6" lift Konig Countersteer with 315/75's???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TodaGuy, Dec 21, 2009.
  1. Dec 21, 2009 at 5:16 PM
    TodaGuy
    TodaGuy [OP] Well-Known Member
    Oregon
    Almost Murdered 09 Taco
    Revtek 3" spacer in front 1" block w/ 2" AAL in rear. Blacked out grill, debadged (almost all done), Magnaflow muffler, black Konig Countersteer Off Road rims, 285/75/16 Toyo Open Country M/Ts.
    I have searched the entire internet and I have not found a 2nd Gen taco with this setup. Does anyone know if you can run this setup? Pics? I want to know how the back spacing of these wheels will look with 6" of lift I'm afraid the stance may look to narrow. If this setup does not work any suggestions on ALL black 16 or 17 inch rims for a 6" lift. Thanks!
  2. Dec 21, 2009 at 5:42 PM
    TodaGuy
    Oregon
    Bump!
  3. Dec 21, 2009 at 5:52 PM
    SwampThing07
    SwampThing07 Well-Known Member
    Orlando, Fl
    07 prerunner/ Toytec lift/ 285 nittos/ MM 951
    885/ w 5100's, Grillcraft, HIDs, 285 nittos, MM 951B, Flowmaster duals, blackout tailights, tint, Sirius.
    I havent seen a 6 inch with Konigs on it yet. And if you do a 6 inch you have to run atleast 17inch rims.
  4. Dec 21, 2009 at 6:35 PM
    TodaGuy
    Oregon
    Why would you have to run 17's on a 6" lift?
  5. Dec 21, 2009 at 6:38 PM
    BigBawlzTaco
    BigBawlzTaco Well-Known Member
    2019 Toyota Tacoma SR
    I've seen tacomas with 16 inches on a 6 inch lift. :confused:
  6. Dec 21, 2009 at 6:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Maybe a Trailmaster lift on a First gen, or 16's with spacers, but Most all 6" lift companies tell you to run 17" or larger, due to clearance issues with the spindles.
