6" lift kit for 15'' wheels
Discussion in 'Suspension' started by J Mac, Jan 24, 2013.
  1. Jan 24, 2013 at 12:55 PM
    J Mac
    J Mac [OP] Member
    New England
    08 Tacoma
    After searching this forum and much of the internet I cannot find a 6" suspension lift kit that will fit 35x12.5x15's. After talking to a number of offroad equipment sites and lift kit manufacturers, for the most part, all I can find are 6" kits that will fit 17in wheels or larger. Does anyone know of a kit that will fit my wheels?
  2. Jan 24, 2013 at 12:56 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You can't fit 15" wheels on the 2nd Gen 6 lug trucks, period.
  3. Jan 24, 2013 at 12:56 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    Your wheel size really has nothing to do with your lift.
    I believe that you need at least 16" wheel to clear the brake calipers on a 2nd gen Tacoma. Anyone?
  4. Jan 24, 2013 at 12:59 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    they're right... you cant fit 15" wheels on 2nd gens
    and also, like they said, wheel size has nothing to do with lift height really
    you can put a 235/75r16 tire on a 3' lift, technically....
    when people talk about stuff "fitting" on lifts, theyre usually talking about the largest tire size they can fit without running into rubbing problems
  5. Jan 24, 2013 at 12:59 PM
    That Dude Tim
    That Dude Tim Toyota Technician
    Elyria, OH
    11 TRD Sport 4x4 DCLB
    Falken Wildpeak AT3/W, BLK Mk6, ICON's, Firestone Ride Rites, SHLM, Rear view camera switch, 7-pin in bumper, Lighted 4x4 switch, ImMrYo bracket, mudflap delete
    this
  6. Jan 24, 2013 at 1:12 PM
    J Mac
    J Mac [OP] Member
    New England
    08 Tacoma
    I guess I left out some info. I grinded down my calipers and added 1.75" spacers so I already have the 15inch wheels installed and have been running them for about a year. The lift has to do with the wheels because the knuckle that comes with these kits that I've been looking at wont fit in the 15in wheels. So i guess I'm looking for a 6" kit with either a smaller knuckle connection or some other option I can't think of.
  7. Jan 24, 2013 at 1:17 PM
    Pugga
    Massachusetts
    Oooh boy... so you took a grinder to your stock calipers, removed some material to clear wheels that shouldn't have fit to begin with, and now you want to task those same weakened calipers with bringing a 35" tire to a stop... I don't know which part of that sounds like a good idea to you but I sure as hell wouldn't drive the truck like that.
  8. Jan 24, 2013 at 1:46 PM
    J Mac
    J Mac [OP] Member
    New England
    08 Tacoma
    I'm not asking you to drive my truck. I've already been riding on these wheels and tires and already have a 6" suspension lift - all I want to do is replace the current lift with one quality kit. I'm not asking for opinions regarding my project I'm simply asking about a specific kit and if anyone knows where I can find one. All relevant responses are appreciated, thanks.
  9. Jan 24, 2013 at 1:53 PM
    Pugga
    Massachusetts
    You're right, I don't have to drive your truck, I just have to share the road with people like you who undermine safety equipment... Wasn't sure if you were aware of the mistake you made so I was bringing it to your attention for both your and my own safety.
    Opinions aside, you have a 6" lift kit that works with your wheels, what don't you like about it? What are you trying to upgrade? Several manufacturers make suspension components that work with a base 6" drop bracket lift so you might not have to scrap the whole thing.
  10. Jan 24, 2013 at 3:07 PM
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    What does your suspension consist of right now ?
  11. Jan 24, 2013 at 3:14 PM
    Large
    Large Red
    Got any pics of your set up ?
  12. Jan 24, 2013 at 3:32 PM
    J Mac
    J Mac [OP] Member
    New England
    08 Tacoma
    Current lift consists of blocks, spacers, and aftermarket springs and shocks - some from a previous owner, some from myself. Tired of the cheap setup and rigid ride.
  13. Jan 24, 2013 at 3:38 PM
    Pugga
    Massachusetts
    If you already have the drop bracket installed, the spindles, etc, check out something like Icon shocks. They make shocks and coils specifically for 6" drop bracket lifts and it will ride like a dream. For the rear, your best option would be a replacement leaf pack.
  14. Jan 24, 2013 at 4:15 PM
    johnnym
    john
    NH
    interesting . got any pics ? as for your original question. i couldn't find any 6" kits that specifically say you can run a 15" wheel . but if you have your heart set on running that combo . im sure there are ways around it with backspacing and offset . but im not the best person to ask
    post some pictures of your front setup if you dont mind .
  15. Jan 24, 2013 at 4:54 PM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    My Pro Comp lift (6") said it requires 18" wheels but I am running 16". The issue is on the new lifts, the tie rod ends will be running on top of the knuckle vs. under the knuckle on a stock truck. With this set up, the tie rod makes contact with the wheel lip unless you run a 18" wheel OR run at least a 1.25" spacer. I went the spacer route. Will the 15" wheel work? It should space wise since your spacer is even bigger than mine & you already modified your brakes.
  16. Jan 25, 2013 at 7:19 AM
    J Mac
    J Mac [OP] Member
    New England
    08 Tacoma
    Well that's encouraging, at least if i do have to resort to bigger tires I know I can get away with 16s, it's just hard to tell without actually seeing where the knuckle will sit if my wheels are spaced out enough - the offset of the wheel should help too, but I also don't want to go farther with the spacers because my tires are already out so far. Posting pics is going to be hard, I'm not a smartphone user unfortunately.
  17. Apr 29, 2013 at 4:28 PM
    J Mac
    J Mac [OP] Member
    New England
    08 Tacoma
    Just wanted to post an update in case any one else runs into a situation where they want to run 15" wheels with 35s on a 2nd gen Tacoma. All in all (and this has been a lengthy project) I ended up installing a 6" lift kit, shaving a couple centimeters off the calipers, adding 1.75" wheel spacers, trimming the wheel wells and I was able to fit 35x12.5x15s on my '08. I'm completely satisfied with the way it rides altho unless youre really in to the look of 15" wheels probably not worth all the labor. The only negative I've noticed is slight axle wrap, but for my needs (1 mile commute to work and occasional fun in the mud) I'm not too worried. Hope this was all helpful and sorry it took so long to post pics - somewhat of a ludite..
  18. Apr 29, 2013 at 10:21 PM
    BradyT88
    BradyT88 Well-Known Member
    Do you have any pics of your shaved down calipers? I had thought about doing this once since R15 tires are so much cheaper. I was too worried about getting too deep into the caliper though...
  19. Apr 29, 2013 at 10:30 PM
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    save the effort and go 16, no offence op
  20. Apr 29, 2013 at 10:33 PM
    BradyT88
    Well when I go to 37's if I want to stay with KM2's I will have to go to a 17" wheel so I probably will save the effort. Just curious though.
