6" Pro Comp vs 6" Fab Tech Whats the difference?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wizzard005, Sep 7, 2011.
  1. Sep 9, 2011 at 12:27 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Yeah true. I have to run glass which I wasn't expecting and I need a front bumper. All to clear the 35's
  2. Sep 9, 2011 at 1:18 AM
    Manwithoutaplan
    ID
    ahhh well you are talking some dollers $$$ now :$
  3. Sep 9, 2011 at 10:51 AM
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Thickness of material used... FT db's are thicker.
    Im also taking off my FT kit, going 3"
  4. Sep 9, 2011 at 11:03 AM
    PLC721
    Patrick
    Chandler, Az
    i dont understand what you mean by saying you need the spindles with bolts?
  5. Sep 9, 2011 at 11:25 AM
    ruggedT
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Me?
  6. Sep 9, 2011 at 11:26 AM
    PLC721
    Patrick
    Chandler, Az
    Duh lol
  7. Sep 9, 2011 at 11:33 AM
    ruggedT
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Haha... you still see my old sig or somthn?
    Fabtech kit replaces the entire spindle, including the lower ball joint attachment. Procomp just replaces the top part re-using the lower ball joint mount and 4 bolts. I needed the whole setup, not just the top.
  8. Sep 9, 2011 at 11:38 AM
    PLC721
    Patrick
    Chandler, Az
    Oh okay no I was just remembering seein it, so I guess my switch will be easier once I get new diff mounts
  9. Sep 9, 2011 at 11:41 AM
    ruggedT
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Whats wrong with the old ones? Hopefully your cross member wont be so hard to fix. I have to make an insert and weld it to whats left of the old one by the alignment tabs
    I found a set up in Canada, the guy shipped them yesterday. He's only missing the $4/pc bolts... the lowers are included!
  10. Sep 9, 2011 at 12:07 PM
    PLC721
    Patrick
    Chandler, Az
    its a different mount and apparently 4wheel parts tosses them during install, this is info i have gathered from rondog.
  11. Sep 9, 2011 at 12:12 PM
    ruggedT
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    That sucks, mine are different but I still have the stock ones... you having trouble tracking them down like I did w/ the spindles?
  12. Sep 9, 2011 at 12:17 PM
    PLC721
    Patrick
    Chandler, Az
    no sdhq is just going to fab some up i think, but im taking the truck to stock first then bolting the LT up just to do it in steps and be easier
  13. Sep 10, 2011 at 1:24 AM
    Wizzard005
    Wizzard005 [OP] Well-Known Member
    Greg
    Sacramento, CA
    Stock
    I added up the price on the LT kit, It will cost about 5k to my door....
    Coil-over's will be 1300 + 3" springs for the back 600
    Or Procomp / fabtech 2k
    I think it makes more sense to get the 6" and run 35's ... gosh i cant decide
  14. Sep 10, 2011 at 7:59 AM
    PLC721
    Patrick
    Chandler, Az
    And then you need bumpers, glass, bumpstops,
    Guesset everything, and guaranteed to break stuff
  15. Sep 10, 2011 at 8:31 AM
    #35
    04LTtacoma
    04LTtacoma Well-Known Member
    Oregon
    x2
  16. Sep 10, 2011 at 8:31 AM
    #36
    04LTtacoma
    Oregon
    Fu&^ yeah!
  17. Sep 10, 2011 at 8:34 AM
    #37
    04LTtacoma
    Oregon
    LT lots of work???
    LT is a lot easier to install then fabtech or procomp. I am pretty sure you have to cut the lower mounts for the lower arm and weld on the fabtech kit.
    LT doesn't involve any welding or modifying, all bolt on. You can also run 35" tires on a LT suspension kit.
  18. Sep 10, 2011 at 8:41 AM
    #38
    PLC721
    Patrick
    Chandler, Az
    Yes the install is very easy I know. But I was referring the the glass and the bumpers etc that you will want to have as well.
  19. Jul 17, 2012 at 1:44 PM
    #39
    PCoTaco06
    PCoTaco06 Member
    Josh
    South Carolina
    05 SR5 Ext. Cab Long Bed 4x4 White
    Blacked out emblems
    I'm new at this and was wondering the same thing. But I have no idea what some of you are talking about with all the abbreviations and stuff. I'm trying to decide on a 6 in. Pro Comp stage 2 lift or a Fabtech 6 in. performance system. No rude replies please. Like I said, I'm new at this.
