6 spd manual disappointing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Stakedriver, Aug 25, 2008.
  1. Aug 25, 2008 at 8:40 AM
    Stakedriver
    Stakedriver [OP] New Member
    Madison, WI
    08 Rugged Trail
    ARE hard tonneau K&N air
    New here, and I apologize up front if this is already a topic, but I haven't found one specifically on this transmission.
    I've got the 6 spd manual on my 08 access rugged trail. Been a stick guy for 25 years, but am disappointed enough in this tranny to inquire on what others are experiencing. Here are the issues:
    1. When backing out of drive or parking spot, it can be tough to find 2nd, especially if rolling back while doing so. It seems that backward motion makes the reverse cog softer.
    2. If rolling to stoplight in N, about 10% of the time 2nd gear is not there initially, needing to pump the clutch and grind to get it in gear.
    3. RPMs race between gears, esp between 2-3 and 3-4. I've not experienced this before in a manual. Maybe this is normal, but I still don't like it.
    4. Gears are too short, esp 4-5-6. Yeah, I know. If I used it for offroading this would not be an issue. As a surveyor, I do use it for offroading on a daily basis, but I've never used 6th gear offroad. I wish it was out there a little more. Everytime I hit 65, I'm looking for another, but it's not there.
    Is anybody else disappointed in the 6 spd. Does anybody love this transmission? Maybe I got a lemon. All feedback is appreciated, especially anything I can take to my dealer, or maybe you know a way to change the gears. Also, maybe I need to suck it up and take it like a man! That's fine too. Thanks for reading.
  2. Aug 25, 2008 at 8:50 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I think it could be geared a bit taller-I was thinking overall tho. I get up outta the hole to second in no time and then shift quick thru the whole gear set.
    Other then that...I love the transmission. IDK what kind of stick rides you've hard before now-but this truck tranny is far different from the sport tranny in my Scion tC- so it takes a different type of driving to drive the truck well compared to the car.
  3. Aug 25, 2008 at 10:16 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    i've been a manual guy for 9 years and was planning on getting my taco in the 6 speed. but i drove the auto, then after that i drove the manual and i hated the feel of hte 6speed. nothing about it was smooth and it is geared way too low
  4. Aug 25, 2008 at 10:34 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    Toyota manual transmissions are notorious for being stiff/rough/clunky when new. They usually improve dramatically over time. My 5 speeds 1st to 2nd shift was so bad that I was sure something was wrong until I drove my fathers truck and it was identical. Somewhere between 10K and 15K miles the issue completely disappeared.
  5. Aug 25, 2008 at 10:39 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    1. Not sure what you mean by this. I don't look for 2nd when rolling backwards so.... :confused:
    2. I usually use 2nd or 3rd if I can do a rolling stop. Here's a tip DON'T GRIND THE GEARS. Use gentle forward/backward pressure and let it slide into whatever gear is easiest. I tried fighting mine for the first week with the result being grinding gears. Once I learned to just push/pull and let it decide left/right things worked better. Like it's gated or RPMS make it slide easier into the correct gear which may not be the one YOU think it should be in.
    3. RPMs hang between shifts for emissions reasons. Burns gas in the cylinders instead of dumping it out the exhaust by dropping to idle speed immediately. Or something like that.
    4. Try towing something or offroading or get bigger tires. I have a 3" lift with 285 tires and it's perfect for me. Granted, a better OD gear would be nice for highway travel, but then again the manuals can hold speed on hills with CC while the autos downshift.
    Also keep in mind this tranny is brand new right? You need at LEAST 5k on it to break it in. I noticed improvements at 5, 10, and 15k. The more miles, this smoother the transmission becomes. I have just over 50k on my 06 now.
    Oh, and it does take some driver adjustment. This manual is different from all the other's I've driven over the last 13 years.
  6. Aug 25, 2008 at 10:40 AM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    Its not a perfect, but really not much different than my previous trucks. It'll get smoother over time.
    1 & 2: First I've heard of 2nd gear issues. If keeps up, may need to see dealer.
