6" lift question?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lionhunter93, Jun 28, 2012.
  1. Jun 28, 2012 at 9:59 AM
    lionhunter93
    lionhunter93 [OP] Well-Known Member
    Vinny
    NM
    06 TRD Off Road
    Front Suspension IVD coilovers and UCA's, Rear set up is OME leaf pack with OME shocks. Shrockworks front bumper.
    What is the best and most reliable 6" lift out there?
  2. Jun 28, 2012 at 10:02 AM
    Manwithoutaplan
    ID
  3. Jun 28, 2012 at 10:02 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Procomp Stage 2 or 3, also most expensive
  4. Jun 28, 2012 at 10:04 AM
    Manwithoutaplan
    ID
    plus if you are looking for more ground clearnce just get bigger tires for your 3 inch lift you dont gain anything with the 6 inch.
  5. Jun 28, 2012 at 10:06 AM
    lionhunter93
    Vinny
    NM
    06 TRD Off Road
    What about bds?
  6. Jun 28, 2012 at 10:07 AM
    Manwithoutaplan
    ID
    can you give me the website never heard of them.
  7. Jun 28, 2012 at 10:09 AM
    lionhunter93
    Vinny
    NM
    06 TRD Off Road
  8. Jun 28, 2012 at 10:09 AM
    Manwithoutaplan
    ID
  9. Jun 28, 2012 at 10:10 AM
    lionhunter93
    Vinny
    NM
    06 TRD Off Road
  10. Jun 28, 2012 at 10:13 AM
    Manwithoutaplan
    ID
    OP jw what is wrong with your 3 inch right now ??? DO you off road alot????
  11. Jun 28, 2012 at 10:15 AM
    lionhunter93
    Vinny
    NM
    06 TRD Off Road
    Nothing is wrong with it, I just like the look of a 6 inch lift and yes i do a ton of off roadin
  12. Jun 28, 2012 at 10:18 AM
    Manwithoutaplan
    ID
    honestly coming from someone that own a 6 inch lift it is not worth keep your 3 inch and save your cross member. spend your money on a more preformance lift instead of a 6 inch lift. WHen you do the 6 inch you gain nothing. But hey that is just my .02 cents.
  13. Jun 28, 2012 at 10:19 AM
    Manwithoutaplan
    ID
  14. Jun 28, 2012 at 10:22 AM
    lionhunter93
    Vinny
    NM
    06 TRD Off Road
    I would probably have the same amount of ground clearance correct? Ive thought about that and just getting this one by fox
  15. Jun 28, 2012 at 10:24 AM
    Manwithoutaplan
    ID
    yea, but it is all about tire size. what size are you running right now.
  16. Jun 28, 2012 at 10:25 AM
    lionhunter93
    Vinny
    NM
    06 TRD Off Road
    255/80
  17. Jun 28, 2012 at 10:28 AM
    lionhunter93
    Vinny
    NM
    06 TRD Off Road
    I dont really want to lose ground clearance because thats important to me
  18. Jun 28, 2012 at 10:31 AM
    Manwithoutaplan
    ID
    then go with 285/70 gain more ground clearnce with some trimming.
  19. Jun 28, 2012 at 10:33 AM
    lionhunter93
    Vinny
    NM
    06 TRD Off Road
    Already tried 285s and had too much rubbing and I don't really like to trim
  20. Jun 28, 2012 at 10:36 AM
    Manwithoutaplan
    ID
    ok, well just to let you know even with 35's with 6 inch, I have had to trim my fender and do cab mount chop.
