tell them to set Camber at 0* and Toe at 0* I have a feeling your front tires look like this: \ / when veiwed from the front.
  12. Oct 29, 2008 at 6:58 PM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    Mine is (after lift):
    Left:
    Camber .9
    Caster 3.4
    Toe -.02
    Right:
    Camber .5
    Caster 3.6
    Toe -.02
    That seems WAY different from the above numbers...
    I have to take it in tomorrow(-ish) to get the alignment redone since I adjusted the coilvers... I was planning on telling them to set the Caster at 2.4 based on ToKu's thread from ToyotaNation.com.
  13. Oct 29, 2008 at 7:00 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Just tell them to set the Camber at 0* and the Toe at 0*. The Caster should fall into spec. With the TC UCA's your going to have a little more Camber than stock. Probably around 3*. This is a good thing as it will track really nice. :)
  14. Oct 29, 2008 at 7:09 PM
    LonghornTaco
    Minnesota
    As always, thanks dude!
  15. Oct 29, 2008 at 7:10 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    aight.....since its only slightly lifted, i'll keep it as is till i get new uca's.:D
  16. Oct 29, 2008 at 7:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Cool! :)
  17. Oct 29, 2008 at 7:37 PM
    dtrujillo63
    dtrujillo63 Well-Known Member
    Denny
    Los Angeles
    08 Tacoma DC 4x4 Sport
    How about mine! Do these look ok? I have 5100s set at 2.5".
    Left:
    Camber: 1.2
    Caster: 0.0
    Toe: 0.03
    SAI: 10.4
    Included Angle: 11.6
    Right:
    Camber: 0.7
    Caster: 0.3
    Toe: 0.04
    SAI: 11.1
    Included Angle: 11.7
  18. Oct 29, 2008 at 7:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Are you serious?
  19. Oct 29, 2008 at 7:49 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    dude...that cant be riding good. they need to get those closer to each other i think.
  20. Oct 29, 2008 at 8:03 PM
    dtrujillo63
    Denny
    Los Angeles
    I don't know the first thing about alighments, is that really bad:confused:? That is the job from the great Firestone lifetime alignment.