    3: Unlike other vehicles, the Rpms don't drop when clutch in. Done for emissions purposes. You'll get used to it.
    4: They probably could have gone taller in 6th for better interstate mpgs, but its perfect when you tow a light trailer, climb a mtn, or haul
    full load and never have to downshift on the hwy.
  7. Aug 25, 2008 at 3:36 PM
    CornDog
    CornDog Well-Known Member
    Gallant, Alabama
    2007 SpeedWay Blue Double Cab Tacoma
    12000 lb Milemarker Winch Warn Trans4mer Grille Guard Gear Motorsports Wheels, Pioneer Head Unit w Ipod Interface, 2 Diamond D3 10's in custom box, UWS black tool box. N-fab stepbars, 15% tint, bug deflector,ventvisors, K&N Series 77 Cold air Intake, Hi lift jack mounted, 4D-LED maglite mounted, Lund Grill Screen
    i agree ^^^^^^^^^^^^ TOTALLY!!!!!!!!! ive got 45k on my taco. ive owned 3 stick tacomas b4 i got this one and i KNEW i was doin something wrong when i was test driving it. but it just took some getting used to. 45k miles later im pretty happy with it. it just might not be yal cup of tea tho. its deffinately a different style transmission tho. lol
  8. Aug 25, 2008 at 5:44 PM
    pmo
    pmo Well-Known Member
    Nova Scotia Canada
    2007 Tacoma 4x4, DC, 6 Speed Manual.
    I luv it!! BTW I never use 2nd when going from reverse. 2nd, 3rd and 4th are great, I can't believ the pickup in 4th at 80 or 85 kph!! The engine racing between gears is something that takes gettin used to...don't worry you will. I can go thru all 6 smooth as silk especially when accelerating to highway speeds!Its a great tranny
  9. Aug 25, 2008 at 5:52 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    You are right! Toyota's manual is a sorry ass excuse for a stick! To bad you learned this so late in life! :eek:
  10. Aug 25, 2008 at 5:56 PM
    kwalton
    kwalton Well-Known Member
    Baltimore, Md
    2017 MGM DCSB Sport 4x4
    i've driven stick for about 18 years and i too had a hard time getting used to this truck. i am now pretty used to it but it could be a little taller in the gearing. i drive a lot of highway. i also use 6th on main roads for the most part. 5th is the least used.
  11. Aug 25, 2008 at 6:10 PM
    lakewoodbilly
    lakewoodbilly Well-Known Member
    Bill
    Lakewood, CO
    White 08 DC V6 SR5 4WD TRD Sport
    Factory DRL's, Underhood Flood LED's, Underbody Multi-color LEDS, Red Line Tuning Elite Hood Struts, Anytime Fog Lights, PIAA 4100 Intense White, Luminics JDM Yellow H10 Fog Lights, OBX Sport Pedals, Sill Protectors, Bed Net, Front Bed Tie Downs, iPod and Aux Factory HU Interface, Sirius Sportster 5, Satellite Antenna through third brake light
    I totally agree with this. I rememeber my last truck ('91 that I drove for 17 years) was similar. It was tight when new and loosed up real nice over the life of the truck. I drove it hard as hell too on many occassions including many trips over jeep trails in the high country of CO. It finally loosened up enough that I needed to hold it in first just before I sold it.
    As far as the 6 speed, if you drive it hard and fast, you won't notice :D
  12. Aug 25, 2008 at 9:51 PM
    MyTaco
    MyTaco Well-Known Member
    Az
    08 Prerunner
    BLHM, Grillcraft grill, painted grill and eyelids. 285/70/17 BFG's on 17x9 Pro Comps 5100's all corners
    Is that why it RPM's between gears...emission related? After driving 4 other Toyota trucks over the last 25 years I thought It was the fly by wire throttle that was doing it since I never drove one before. You just have to re-train yourself in letting off the gas a little earlier before shifting. And I think 6th could be taller but I love how it's geared....feels like a truck!
