5VZ-FE 3.4L V6 reliability problem Please HELP
Discussion in '1st Gen. Tacomas (1995-2004)' started by Barlie_pop, Mar 11, 2019.
  1. Mar 13, 2019 at 12:58 PM
    preybird1
    preybird1 02 taco on 37's
    Russ
    Salt lake city Utah
    2002 taco s\c
    Trd S\C with nosecone hybrid bearing upgrade kit. 2.0 urd pulley, 7th injector kit-urd "6 fabtech lift with 3" body lift. 20" XD spy wheels with toyo open country r\t's in 37"x 12.50x20. Front and rear diffs re-geared to 4.88 dirty 30 drive axles. and a rhino pack clutch. Custom exhaust and huge mudflaps!
    sounds like fuel pump is getting weak. or your flyby wire throttle body is going out. I had an 04 that had the flyby wire and when is started going bad it would stumble and hesitate at random times and would not throw and engine light. took me 6 months to figure it out. I sold that truck because that throttle body is $1400-1600.00 from Toyota and you cannot adjust it i tried to no avail. they put that throttle body into an electronic ohm jig and set the throttle position and throttle intake butterly and then lock the screws down and put yellow paint on it so if it moves or if you mess with it they can tell. i sold that truck because of that throttle body issue and went back to a 2001-2002 before that throttle body came out. i am happy with a cable pull throttle body because the throttle position sensor is only $35 bucks if it goes bad.
    Barlie_pop[OP] and cruiserguy like this.
  2. Mar 13, 2019 at 1:12 PM
    preybird1
    Russ
    Salt lake city Utah
    2002 taco s\c
    you can buy this stuff from toyota specifically for cleaning the fuel injectors without taking them out of the engine.
    P/N 08813--0080DS
    here are some documents regarding this cleaner.
    Barlie_pop[OP] likes this.
  3. Mar 13, 2019 at 1:15 PM
    eon_blue
    Azusa, CA
    Have you tried it? Seem to work?
  4. Mar 13, 2019 at 6:18 PM
    Barlie_pop
    Barlie_pop [OP] Member
    Had to work early and didn't finish till late today beat up and didn't get anything done on the truck.
    If i have to buy important parts I want OEM and have been going here. Any better suggestions I'm all ears.
  5. Mar 13, 2019 at 6:48 PM
    Barlie_pop
    First thing I did, everybody I talked to said that was the prime suspect. Turns out, according to Toyota, on my throttle body it not replaceable. Had to buy a new throttle body to replace the TPS.
    Toyota Part No.: 22030-62020
    TPS No. on that throttle body is 89452-35030
    thread on this forum about it here
  6. Mar 13, 2019 at 6:52 PM
    Barlie_pop
    Air filter was replaced a not to long ago will check the MAS
    Thanks
  7. Mar 13, 2019 at 7:46 PM
    Barlie_pop
    Thanks preybird1 that may be the answer after spending 700 bucks on a "new throttle body" and taking a fishing trip from Las Vegas to Yellow lake region out of Escalante UT after the install with no worries and no problems till a few weeks later and the problem showed up again. Starting to think it's a computer problem related to the TPS. Maybe next time it happens I'll pull a battery cable and see what happens.
    Thanks
    Great stuff right there preybird1
  8. Mar 14, 2019 at 7:27 PM
    Barlie_pop
  9. Mar 14, 2019 at 11:57 PM
    Johnny_Mac
    Johnny_Mac Member
    Johnny
    SW Washington
    2003 Prerunner DoubleCab
    Cool Sasquatch sticker
    It appears that this has been an issue for a while and it runs fine out on the highway so this is a wild stab in the dark.....I had a buddy that had excessive water in his fuel tank. It would start just fine in the morning and after driving, the water would get sloshed around and mixed up and cause his truck to start bucking and snorting, but if he let it sit for a while, the water would apparently settle and/or homogenize and it would start and run again. He initially troubleshot it as a heat issue. I guess a super cheap test would be dump a couple bottles of "Heat" into the tank, top off with some good fuel and see if anything changes?
