6" lift kit under $800?
Discussion in 'Suspension' started by jbakane23, Apr 21, 2021.
  1. Apr 21, 2021 at 3:29 PM
    jbakane23
    jbakane23 [OP] Member
    Is there a good 6” suspension lift kit for under $800
  2. Apr 21, 2021 at 3:32 PM
    Boozie2015
    Boozie2015 Well-Known Member
    Vancouver WA
    03 Tacoma
    Maybe a 3" body lift and a 3" spacer. Not sure.
    Mully and Mark77 like this.
  3. Apr 21, 2021 at 3:40 PM
    jbakane23
    Stacking the spindles on top of my lift will be safe to drive and not going to be easy to break?
    BassAckwards and desertrunner24 like this.
  4. Apr 21, 2021 at 4:13 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Itll be fine as long as you can keep your alignment in good numbers. I ran maxtracs with lift coils for a few years on my old prerunner. Had a total of 5.5inches in the front and it drove great.
    BassAckwards and whatstcp like this.
  5. Apr 21, 2021 at 4:23 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
  6. Apr 21, 2021 at 4:27 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Maxtrax spindles are definitely a great solution for what you want. They are way beefier than the stock ones too
    Sterling_vH111 likes this.
  7. Apr 21, 2021 at 4:35 PM
    jbakane23
    What should I do for the rear?
  8. Apr 21, 2021 at 4:38 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    No
    wi_taco, whatstcp and barf like this.
  9. Apr 21, 2021 at 4:52 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    Get a set of leaf packs etc. Deaver, Dakar, Alcan, or all pro. Or an add a leaf and some lift block. All depends on your budget. But to lift the front and rear you're looking at about 12-1500$
    BassAckwards likes this.
  10. Apr 21, 2021 at 4:53 PM
    Sig Taco
    Sig Taco Well-Known Member
    2021 Taco DCSB
    Icon Rebounds 17x8.5 Toyo 35/12.5/17 JBA UCA, Bilstein 6112/5160, KDMax
    You'll have $100 left, so maybe a 5" block.
    whatstcp likes this.
  11. Apr 21, 2021 at 5:56 PM
    jbakane23
    So I might as well just buy a whole new lift kit? Or would it still be better to go with spindles and leaf springs?
  12. Apr 21, 2021 at 6:05 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    Just get spindles, leaf spring and rear shocks
    tcjacado, BassAckwards and whatstcp like this.
  13. Apr 22, 2021 at 6:39 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This ^
  14. Apr 22, 2021 at 6:44 AM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    How little do you care about your truck?
    wi_taco and whatstcp like this.
  15. Apr 22, 2021 at 11:42 AM
    jbakane23
    I care about it a lot. I want it to work good and look good
  16. Apr 22, 2021 at 12:13 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    This is unrelated but I feel like it needs mentioning.
    If you love your vehicle and want it to keep looking good and working good, then the best thing you can do for it is have $5k in the bank that is strictly there for car repairs.
    I'm not assuming that you do or don't, I'm just mentioning it. It ain't sexy, but it'll keep you on the road longer than any lift kit will.
  17. Apr 22, 2021 at 1:41 PM
    thegrandpoohbah
    thegrandpoohbah Well-Known Member
    Terrace, BC, Canada
    2013 4x4 Double Cab V6 TRD Sport
    Probably not what you want to hear but with your budget you can make it look good or you can make it work good (maybe), but probably not both.
    wi_taco likes this.
  18. Apr 22, 2021 at 1:45 PM
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
    Take that 800 and buy a bunch of Dogecoin. When it inevitably goes to the moon you will have enough money to buy a real lift.
    wi_taco likes this.
  19. Apr 22, 2021 at 1:48 PM
    Dpher
    Dpher Active Member
    2009 white Tacoma 4 door shortbed 4.0L Auto
    33s and a lift
    I currently have a rough country 5 in front and 4 in blocks in the rear it drives like garbage I could only imagine a 6in. I would stick to a 3 in suspension lift without blocks and new leafs but thats $1600 for the bilstein kit.
  20. Apr 22, 2021 at 1:57 PM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Will you need extended brake lines for a 6 inch lift?
    tcjacado likes this.
