6.5" subwoofer in the doors
Discussion in 'Audio & Video' started by eric3187, Jul 1, 2012.
  1. Jul 1, 2012 at 6:33 PM
    eric3187
    eric3187 [OP] Well-Known Member
    has anyone ran 6.5" subwoofers in the rear doors on a double cab?
    for instance, these subwoofers http://www.crutchfield.com/p_2060CVT654/Kicker-10CVT654.html?tp=111#overview-tab
    with multiple layers of sound deadening, and sealing off any major openings, would the door be a suitable enclosure for something like this?
    Main reason for this is i use the area behind the back seats for storage so i do not want to loose that space.
  2. Jul 1, 2012 at 6:59 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    I am interested in there as well.
    Anyone know if a 3" mounting depth will fit in the double cab rear doors?
    These are listed as a free air sub so putting them in a non sealed door will work but they will just not hit as hard.
    I am not in need of a big thump anymore since I am getting older and would like to keep rear seat storage as well.
  3. Jul 1, 2012 at 10:02 PM
    rpking
    rpking Well-Known Member
    Roger
    Ohio
    Tacoma 4x4 TRD off road
    painted engine cover, bed cover, color match door handles, window tint, seat covers, weather gaurd floor mats, TRD stainless steel cat back exhaust, front skid pan, bug deflector, custom holster mount in center console, OME 884X springs and shocks, 2" AAL, OME shocks
    Good idea. I have an access cab, does anyone know if they would fit in the rear doors of an access cab? My truck does not have any speakers in the rear doors I would love to put some in if they would fit. There isnt much room in the back of an access cab so I dont want to build a box for a sub hell I wouldnt have any room then if I could put some speakers like this in the doors that would be just tits!!!
  4. Jul 3, 2012 at 11:48 AM
    Aw9d
    Aw9d That one guy
    If you use a spacer from ********* (Or make one) I think you could fit a 6.5 sub in the rear door.
  5. Jul 3, 2012 at 1:47 PM
    eric3187
    the only fitment issue i would see would be from the excursion of the woofer hitting the door panel, (that is if it fits depth wise) i am just curious if anyone has ran a setup like this
  6. Jul 3, 2012 at 1:52 PM
    blue97taco
    blue97taco Well-Known Member
    alex
    Raleigh, Nc
    Even if it fits, how would the sound quality be? I'm not an expert at all but that doesn't seem like the beat enclosure for a sub
  7. Jul 5, 2012 at 10:06 AM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    probably sound like crap, and im no expert but i think youll need a sub that can run IB
  8. Jul 5, 2012 at 10:10 AM
    Aw9d
    Aw9d That one guy
    If you tune it right, it will sound great. Most audio setups for sound staging don't use rear speakers, a lot of people use small subs to help fill in some of the bass between the subs and door speakers if they do have a set of rear speakers.
    As for fitment, I doubt the sub would hit the door panel during excursion. It will be a close fit but I think it would work.
  9. Jul 5, 2012 at 10:26 AM
    eric3187
    well i found the same subs for 65 each so i may give it a shot in a couple months.
    since they can run off a low RMS power, would a basic 4 channel amp work for these (Channels 1 & 2 for the front speakers and 3 & 4 for the 6.5 subs)
  10. Jul 5, 2012 at 10:44 AM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    I thought forum member, ItalynStylion, tried doing this. He ordered some 6.5 subs, fabricated some sub mounts for the front doors, hooked up everything correctly and just couldn't make it sound right, like too muddy.
    There was too much rattle, or not enough seal withing the door to make a door mounted sub sound clean. Something like that...
  11. Jul 5, 2012 at 11:19 AM
    Kaitacoma
    Kaitacoma Member
    Scott
    Whiteville
    08 RadRed PreRunner TRD Sport
    BHLM, N-E Time Fog Lights, Plastidip Front Valence, N-Fab Bars, Blacked Out Emblems, Sony DVD HU, Blacked Out Dash, Red LED Instrument Display w/White Needles
    I've currently got a similar setup like this and Bishop or Italyn is right. One thing im trying now is to put dampening sheets on the interior of the doors outer skin which i didnt do initially. Not sure what level sound quality level u prefer. I just have pioneer 6.5 component speakers driven by a sony receiver with the rear bass enhancer circuitry which basically acts as preamp LPF in the HU and
    pioneer 6x9 coaxials in the front. It actually thumps fairly well, but it is sort of muddy due to the flex of the door just using 17 watts rms my sony is putting out. Dont think you'll have a problem with depth if using the ref spacers mine are mounted on 1" mdf. I'll let u know if dampening the outer skin helps as i just ordered it last night.
    QUOTE=Bishop2Queens6;5337616]I thought forum member, ItalynStylion, tried doing this. He ordered some 6.5 subs, fabricated some sub mounts for the front doors, hooked up everything correctly and just couldn't make it sound right, like too muddy.
    There was too much rattle, or not enough seal withing the door to make a door mounted sub sound clean. Something like that...[/QUOTE]
  12. Jul 5, 2012 at 11:29 AM
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
    couldn't you use spray expanding foam in the speaker hole in the rear door then cut out the correct airspace
  13. Jul 5, 2012 at 5:41 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Not unless you want your door to look like the Michelin Man.
    I've tried the subwoofer idea in the doors with some of those Tang Band 6.5" Neo Subs. The doors aren't sufficiently bolstered in my opinion for that type of movement. I think you could reinforce the door a bit and it will help some. I know for a fact that the Tang Bands fit but I don't know about the kickers. Also, I doubt you'll have a problem with excursion hitting the door. There's a ton of space in there.
    My take on the whole thing is that you aren't going to like what they do. I think I have a thread on this somewhere....
  14. Jul 5, 2012 at 6:05 PM
    eric3187
    since you have been this route already, what is your input/thought on the way to achieve a more full sound stage without taking up the storage behind the rear seats.
