6" Pro Comp vs 6" Fab Tech Whats the difference?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wizzard005, Sep 7, 2011.
  1. Sep 7, 2011 at 10:37 PM
    Wizzard005
    Wizzard005 [OP] Well-Known Member
    Greg
    Sacramento, CA
    Stock
    Aloha all,
    what is the difference between these kits besides price?
    Fabtech
    Pro Comp
    There is a very large price difference.....
    Not sure what way I want to go....
  2. Sep 7, 2011 at 10:39 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    Where are you going that has a big price difference?
  3. Sep 7, 2011 at 10:40 PM
    Yodaforce
    Yodaforce Diverse-Customs.com
    William
    Western NC
    01 S-Runner (Arrghh! The Black Pearl)
    Simple Drop (3")
    Those FT spindles are alot beefier. Other than that, I sure can't see much difference.
  4. Sep 7, 2011 at 10:57 PM
    DubVtundy
    DubVtundy ERMAHGERD
    Thayer
    Keyser West Virginia
    2010 white double cab
    8 inch alcan custom leaf packs, ome 885's powdercoated white, bilstein 5100's all the way around with 12 inch travel on the rear, Light Racing Upper Control Arms, Sway bar removed, 17x9 kmc strike. 35x12.50 nitto Trail Grapplers. Satoshi Grill made by (homertaco), Black Headlight housings,retrofits, Tinted Tailights, color matched grill, Bought a TRD sport hood,elite off road front plate bumper,elite off road sliders, 13% tint on the front windows, 5% on top of the facotry rear windows and back glass, 5% tint stip across the windshield, Lo Pro Truxedo tonneu cover, Herculiner bed liner, Weather Tech Window Visors, Exhaust- Flowmaster Super 44 dumped above rear axle, Maglight Mount on side of drivers seat, Scangauge II, Mossy Oak Camo Seat Covers, Weather Tech Floor mats, Spatter painted A-Pillars, Spatter painted headunit trim and shifter trim, Headunit= Pioneer 4300 double din touch screen, Speakers- Precision Power 3 way component stage, Precision Power 8 i
    not a thing except fabtech has curved crossmember
  5. Sep 8, 2011 at 12:47 AM
    Manwithoutaplan
    ID
    save your money and get a long travel kit.
  6. Sep 8, 2011 at 1:23 AM
    ExpoSpy
    ExpoSpy Well-Known Member
    Brian
    S.D.
    08 DCLB 4X4
    It looks like the Fabtech has an AAL for the rear whereas the ProComp uses blocks...
  7. Sep 8, 2011 at 1:59 AM
    Wizzard005
    Greg
    Sacramento, CA
    Stock
    The Pro comp kit is about 2600, the fabtech kit is 4k To the person who said for long travel, I don't want to spend that kind of money , as if and when i move back to the USA, I am going to SAS it like my old truck. So for the time being this will be fine..
    I may just do coil-overs, for if i can spend a little extra I will get the procomp and but a add a leaf from all pro...
  8. Sep 8, 2011 at 2:01 AM
    Wizzard005
    Greg
    Sacramento, CA
    Stock
    how has your Pro Comp kit been? Any weird noises, any broken CV's?
  9. Sep 8, 2011 at 2:15 AM
    vprgts
    vprgts Well-Known Member
    Walter
    Centreville, VA
    Tacoma Sport TRD 4x4 DC LB
    265/70/17 BF Goodrich K02, OEM 17" Sport wheels, Bilstein 5100's, OME 887 coils, single Deaver rear AAL, Plasti dipped black front bumper cover, wheels and badges. TRD pro grill, trd auto shift knob, truxport roll up bed cover, painted red front calipers, tinted front windows, vital 2-way auto remote start.
    I just got the basic fabtech 6" with performance shocks delivered to me for under $1800. Absolutely love the ride and set up!! After many months of doing the research I decided on this lift and definitely do not regret it.
  10. Sep 8, 2011 at 9:24 AM
    TiMe
    TiMe Well-Known Member
    CA
    05 Dbl Cab 4x4
    6" Fabtech with coilovers 33" nitto mud grapplers
    A friend of mine has the procomp with the coil overs and I have the fabtech with the coil overs. I like mine more than his. His sway bar mounts different than mine and he wears out the lil end links a lot. He also has some rubbing and is only on 33's.
    I got my Fabtech kit from 4WP for 1900 and installed it myself.
  11. Sep 8, 2011 at 9:36 AM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    Not sure how the sway bar attaches to the fabtech, but the procomp sucks ass. you have to turn the heads of the endlinks with a allen key to install them. its kind of hard to explain. They dont go through the spindle then have a nut attached to them. you use the allen key to actually screw them directly into the spindles. recently had to try to remove them from my friends truck and it was impossible. the were frozen solid in there and this was a cali truck. so make sure to use lots of antisieze on them if you go with procomp. Personally its a shitty design as you're not supposed to turn the stud on the end link to begin with.
  12. Sep 8, 2011 at 10:19 AM
    Manwithoutaplan
    ID
    I did have a cv seal leak. but i think i have a bad cv. Because the angles are not bad at all. I have had couple noises but they have worked them selfs out. But if i had to do it all over again i would go with the All pro Long travel kit. But you live and learn.
  13. Sep 8, 2011 at 10:28 AM
    PLC721
    Patrick
    Chandler, Az
    I have not had one problem with my procomp kit but I am however taking it off and going lt.
  14. Sep 8, 2011 at 10:30 AM
    Manwithoutaplan
    ID
    are you going to reweld the cross member you cut off???
  15. Sep 8, 2011 at 10:31 AM
    PLC721
    Patrick
    Chandler, Az
    No I'm not worried about it. Haha jk jk yeah I'm having a new piece made
  16. Sep 8, 2011 at 10:33 AM
    Manwithoutaplan
    ID
    what kit are you going with ??? or you haveing custom done??
  17. Sep 8, 2011 at 10:51 AM
    PLC721
    Patrick
    Chandler, Az
    Just the all pro kit
  18. Sep 8, 2011 at 3:41 PM
    Manwithoutaplan
    ID
  19. Sep 9, 2011 at 12:24 AM
    PLC721
    Patrick
    Chandler, Az
    Lt is so much work tho. Not sure if it's worth it :/
  20. Sep 9, 2011 at 12:25 AM
    Manwithoutaplan
    ID
    yea but it be worth it ..beacuse it will be able to handle the terrain better.
