6 sp manual shift knob adjustment?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toytruckmike, Feb 26, 2011.
  1. Feb 26, 2011 at 2:35 PM
    Toytruckmike
    Toytruckmike [OP] Well-Known Member
    Michael
    Texas
    07 TRD Sport AC 4x4 manual
    Eclipse nav unit, TRD Yeti decal, 18" 4Runner limited wheels finally installed! Look great
    Hi,
    I have the 6sp manual shifter in my Tacoma and the knob won't stay in place, it is fairly tight, but still moves a bit.
    Since I am famous for stripping bolts, I am hesitant to turn it another turn.
    How tight should I be able to get the shift knob before much destruction happens???
    Thanks,
    MichaelS.
  2. Feb 26, 2011 at 2:38 PM
    tanzak88
    tanzak88 Well-Known Member
    Tanner
    BC, C-eh-N-eh-D-eh
    I don't think you can strip it, as long as the threads are mated properly... If it's screwed on properly, I say crank it down as best you can, by hand. I mess with mine all the time, while in traffic, turning it 180 and trying it out, and switching it back. You wont strip it.
  3. Feb 26, 2011 at 2:58 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    Aim-ish country PA
    2002 Sliver-ade-o 2008 P71
    Yes
    Yeah you won't strip it. I had a rubber washer on mine and that seemed to help alot.
  4. Feb 26, 2011 at 4:16 PM
    BigBiscuit
    BigBiscuit Well-Known Member
    Mass.
    2010 TRD Sport DCSB MGM
    Just put a drop of removable Loctite (the blue stuff) on the threads. Screw the knob on until the alignment is where you want it and let it set for a while. It'll stay put afterwards.
  5. Feb 26, 2011 at 5:37 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    You talkin about the aftermarket shift knob? The big, relatively ugly (some say it's out of place) but terribly comfy ball.
    If it's moving on you you don't have the lock nut installed or you're not using a wrench. I'd brake the shaft before I got mine off.
    As for the stock one. They seem to have a sleeve that rotates. I've honked that thing down a good couple of extra turns. Never had a problem with it moving after that.
    ITs plastic anyway. Worst thing you'll do is strip the plastic and have to get the round knob or a new plastiknob.