  13. Aug 26, 2008 at 2:58 AM
    Nimbus 2008
    Nimbus 2008 Protected by GSD security systems
    08 PreRunner SR5 Double Cab
    LED light bar
    With Tacoma's I agree (had an '01) but not all Toyota's. My last vehicle was an '05 Rav4 that was fun to drive, zippy, effortless to shift, handled beautifully from the get go. If I hadn't only been in it long enough to save for our double cab... I would have kept it if I could have afforded three vehicles. Now in an automatic Tacoma I miss driving manual so badly at times.
  14. Aug 26, 2008 at 5:32 AM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    As a owner of a 5 lugger, Myself and others wish 1st and 2nd were geared lower. With the a/c on unless you rev above 2500 RPM, when you hit second it lugs and the truck vibrates, even with a firm throttle application. With A/C off it is better. My feeling is the clutch won't make it to 100K, because it is so highy stressed during takeoff from a dead stop. I think WaWire said it best, why is the 4 cyl autobahn geared, and the 6-speed manual geared so low?
  15. Aug 26, 2008 at 6:16 AM
    klown
    klown Tacoma World Ring Leader
    Lynchburg, VA
    2008 TRD sport 4x4 double cab 6-speed
    Black, leather and heated seats, borla sport exhaust, side curtain airbags, daytime running lights, all weather mats, JBL premium 6 disk changer system, stainless step tubes, window tint, tow package
    I like the manual tranny in this truck. I drove the auto, the auto is a piece of shit. It never shifts when I want. Then when you're coming to a stop it decides it wants to downshift, which means you now have to step on the brakes a little harder. When you use cruise control and going up a slight hill, the auto wants to downshift and floor it to get up to speed. The auto is not worth a piece of shit in my book.
    Yeah, the 6 speed took some getting used to, heck every manual tranny vehicle I ever owned taked some getting used to. But this is a truck, so first gear is gonna be LOW.
    I've never had an issue finding any particular gear, you may have an issue with your tranny. Maybe get it checked out, I would say that it is not normal.
  16. Aug 26, 2008 at 6:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Interesting oppinion on the Auto tranny. Mine is the best auto I have ever diven. Doesnt upshift unless nessesary, always seems to be in the best gear. It even short shifts when towing my boat. :confused: It rearly shifts latter than 2500 rpm unless Im getting on it.
  17. Aug 26, 2008 at 6:25 AM
    klown
    Lynchburg, VA
    Maybe they drive differently after you've driven them for a while, I don't know. I wasn't too happy with my experience. Especially the cruise control deal, there are alot of hills over here. I can't have the thing downshift everytime I go up a hill. I just put my 6 speed in cruise and it just goes up the hill in 6th.
  18. Aug 26, 2008 at 6:32 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have heard about that. My truck goes right up a 6%+ grade without dropping a gear, unless I put my foot in it. It will down shift if I have my speed set high, or Im pulling mu boat, but many times it trys to lug the hill, so I manually shift it. Before I got my '07 I have heard people haveing issues with the Auto, but I drove it and figured Toyota had the bugs worked out. I guess they havent.
  19. Aug 26, 2008 at 7:23 AM
    piercedtiger
    Jon
    Southern Tier, NY
    I think they changed something in the 07+ models. I know 05's and 06's had a problem where they would downshift violently, floor it to get up to speed, upshift to OD, and then repeat the process again as it dropped down below the set point. Before the 07's came out I heard a LOT of people on TN complaining about that. It was so bad it scared some people as they'd be going up a hill behind someone and suddenly the truck with downshift 2 gears and surge ahead like it was trying to ram the car in front. :eek: Seems like there was an ECU tweak or something to change the shift behavior, but I don't remember for sure. Either way, I was happy to have my manual. :D Between that flaky CC problem, and the surging while stopped I was glad to have a manually controlled tranny.
  20. Aug 26, 2008 at 7:24 AM
    LID
    LID Member
    Calgary, (no more Ft.Smack, YEAH!)
    06 Tacoma SR5
    I find 6th a little short when empty but perfect when towing two sleds on my trailer.
